I'm trying to explore the minimum necessary I2C commands needed to configure the 7842 on the EVAL-8005 board. As a baseline when using AVES Blue if I perform a capture all and then feed those settings back into the 7842 as a script, I don't get any output, even if the ADV8005 is reconfigured.
This procedure works with the ADV8005, why does it not seem to work with the 7842?
Thanks.
