ADV7181C
here i attached design in file
please verify and give feedback
here are some clarification i need
in this design i used SDP 8-bit 4:2:2 mode
  1. for this mode the connections are right?
2.in this mode where i have to connect the following signals
   a.pin no#55  VS_IN
   b.pin no#56  HS_IN
   c.pin no#63  FIELD
   d.pin no#9  SFL/SYNC_OUT
   e.pin no#34  FB
   f.pin no#50  SOG/SOY
ADV7181C.pdf
  • FormerMember
    0 FormerMember
1) Watch the analog input impedance.  I don't see any 75 Ohm resistors or normal input circuit.  Please refer to the reference schematic in the data sheet.
2) What are D1 & D2 for?
3) ADV7181C is and old part, you should use ADV7181D
Follow the reference circuit and you should be OK
    Thank you,
    EZ Admin
