memory_initialization_radix=16; memory_initialization_vector= 4cff80, :MAIN RESET 4cff80, :MAIN RESET 4cf480, :Programmable I2C slave address for CEC map 4cf57c, :Programmable I2C slave address for Infoframe map 4cf964, :Programmable I2C slave address for KSV map 4cfa6c, :Programmable I2C slave address for EDID map 4cfb68, :Programmable I2C slave address for HDMI map 4cfd44, :Programmable I2C slave address for CP map 346ca6, : 4c2070, :A manual control for the value of HPA on Port A. Only valid if HPA_MANUAL is set to 1.(x111,0000) 4c0001, :Sets the input video standard mode. Configuration is dependant on PRIM_MODE[3:0]. 4c0106, :A control to set vertical frequency : - 60 Hz 4c02f2, :1111 - Input color space depends on color space reported by HDMI block, 2 - RGB color space output 4c0340, :- 24-bit 4:4:4 SDR mode 4c0528, :A control to select DE signal or Field signal to be output on the FIELD/DE pin. 4c06a6, :A control to select VSync signal or Field signal to be output on VS/Field pin. 4c0b44, :A power-down control 4c0c42, :POWER_DOWN 4c1455, :drive strength control 4c15b0, :output tristate 4c1983, :Enable LLC DLL, 4c3340, :Muxes the DLL output on LLC output 22ba01, : 324081, : 327401, : EDID enable 327401, : 327401, : 340000, :HDMI_REGISTER_00H :000 - Port A 340101, : 349b03, : 34c101, : 34c201, : 34c201, : 34c301, : 34c401, : 34c501, : 34c601, : 34c701, : 34c801, : 34c901, : 34ca01, : 34cb01, : 34cc01, : 3483fe, : 346f08, : 34851f, : 348770, : 348d04, : 348e1e, : 360000, :Header 3601ff, :Header 3602ff, :Header 3603ff, :Header 3604ff, :Header 3605ff, :Header 3606ff, :Header 360700, :Header 360830, :Manufacturer ID 3609D4, :Manufacturer ID 360a00, :Product ID Code 360b00, :Product ID Code 360c00, :Serial Number 360d00, :Serial Number 360e00, :Serial Number 360f00, :Serial Number 361034, :Manufacture Date 361121, :Manufacture Date 361201, :EDID Version 361304, :EDID revision 3614a1, :Video Type Input 361522, :Horizontal Size(cm) 361600, :Vertical Size (cm) 361700, :Display Gamma 361800, :Supported features 361900, :Color Characteristics 361a00, :Color Characteristics 361b00, :Color Characteristics 361c00, :Color Characteristics 361d00, :Color Characteristics 361e00, :Color Characteristics 361f00, :Color Characteristics 362000, :Color Characteristics 362100, :Color Characteristics 362200, :Color Characteristics 362301, :Established Supported Timings 362400, :Established Supported Timings 362500, :Manufacture's reserved Timings 362601, :EDID Standard Supported Timings 362700, :EDID Standard Supported Timings 362801, :EDID Standard Supported Timings 362900, :EDID Standard Supported Timings 362a01, :EDID Standard Supported Timings 362b00, :EDID Standard Supported Timings 362c01, :EDID Standard Supported Timings 362d00, :EDID Standard Supported Timings 362e01, :EDID Standard Supported Timings 362f00, :EDID Standard Supported Timings 363001, :EDID Standard Supported Timings 363100, :EDID Standard Supported Timings 363201, :EDID Standard Supported Timings 363300, :EDID Standard Supported Timings 363401, :EDID Standard Supported Timings 363500, :EDID Standard Supported Timings 3636a0, :Detailed Timing block 1 36370f, :Detailed Timing block 1 363820, :Detailed Timing block 1 363900, :Detailed Timing block 1 363a31, :Detailed Timing block 1 363b58, :Detailed Timing block 1 363c1c, :Detailed Timing block 1 363d20, :Detailed Timing block 1 363e28, :Detailed Timing block 1 363f80, :Detailed Timing block 1 364014, :Detailed Timing block 1 364100, :Detailed Timing block 1 36420a, :Detailed Timing block 1 3643c8, :Detailed Timing block 1 364410, :Detailed Timing block 1 364500, :Detailed Timing block 1 364600, :Detailed Timing block 1 36471e, :Detailed Timing block 1 364800, :Detailed Timing Block 2 364900, :Detailed Timing Block 2 364a00, :Detailed Timing Block 2 364bfc, :Detailed Timing Block 2 364c00, :Detailed Timing Block 2 364d41, :Detailed Timing Block 2 364e44, :Detailed Timing Block 2 364f41, :Detailed Timing Block 2 365053, :Detailed Timing Block 2 365143, :Detailed Timing Block 2 36520a, :Detailed Timing Block 2 365320, :Detailed Timing Block 2 365420, :Detailed Timing Block 2 365520, :Detailed Timing Block 2 365620, :Detailed Timing Block 2 365720, :Detailed Timing Block 2 365820, :Detailed Timing Block 2 365920, :Detailed Timing Block 2 365a00, :Detailed Timing Block 3 365b00, :Detailed Timing Block 3 365c00, :Detailed Timing Block 3 365d10, :Detailed Timing Block 3 365e00, :Detailed Timing Block 3 365f00, :Detailed Timing Block 3 366000, :Detailed Timing Block 3 366100, :Detailed Timing Block 3 366200, :Detailed Timing Block 3 366300, :Detailed Timing Block 3 366400, :Detailed Timing Block 3 366500, :Detailed Timing Block 3 366600, :Detailed Timing Block 3 366700, :Detailed Timing Block 3 366800, :Detailed Timing Block 3 366900, :Detailed Timing Block 3 366a00, :Detailed Timing Block 3 366b00, :Detailed Timing Block 3 366c00, :Detailed Block 4 366d00, :Detailed Block 4 366e00, :Detailed Block 4 366f00, :Detailed Block 4 367000, :Detailed Block 4 367100, :Detailed Block 4 367200, :Detailed Block 4 367300, :Detailed Block 4 367400, :Detailed Block 4 367500, :Detailed Block 4 367600, :Detailed Block 4 367700, :Detailed Block 4 367800, :Detailed Block 4 367900, :Detailed Block 4 367a00, :Detailed Block 4 367b00, :Detailed Block 4 367c00, :Detailed Block 4 367d00, :Detailed Block 4 367e00, :Extension flag 367f3a, :Checksum 4c20f0; :A manual control for the value of HPA on Port A. Only valid if HPA_MANUAL is set to 1.(x111,0000)
