[ADV7513] DE, Hsync, and Vsync Generation Recommended Settings for 1920x1080@30/25
Category: Datasheet/Specs
Product Number: ADV7513
In the ADV7513 programming guide, the tables for setting the DE generation, sync adjustment and embedded sync processing (i.e. tables 26, 27, & 28) do not show the settings for both 1080p25 nor 1080p29/30.
I'd like to know these recommended settings.
Please check if the register settings I tried are correct.
* (Table 26) Register Settings for DE Generation
0x35 0x36 0x37 0x38 0x39 0x3A
1080p29/30 0x2F 0xE9 0x0F 0x00 0x43 0x80
1080p25 0x2F 0xE9 0x0F 0x00 0x43 0x80
* (Table 27) Register Settings for Sync Adjustment
0xD7 0xD8 0xD9 0xDA 0xDB 0x17[6:5]
1080p29/30 0x16 0x02 0xC0 0x10 0x05 0x0
1080p25 0x84 0x02 0xC0 0x10 0x05 0x0
* (Table 28) Register Settings for Embedded Sync Processing
0x30 0x31 0x32 0x33 0x34 0x17[6:5]
1080p29/30 0x16 0x02 0xC0 0x08 0x05 0x0
1080p25 0x84 0x02 0xC0 0x08 0x05 0x0
Any help is significantly appreciated.
*Related Q&A is below.
ez.analog.com/.../8023
    For 1080p-30 resolution, please try with below recommended configuration on your side
    Register 0x35 0x36 0x37 0x38 0x39 0x3A
    Value 0x2F 0xE9 0x0F 0x00 0x43 0x80
    Register 0xD7 0xD8 0xD9 0xDA 0xDB 0X17
    Value 0x84 0x02 0xC0 0x10 0x05 0x00
    Register 0x30 0x31 0x32 0x33 0x34 0x17
    Value 0x16 0x02 0xC0 0x10 0x05 0x00
    Dharani S
  • Hi, thank you for your reply!
    I'll try the above settings.
    Sorry to trouble you, but could you please tell me 1080p-25 settings?
    For 1080p-25 resolution, please try with below recommended configuration on your side
    Please ensure with the above things and get back to us if further clarification is required on this.
    Dharani S
  • Hi, thank you for your support!
    Please tell me one thing.
    For 1080p-30 resolution (Table 27) Register Settings for Sync Adjustment, is register address 0xD7 setting 0x16??
    Thanks.
    Please try with 0x16 configuration on your side and get back to us if further clarification is required on this.
    Varshini K
  • Hi, thank you for your reply.
    It was displayed successfully with the following setting values.
    Thank you very much for your support!
    1080p29/30 0x16 0x02 0xC0 0x10 0x05 0x00
    1080p25 0x84 0x02 0xC0 0x10 0x05 0x00
