adv7343 RGB output image shift issue
Product Number: ADV7343
I am using ADV7343 chip. The input configuration is BT656 Ycbcr, and the output uses DAC1 as CVBS, DAC2 and DAC3 as Y/C, and DAC4, DAC5 and DAC6 as RGB output.
No matter whether the input is NTSC 480i or PAL 576i format, a problem is found now that the CVBS and Y/C outputs are normal, but the RGB output image is skewed to the right, I don't know why.
shifed to right
Thank you very much for your kind help.
moved & added tag
[edited by: emassa at 3:46 PM (GMT -4) on 24 May 2023]
