MAX9406 :: DisplayPort to DVI/HDMI Level Shifter :: TMDS Signal Swapping
Product Number: MAX9406ETJ+
Software Version: Not Applicable
Hello Team,
I am using MAX9406ETJ+  (DisplayPort to DVI/HDMI Level Shifter) for  Dual Mode-Diplay Port (DP++) to HDMI Conversion.
As per Application Notes  (APPLICATION NOTE 4313),  the output  signals (i.e., TMDS signal (OUT_D4  & OUT_D2 pairs)) to be swapped  like the following order as,
Input:   D4 D3 D2 D1 &
Output : D2 D3 D4 D1.
From the above, It is observed that TMDS Pair D4 & D2 got swapped for HDMI Conversion at Output side.
Is it, The output of Signals (TMDS pair D4 & D2) to swapped for DP to HDMI Conversion?
Kindly do the needful,
Note: Application Note Image is attached herewith
Prabakaran  P
