MAX96711
Production
The MAX96711 is a compact serializer with features especially suited for automotive camera applications. In high-bandwidth mode, the parallel-clock maximum...
Datasheet
MAX96711 on Analog.com
We got GMSL2 User Guide Version 22 (Working Draft) about more then one year ago. From the update history, I guess there should be a newer version of this document.
And for the GUI tool, we're now using v6.4.5. But there is a bug need to be confirmed from ADI: Error Starting PRBS while running PRBS test on MAX96712.
During PRBS test, ERRB function changes to reflect PRBS errors only. ERRB goes low when any PRBS errors occur. ERRB goes high when the PRBS error counter is reset when PRBS_ERR is read. Normal ERRB function resumes when exiting the PRBS test.
Please refer here at MAX96711 14-Bit GMSL Serializer with High Immunity/Bandwidth Mode and Coax/STP Cable Drive | Analog Devices
Poornima
It's not during, the GUI tool failed to start, because it send invalid command. Please see the first screenshot in the initial post.
Could you please check the same with respective forum? In this forum we are aware only for Video related parts.
Poornima
Hi PoornimaSubramani ,
GMSL is designed for serializing Video stream, especally for MIPI CSI/DSI or eDP/HDMI. So it's should be part of Video.
Can you tell me which sub-forum is for discussing GMSL? I checked https://ez.analog.com/subgrouplist, and found no one is fit then this Video sub-forum.
We got some of the document from google search related GMSL, Please go through this and let us know whether you got any useful information from this link,
https://www.stg-maximintegrated.com/en/products/interface/high-speed-signaling/MAX96717F.html
https://www.stg-maximintegrated.com/en/design/software-description.html/swpart=SFW0019760C
This link is about 'MAX96717F' part Search | Analog Devices
Poornima
