I connect ADV7611 input to a HMDI port, and connect it's RGB output to ADV7341.
by this setup I want convert HDMI input to PAL CVBS at output.
HDMI signal 720x576 @ 50Hz --> [ADV7611] -RGB,HS,VS,LLC -> [ADV7341]--> PAL CVBS
but at output of ADV7611 HS (Horizontal Sync) and VS (Vertical Sync) not generate at correct frequencies. as a result of output video not Horizontally/Vertically synced.
I expect HS = 15625Hz , VS = 50 Hz generate by ADV7611 for ADV7341, but Does not work correct!
Does the ADV7611 support this mode? And how to configure its registers ?
