ADV7281 sending black frames when video signal is disconnected in free-run mode
Product Number: ADV7281A
Hello ADI team,
We are using ADV7281 to capture NTSC-J in UYVY 8-bit format with free run mode (set to blue color pattern) enabled. We are verifying disconnect-connect of the video source. Our expectation is that, when video source is disconnected the ADV7281 should switch to free-run mode and the video stream should continue (transit from video stream to free run) seamlessly.
Problem
When we disconnect the video source, we see that ADV7281 is sending black frames (with some noise) for around 1 second. We verify this by dumping the raw frame captured by the CSI block on the SOC side. After 1 second, we get a CSI error on the SOC side. Once we get CSI error, we reset the CSI block on the SOC side and after this we start getting the blue frames (as expected in free run mode).
Additional observations
From the raw frame dump its confirmed that ADV7281 is sending the black frames. The duration of black frame is consistent across multiple test cycle. On disconnect of the video source after receiving black frames we always get CSI error.
Questions
  1. As per our expectation with free run mode, the transition between video stream and free-run stream should be seamless. How long does the ADV7281 to switch to free-run mode?
  2. Why is ADV7281 sending black frames, instead of configured free-run pattern?
  3. Is it expected to get CSI error when ADV7281 switches from video stream and free-run stream on video source disconnection? Why?
  4. Is there a way to avoid black frames after disconnection of the video source?
Please review the attached register dump (adv7281_reg_dump_camera_connected.txt, adv7281_reg_dump_camera_disconnected.txt) and answer all the questions listed point by point.
adv7281_reg_dump_camera_connected is taken when video source is connected, and valid stream is given out by ADV7281.
adv7281_reg_dump_camera_disconnected is taken when video source is disconnected, and free-run mode is active.
CCI DBGR v1.1
cci power up [ok]
rd: addr 0x0 data 0xe [ok]
rd: addr 0x1 data 0xc8 [ok]
rd: addr 0x2 data 0x44 [ok]
rd: addr 0x3 data 0x4e [ok]
rd: addr 0x4 data 0x57 [ok]
rd: addr 0x5 data 0x0 [ok]
rd: addr 0x6 data 0x2 [ok]
rd: addr 0x7 data 0x7f [ok]
rd: addr 0x8 data 0x80 [ok]
rd: addr 0x9 data 0x80 [ok]
rd: addr 0xa data 0x0 [ok]
rd: addr 0xb data 0x0 [ok]
rd: addr 0xc data 0x36 [ok]
rd: addr 0xd data 0x7c [ok]
rd: addr 0xe data 0x0 [ok]
rd: addr 0xf data 0x0 [ok]
rd: addr 0x10 data 0xd [ok]
rd: addr 0x11 data 0x43 [ok]
rd: addr 0x12 data 0x0 [ok]
rd: addr 0x13 data 0x69 [ok]
rd: addr 0x14 data 0x10 [ok]
rd: addr 0x15 data 0x0 [ok]
rd: addr 0x16 data 0x28 [ok]
rd: addr 0x17 data 0x41 [ok]
rd: addr 0x18 data 0x93 [ok]
rd: addr 0x19 data 0xf1 [ok]
rd: addr 0x1a data 0x80 [ok]
rd: addr 0x1b data 0x80 [ok]
rd: addr 0x1c data 0xc0 [ok]
rd: addr 0x1d data 0xc0 [ok]
rd: addr 0x1e data 0xc2 [ok]
rd: addr 0x1f data 0x0 [ok]
rd: addr 0x20 data 0x41 [ok]
rd: addr 0x21 data 0x0 [ok]
rd: addr 0x22 data 0x21 [ok]
rd: addr 0x23 data 0xc1 [ok]
rd: addr 0x24 data 0x20 [ok]
rd: addr 0x25 data 0xa6 [ok]
rd: addr 0x26 data 0x0 [ok]
rd: addr 0x27 data 0x58 [ok]
rd: addr 0x28 data 0x20 [ok]
rd: addr 0x29 data 0x98 [ok]
rd: addr 0x2a data 0xa8 [ok]
rd: addr 0x2b data 0xe1 [ok]
rd: addr 0x2c data 0xae [ok]
rd: addr 0x2d data 0xf5 [ok]
rd: addr 0x2e data 0xaf [ok]
rd: addr 0x2f data 0xf6 [ok]
rd: addr 0x30 data 0xde [ok]
rd: addr 0x31 data 0x2 [ok]
rd: addr 0x32 data 0x41 [ok]
rd: addr 0x33 data 0x84 [ok]
rd: addr 0x34 data 0x0 [ok]
rd: addr 0x35 data 0x2 [ok]
rd: addr 0x36 data 0x0 [ok]
rd: addr 0x37 data 0x81 [ok]
rd: addr 0x38 data 0x80 [ok]
rd: addr 0x39 data 0xc0 [ok]
rd: addr 0x3a data 0x0 [ok]
rd: addr 0x3b data 0x44 [ok]
rd: addr 0x3c data 0x58 [ok]
rd: addr 0x3d data 0x22 [ok]
rd: addr 0x3e data 0x64 [ok]
rd: addr 0x3f data 0xe4 [ok]
rd: addr 0x40 data 0x90 [ok]
rd: addr 0x41 data 0x1 [ok]
rd: addr 0x42 data 0x7e [ok]
rd: addr 0x43 data 0xa4 [ok]
rd: addr 0x44 data 0xff [ok]
rd: addr 0x45 data 0xb6 [ok]
rd: addr 0x46 data 0x12 [ok]
rd: addr 0x47 data 0x0 [ok]
rd: addr 0x48 data 0x0 [ok]
rd: addr 0x49 data 0x0 [ok]
rd: addr 0x4a data 0x0 [ok]
rd: addr 0x4b data 0x0 [ok]
rd: addr 0x4c data 0x0 [ok]
rd: addr 0x4d data 0xef [ok]
rd: addr 0x4e data 0x8 [ok]
rd: addr 0x4f data 0x8 [ok]
rd: addr 0x50 data 0x8 [ok]
rd: addr 0x51 data 0x24 [ok]
rd: addr 0x52 data 0xcd [ok]
rd: addr 0x53 data 0x4e [ok]
rd: addr 0x54 data 0x80 [ok]
rd: addr 0x55 data 0x0 [ok]
rd: addr 0x56 data 0x10 [ok]
rd: addr 0x57 data 0x0 [ok]
rd: addr 0x58 data 0x0 [ok]
rd: addr 0x59 data 0x0 [ok]
rd: addr 0x5a data 0x90 [ok]
rd: addr 0x5b data 0x6 [ok]
rd: addr 0x5c data 0x0 [ok]
rd: addr 0x5d data 0x6d [ok]
rd: addr 0x5e data 0x6d [ok]
rd: addr 0x5f data 0xa8 [ok]
rd: addr 0x60 data 0xb0 [ok]
rd: addr 0x61 data 0x0 [ok]
rd: addr 0x62 data 0x20 [ok]
rd: addr 0x63 data 0xd0 [ok]
rd: addr 0x64 data 0x10 [ok]
rd: addr 0x65 data 0x6 [ok]
rd: addr 0x66 data 0x28 [ok]
rd: addr 0x67 data 0x3 [ok]
rd: addr 0x68 data 0x1 [ok]
rd: addr 0x69 data 0x0 [ok]
rd: addr 0x6a data 0x0 [ok]
rd: addr 0x6b data 0x92 [ok]
rd: addr 0x6c data 0x3 [ok]
rd: addr 0x6d data 0x0 [ok]
rd: addr 0x6e data 0x0 [ok]
rd: addr 0x6f data 0x0 [ok]
rd: addr 0x70 data 0x0 [ok]
rd: addr 0x71 data 0x0 [ok]
rd: addr 0x72 data 0x80 [ok]
rd: addr 0x73 data 0x0 [ok]
rd: addr 0x74 data 0x20 [ok]
rd: addr 0x75 data 0x0 [ok]
rd: addr 0x76 data 0x0 [ok]
rd: addr 0x77 data 0x0 [ok]
rd: addr 0x78 data 0x0 [ok]
rd: addr 0x79 data 0x0 [ok]
rd: addr 0x7a data 0xf8 [ok]
rd: addr 0x7b data 0x0 [ok]
rd: addr 0x7c data 0x0 [ok]
rd: addr 0x7d data 0x0 [ok]
rd: addr 0x7e data 0x0 [ok]
rd: addr 0x7f data 0x0 [ok]
rd: addr 0x80 data 0x51 [ok]
rd: addr 0x81 data 0x51 [ok]
rd: addr 0x82 data 0x68 [ok]
rd: addr 0x83 data 0x0 [ok]
rd: addr 0x84 data 0xc [ok]
rd: addr 0x85 data 0x2 [ok]
rd: addr 0x86 data 0x3 [ok]
rd: addr 0x87 data 0x63 [ok]
rd: addr 0x88 data 0x5a [ok]
rd: addr 0x89 data 0x8 [ok]
rd: addr 0x8a data 0x10 [ok]
rd: addr 0x8b data 0x0 [ok]
rd: addr 0x8c data 0x40 [ok]
rd: addr 0x8d data 0x2 [ok]
rd: addr 0x8e data 0x40 [ok]
rd: addr 0x8f data 0x0 [ok]
rd: addr 0x90 data 0x0 [ok]
rd: addr 0x91 data 0x0 [ok]
rd: addr 0x92 data 0x0 [ok]
rd: addr 0x93 data 0x0 [ok]
rd: addr 0x94 data 0x0 [ok]
rd: addr 0x95 data 0x0 [ok]
rd: addr 0x96 data 0x0 [ok]
rd: addr 0x97 data 0x0 [ok]
rd: addr 0x98 data 0x0 [ok]
rd: addr 0x99 data 0x0 [ok]
rd: addr 0x9a data 0x0 [ok]
rd: addr 0x9b data 0x0 [ok]
rd: addr 0x9c data 0x0 [ok]
rd: addr 0x9d data 0x0 [ok]
rd: addr 0x9e data 0x11 [ok]
rd: addr 0x9f data 0x60 [ok]
rd: addr 0xa0 data 0x0 [ok]
rd: addr 0xa1 data 0x0 [ok]
rd: addr 0xa2 data 0x0 [ok]
rd: addr 0xa3 data 0x0 [ok]
rd: addr 0xa4 data 0x0 [ok]
rd: addr 0xa5 data 0x0 [ok]
rd: addr 0xa6 data 0x0 [ok]
rd: addr 0xa7 data 0x0 [ok]
rd: addr 0xa8 data 0x0 [ok]
rd: addr 0xa9 data 0x0 [ok]
rd: addr 0xaa data 0x0 [ok]
rd: addr 0xab data 0x0 [ok]
rd: addr 0xac data 0x0 [ok]
rd: addr 0xad data 0x0 [ok]
rd: addr 0xae data 0x0 [ok]
rd: addr 0xaf data 0x0 [ok]
rd: addr 0xb0 data 0x0 [ok]
rd: addr 0xb1 data 0x0 [ok]
rd: addr 0xb2 data 0x0 [ok]
rd: addr 0xb3 data 0x0 [ok]
rd: addr 0xb4 data 0x0 [ok]
rd: addr 0xb5 data 0x0 [ok]
rd: addr 0xb6 data 0x0 [ok]
rd: addr 0xb7 data 0x0 [ok]
rd: addr 0xb8 data 0x0 [ok]
rd: addr 0xb9 data 0x0 [ok]
rd: addr 0xba data 0x0 [ok]
rd: addr 0xbb data 0x0 [ok]
rd: addr 0xbc data 0x0 [ok]
rd: addr 0xbd data 0x0 [ok]
rd: addr 0xbe data 0x0 [ok]
rd: addr 0xbf data 0x2 [ok]
rd: addr 0xc0 data 0x18 [ok]
rd: addr 0xc1 data 0x80 [ok]
rd: addr 0xc2 data 0x40 [ok]
rd: addr 0xc3 data 0x4 [ok]
rd: addr 0xc4 data 0x60 [ok]
rd: addr 0xc5 data 0x91 [ok]
rd: addr 0xc6 data 0x0 [ok]
rd: addr 0xc7 data 0x0 [ok]
rd: addr 0xc8 data 0x0 [ok]
rd: addr 0xc9 data 0x4 [ok]
rd: addr 0xca data 0x0 [ok]
rd: addr 0xcb data 0x0 [ok]
rd: addr 0xcc data 0x69 [ok]
rd: addr 0xcd data 0x0 [ok]
rd: addr 0xce data 0x1 [ok]
rd: addr 0xcf data 0xb4 [ok]
rd: addr 0xd0 data 0x0 [ok]
rd: addr 0xd1 data 0x10 [ok]
rd: addr 0xd2 data 0xff [ok]
rd: addr 0xd3 data 0xff [ok]
rd: addr 0xd4 data 0x7f [ok]
rd: addr 0xd5 data 0x7f [ok]
rd: addr 0xd6 data 0x3e [ok]
rd: addr 0xd7 data 0x8 [ok]
rd: addr 0xd8 data 0x3c [ok]
rd: addr 0xd9 data 0x8 [ok]
rd: addr 0xda data 0x3c [ok]
rd: addr 0xdb data 0x9b [ok]
rd: addr 0xdc data 0xac [ok]
rd: addr 0xdd data 0x4c [ok]
rd: addr 0xde data 0x8 [ok]
rd: addr 0xdf data 0x6 [ok]
rd: addr 0xe0 data 0x15 [ok]
rd: addr 0xe1 data 0x80 [ok]
rd: addr 0xe2 data 0x80 [ok]
rd: addr 0xe3 data 0x80 [ok]
rd: addr 0xe4 data 0x80 [ok]
rd: addr 0xe5 data 0x25 [ok]
rd: addr 0xe6 data 0x4 [ok]
rd: addr 0xe7 data 0x63 [ok]
rd: addr 0xe8 data 0x65 [ok]
rd: addr 0xe9 data 0x14 [ok]
rd: addr 0xea data 0x63 [ok]
rd: addr 0xeb data 0x55 [ok]
rd: addr 0xec data 0x55 [ok]
rd: addr 0xed data 0x0 [ok]
rd: addr 0xee data 0x0 [ok]
rd: addr 0xef data 0x4a [ok]
rd: addr 0xf0 data 0x44 [ok]
rd: addr 0xf1 data 0xc [ok]
rd: addr 0xf2 data 0x32 [ok]
rd: addr 0xf3 data 0x0 [ok]
rd: addr 0xf4 data 0x15 [ok]
rd: addr 0xf5 data 0xe0 [ok]
rd: addr 0xf6 data 0x69 [ok]
rd: addr 0xf7 data 0x10 [ok]
rd: addr 0xf8 data 0x0 [ok]
rd: addr 0xf9 data 0x3 [ok]
rd: addr 0xfa data 0xa0 [ok]
rd: addr 0xfb data 0x40 [ok]
rd: addr 0xfc data 0x4 [ok]
rd: addr 0xfd data 0x0 [ok]
rd: addr 0xfe data 0x88 [ok]
rd: addr 0xff data 0x0 [ok]
wr: addr 0xe data 0x20 [ok]
rd: addr 0xe data 0x20 [ok]
rd: addr 0x40 data 0x10 [ok]
rd: addr 0x41 data 0x0 [ok]
rd: addr 0x42 data 0x0 [ok]
rd: addr 0x43 data 0x0 [ok]
rd: addr 0x44 data 0x0 [ok]
rd: addr 0x45 data 0x0 [ok]
rd: addr 0x46 data 0x0 [ok]
rd: addr 0x49 data 0x6 [ok]
rd: addr 0x4d data 0xc4 [ok]
rd: addr 0x4e data 0x0 [ok]
rd: addr 0x4f data 0x0 [ok]
rd: addr 0x50 data 0x20 [ok]
rd: addr 0x51 data 0x0 [ok]
rd: addr 0x52 data 0x0 [ok]
rd: addr 0x53 data 0x0 [ok]
rd: addr 0x54 data 0x0 [ok]
rd: addr 0x56 data 0x0 [ok]
rd: addr 0x5a data 0x0 [ok]
rd: addr 0x5b data 0x0 [ok]
rd: addr 0x5d data 0x0 [ok]
rd: addr 0x5e data 0x0 [ok]
rd: addr 0x5f data 0x0 [ok]
rd: addr 0x60 data 0x88 [ok]
rd: addr 0x61 data 0x10 [ok]
rd: addr 0x62 data 0x15 [ok]
rd: addr 0x63 data 0x2a [ok]
rd: addr 0x65 data 0x0 [ok]
rd: addr 0x66 data 0x0 [ok]
rd: addr 0x67 data 0x0 [ok]
rd: addr 0x68 data 0x0 [ok]
rd: addr 0x6b data 0x0 [ok]
rd: addr 0x6c data 0x0 [ok]
rd: addr 0x72 data 0x0 [ok]
rd: addr 0x74 data 0x0 [ok]
rd: addr 0x78 data 0xc4 [ok]
rd: addr 0x7a data 0x0 [ok]
rd: addr 0x80 data 0x0 [ok]
rd: addr 0x81 data 0x0 [ok]
rd: addr 0x82 data 0x0 [ok]
rd: addr 0x84 data 0x0 [ok]
rd: addr 0x85 data 0x0 [ok]
rd: addr 0x86 data 0x0 [ok]
rd: addr 0x87 data 0x0 [ok]
rd: addr 0x88 data 0x0 [ok]
rd: addr 0x89 data 0x0 [ok]
rd: addr 0x8a data 0x0 [ok]
rd: addr 0x8c data 0x0 [ok]
rd: addr 0x8d data 0x0 [ok]
rd: addr 0x8e data 0x0 [ok]
rd: addr 0x92 data 0x50 [ok]
rd: addr 0x93 data 0xe3 [ok]
rd: addr 0x94 data 0xef [ok]
rd: addr 0x95 data 0xee [ok]
rd: addr 0x96 data 0x5 [ok]
rd: addr 0x98 data 0x40 [ok]
rd: addr 0x99 data 0xff [ok]
rd: addr 0x9a data 0xe7 [ok]
rd: addr 0x9b data 0xfb [ok]
rd: addr 0x9c data 0x30 [ok]
rd: addr 0x9e data 0x0 [ok]
rd: addr 0x9f data 0x0 [ok]
VIDIOC_CAM_CONTROL: failed: Connection timed out
rd: addr 0xb9 data 0x0 [fail]
rd: addr 0xbf data 0x0 [ok]
rd: addr 0xc0 data 0x0 [ok]
rd: addr 0xc1 data 0x0 [ok]
rd: addr 0xc2 data 0x0 [ok]
rd: addr 0xc3 data 0x0 [ok]
rd: addr 0xc4 data 0x0 [ok]
rd: addr 0xc5 data 0x0 [ok]
rd: addr 0xc9 data 0x0 [ok]
rd: addr 0xcc data 0x0 [ok]
rd: addr 0xce data 0x0 [ok]
rd: addr 0xcf data 0x0 [ok]
rd: addr 0xd1 data 0x0 [ok]
rd: addr 0xd2 data 0x0 [ok]
rd: addr 0xd3 data 0x0 [ok]
rd: addr 0xd4 data 0x0 [ok]
rd: addr 0xd5 data 0x0 [ok]
rd: addr 0xd6 data 0x0 [ok]
rd: addr 0xd7 data 0x0 [ok]
rd: addr 0xd8 data 0x0 [ok]
rd: addr 0xd9 data 0x0 [ok]
rd: addr 0xda data 0x0 [ok]
rd: addr 0xdb data 0x0 [ok]
rd: addr 0xdc data 0x0 [ok]
rd: addr 0xdd data 0x0 [ok]
rd: addr 0xde data 0x0 [ok]
rd: addr 0xdf data 0x0 [ok]
rd: addr 0xe0 data 0x0 [ok]
rd: addr 0xe1 data 0x0 [ok]
rd: addr 0xe2 data 0x0 [ok]
rd: addr 0xe3 data 0x0 [ok]
rd: addr 0xe4 data 0x0 [ok]
rd: addr 0xe5 data 0x0 [ok]
rd: addr 0xe6 data 0x0 [ok]
rd: addr 0xe7 data 0x0 [ok]
rd: addr 0xe8 data 0x0 [ok]
rd: addr 0xe9 data 0x0 [ok]
rd: addr 0xea data 0x0 [ok]
rd: addr 0xeb data 0x0 [ok]
rd: addr 0xec data 0x0 [ok]
rd: addr 0xef data 0x0 [ok]
rd: addr 0xf0 data 0x0 [ok]
rd: addr 0xf1 data 0x0 [ok]
rd: addr 0xf2 data 0x0 [ok]
rd: addr 0xf4 data 0x0 [ok]
rd: addr 0xf5 data 0x0 [ok]
rd: addr 0xf6 data 0x0 [ok]
rd: addr 0xf7 data 0x0 [ok]
rd: addr 0xf9 data 0x0 [ok]
rd: addr 0xfa data 0x0 [ok]
rd: addr 0xfb data 0x0 [ok]
rd: addr 0xfc data 0x0 [ok]
rd: addr 0xfe data 0x0 [ok]
wr: addr 0xe data 0x40 [ok]
rd: addr 0xe data 0x40 [ok]
rd: addr 0x2e data 0xb0 [ok]
rd: addr 0x40 data 0x0 [ok]
rd: addr 0x41 data 0x4 [ok]
rd: addr 0x42 data 0x8 [ok]
rd: addr 0x43 data 0x39 [ok]
rd: addr 0x44 data 0x1e [ok]
rd: addr 0x45 data 0xd7 [ok]
rd: addr 0x46 data 0x21 [ok]
rd: addr 0x47 data 0x42 [ok]
rd: addr 0x48 data 0x68 [ok]
rd: addr 0x49 data 0x40 [ok]
rd: addr 0x4b data 0x51 [ok]
rd: addr 0x4c data 0x90 [ok]
rd: addr 0x4d data 0x54 [ok]
rd: addr 0x4e data 0x30 [ok]
rd: addr 0x52 data 0x6a [ok]
rd: addr 0x53 data 0x56 [ok]
rd: addr 0x54 data 0x1f [ok]
rd: addr 0x55 data 0x25 [ok]
rd: addr 0x56 data 0x1e [ok]
rd: addr 0x57 data 0xf [ok]
rd: addr 0x58 data 0x2c [ok]
rd: addr 0x59 data 0x81 [ok]
rd: addr 0x5a data 0x57 [ok]
rd: addr 0x5b data 0x19 [ok]
rd: addr 0x5c data 0x64 [ok]
rd: addr 0x5e data 0x40 [ok]
rd: addr 0x5f data 0x40 [ok]
rd: addr 0x60 data 0xc [ok]
rd: addr 0x61 data 0x20 [ok]
rd: addr 0x62 data 0x0 [ok]
rd: addr 0x63 data 0x12 [ok]
rd: addr 0x64 data 0x98 [ok]
rd: addr 0x65 data 0x2d [ok]
rd: addr 0x66 data 0x42 [ok]
rd: addr 0x67 data 0x1e [ok]
rd: addr 0x69 data 0x4 [ok]
rd: addr 0x6a data 0xca [ok]
rd: addr 0x6d data 0x3f [ok]
rd: addr 0x6e data 0x35 [ok]
rd: addr 0x6f data 0x8e [ok]
rd: addr 0x70 data 0x39 [ok]
rd: addr 0x71 data 0xd7 [ok]
rd: addr 0x72 data 0x21 [ok]
rd: addr 0x81 data 0xa0 [ok]
rd: addr 0x82 data 0xa [ok]
rd: addr 0x83 data 0xd [ok]
rd: addr 0x84 data 0x88 [ok]
rd: addr 0x85 data 0xf8 [ok]
rd: addr 0x86 data 0x40 [ok]
rd: addr 0x87 data 0x20 [ok]
rd: addr 0x92 data 0x6 [ok]
rd: addr 0xbc data 0x7 [ok]
rd: addr 0xc3 data 0x7 [ok]
rd: addr 0xc4 data 0x11 [ok]
rd: addr 0xda data 0xff [ok]
rd: addr 0xdc data 0xff [ok]
rd: addr 0xdd data 0xcc [ok]
rd: addr 0xde data 0xcc [ok]
rd: addr 0xe1 data 0x11 [ok]
rd: addr 0xe2 data 0x88 [ok]
rd: addr 0xe3 data 0x1b [ok]
rd: addr 0xe4 data 0xd7 [ok]
rd: addr 0xe5 data 0x23 [ok]
rd: addr 0xe6 data 0x10 [ok]
wr: addr 0xe data 0x0 [ok]
cci power down [ok]
CCI DBGR v1.1
cci power up [ok]
rd: addr 0x10 data 0xe [ok]
rd: addr 0x13 data 0x78 [ok]
rd: addr 0x45 data 0x10 [ok]
rd: addr 0x49 data 0x4 [ok]
rd: addr 0x6a data 0x0 [fail]
cci power down [ok]
Chau
      By using standard scripts after an analog video source is disconnected it can take the ADV728x upto 1 second to enter free-run mode. Using fast swtiching scripts it can take the ADV728x under 250 ms to enter free-run mode.
      For more information Please refer this FAQ at (2) How Does the Free-run Mode Work in the ADV728x Devices ? - Q&A - Video - EngineerZone (analog.com)
       Kindly note that, the output timing of the MIPI CSI-2 parts (ADV7280-M, ADV7281-M, ADV7281-MA, ADV7282-M) cannot be modified. The ADV7282-M does not adjust the video frame. It digitizes the full video signal and outputs it in standard output timing. But in the case of the ADV7282-M it convert it from interlaces to progressive and then provides it as a MIPI signal.
       For custom board, Kindly verify your schematic with reference one which is available at "ADV728x design support file" link, to ensure the connections are connected properly between ADV728x and SoC(Renesas).
      Also kindly do below configuration as per our reference script and let us know the result.
    :Color Bars 480i MIPI Out:
    delay 10 ;
    42 0F 00 ; Exit Power Down Mode
    42 00 04 ; ADI Required Write
    42 0C 37 ; Force Free-run mode
    42 02 4
    84 ; Force standard to NTSC-M
    42 14 11 ; Set Free-run pattern to color bars
    42 03 4E ; ADI Required Write
    42 04 57 ; Power-up INTRQ pin
    42 13 00 ; Enable INTRQ output driver
    42 17 41 ; select SH1
    42 1D C0 ; Tri-State LLC output driver
    42 52 CD ; ADI Required Write
    42 80 51 ; ADI Required Write
    42 81 51 ; ADI Required Write
    42 82 68 ; ADI Required Write
    42 5D 1C ; Enable Diagnostic pin 1 - Level=1.125V
    42 5E 1C ; Enable Diagnostic pin 2 - Level=1.125V
    42 FE 88 ; Set CSI Map Address
    88 DE 02 ; Power up MIPI D-PHY
    88 D2 F7 ; ADI Required Write
    88 D8 65 ; ADI Required Write
    88 E0 09 ; ADI Required Write
    88 2C 00 ; ADI Required Write
    88 00 00 ; Power up MIPI CSI-2 Tx
    End
    Poornima
    It turns out I didn't switch to user sub map 2 when trying to enable the fast switch mode, therefore the changes didn't take effect. Once fast switch is enabled correctly, we no longer get black frames and the free-run mode kicks in instantly.
    Chau
