this ADV7850 is support for NTSC/PAL to HDMI conversion?
thanks
Ganesh
ADV7850
Recommended for New Designs
The ADV7850 is a high quality, single chip, multiformat video decoder graphics digitizer with an integrated 4:1 multiplexed HDMI® receiver.
This multiformat...
Datasheet
ADV7850 on Analog.com
thanks
Ganesh
ADV7850 can do this. It can accept NTSC/PAL video signal and output HDMI. Purchase our evaluation board (EVAL-ADV7850EBZ) to confirm it works for your application and use it as a reference for your project.
Kindly note that, ADV7850 is a high quality, single chip, multiformat video decoder that supports the conversion of PAL, NTSC, and SECAM standards in the form of a composite or an S-Video input signal into a HDMI output stream at (+) ADV7850 Design Support Files - Documents - Video - EngineerZone (analog.com)
Poornima
Thank you, madam, for your reply. I have a small doubt regarding the ADV7850. This board supports converting NTSC/PAL to HDMI, and my requirement involves two NTSC/PAL inputs, but there is only one HDMI output present. How do I select between the two input signals? I have already gone through the data sheet, and it indicates that for analog inputs, no mux is present for selecting the signals. Can you please clarify this doubt?
