Hi.
Looking for the easiest way to convert BT656 into analog PAL output.
Is it enough just to connect BT656 data stream to the ADV7393BCPZ and configure it via I2C or anything additional pre-processing to the BT656 stream is required?
Thanx,
Eli.
ADV7393
Recommended for New Designs
The ADV7390Â /Â ADV7391Â /Â ADV7392Â / ADV7393Â are a family of high speed, digital-to-analog video encoders on single monolithic chips. Three 2.7 V/3...
Datasheet
ADV7393 on Analog.com
Hi.
Thanx,
Eli.
ADV7393 will support BT.656 digital video input into analog PAL output.
Please refer our schematic for data connectivity.
Poornima
Thanx, Poornima.
Does the schematic attached is ok?
This chip is quite complicated and have lot of config registers. Is there any way to get registers set values to config it for BT.656 to PAL conversion?
Please crosscheck your Schematic against our standard ADV739x reference Schematic at /cfs-file/__key/communityserver-discussions-components-files/331/7065.ADV739x_5F00_Evaluation_5F00_Board_5F00_Documents.zip .
Kindly note that, ADV739x can support 480p and 576p in BT656 format and Table 63 lists the scripts available for SD modes of operation. Similarly, Table 98 and Table 115 list the scripts available for ED and HD modes of operation, respectively. For all scripts, only the necessary register writes are included.
Poornima
Thanx :)
