Video signal input level and ferrite beads for power supply
Category: Datasheet/Specs
Product Number: ADV7391
Software Version: -
Hello.
I am considering adopting ADV7391BCPZ.
I have a few questions.
1.
I use the following power supply specs.
VDD_IO = 3.3V,  VAA = 3.3V,  VDD = 1.8V,  PVDD = 1.8V
Since VDD_IO = 3.3V, I plan to input 3.3V digital video signals to P0-P7.
Is my understanding correct ?
Or should I adjust the input level of P0-P7 to VDD's 1.8V ?
2.
I would like to know how to select the recommended components or constants for the fayrite beads to be inserted in the power supply line.
I will be using it in a circuit that inputs in ITU-R BT.656, 8-bit 4:2:2 YCrCb and outputs an analog signal in NTSC or PAL SD quality.
HSYNC and VSYNC pins are not used.
Top Replies
  • FormerMember
    FormerMember
Oct 11, 2023 +1 verified
1) 3.3V digital inputs are good.  Check out Table 6 in the datasheet
2)  There are a number of good ways to implement the power rail filters.  The goal is to keep the power rails clean and isolated from each…
2)  There are a number of good ways to implement the power rail filters.  The goal is to keep the power rails clean and isolated from each other.
  • The reference design uses Murata NFE61PT472C1H9L as part of the Pi EMI filter network
  • You can use ferrite beads such as Murata BLM15EG221SN1D.
  • I prefer Murata NFM21PC105B1A3D style filters.
  • Hi, GuenterL
    Thank you very much for your answer.
