EVAL-ADV7182AEBZ_HSYNC_VSYNC_Abnormal Timing
Product Number: ADV7182
Software Version: DVP Eval Latest Source 10-14-11.exe
Dear Sirm,
We use DVP Eval Latest Source 10-14-11.exe on EVAL-ADV7182AEBZ.
It happen the following symptom.
<Symptom Detail>
AN1/Input Format:  NTSC
Using Script File:Scripts-> ADV7182A_CUST->02_CVBS_SINGLE_ENDED_AUTODETECT->Autodetect_CVBS_Single_Ended_In_Ain_1_YPbPr_Out
We checked Hsync and Vsync pin by oscilloscope.
-It  sometimes happen abnormal of the rising timing of HSYNC and VSYNC (it sometimes work normally.)
 It is unstable behavior of VSYNC.
   -Normal case : VSYNC is same rising timing as HSYNC. (HSYNC and VSYNC rise at same time.)
   -Abnormal case : VSYNC is different rising timing,shiftted(delayed) by 2 clock from HSYNC.
 At reading timing of the script file, it may be normal or abnormal. (dependent on read script file timing)
Could  you please advise us about this symptom?
Thanks and Best regards
Kida
  • Dear Poornima-san,
    Yes,your undestanding is correct.
    As result, this issue is dependent on reading "Script file" timing.
    But we don't know which registers affect it.
    Please advise us which register might be related with this issue if possible.
    Isshin Kida
       I don't think the register will affect this abnormal scenario.
       If possible, Could you please check the same in different eval board.
    Poornima
    Thank you for your reply.
    We tried the different PCBA (by ourselves design) with ADV7182A.
    It also happen same symptom.
    Please tell us about evaluation schematics "adv7182a-adv7280a-32ebz-sch_a.pdf" around X'tal "ABM8AIG-28.63636MHz-12-2Z-T3"
    We think that "-12" of "ABM8AIG-28.63636MHz-12-2Z-T3"  means "Load Capacitance (pF)" on the datasheet
    (ABM8AIG-1775167.pdf)
    But there is 20pF "Load Capacitance (pF)"  on Evalution board schematics.
    (1) Is "Load Capacitance (pF)" around X'tal schematics corret?
    (2) Is this X'tal of "Load Capacitance (pF)"  related with this symptom?
    Isshin Kida
  • FormerMember
    0 FormerMember
on Feb 13, 2023 9:47 AM in reply to IsshinKida
.PDF
Crystal load caps are calculated from crystal parameters outlined in this app note, see Figure 4 and the formulas in that paragraph.  From my calculation the load caps should be ~14pf however 20pF is close enough to start the crystal oscillator.  I don't know the parasitic capacitance for the EVAL board.
  • Dear GuenterL-san,
    CC:  Poornima-san,
    Thank you for your advise.
    Could you please try to check this symptom with Step1 to 6 on EVAL-ADV7182AEBZ?
    We think that you don't check this symptom on EVAL-ADV7182AEBZ.
    Isshin Kida
  • Hi IsshinKida San,
           For our Analog device evaluation boards, a Golledge MA01377 crystal is used. Please refer this FAQ about the Golledge crystal attachment at Notes about the crystal needed for the ADV7180 or ADV7182 - Documents - Video - EngineerZone (analog.com) -   Most of our testing is done with the attached crystal.
           C2 & C3 are dependent on the load capacitance specified in the crystal data sheet.  As an example, a Golledage MA01377 has a load capacitance of 30pF so C2 = C3 = 2 * (30 - 2) - 4 = 52pF, closest real cap. value would be 47pF. Please see our reference schematic (Marked in Yellow Color).
            And these caps adjust the impedance the crystal drivers see to make sure the crystal will oscillate.
    Poornima
    Thank you for your support and comment.
    We refer crystal load capcitance value. And we review crystal load capacitance value.
    Please tell us again.
    Does it happen this symptom if cystal load capacitance is wrong?
    We think that if crystal doesn't work well, it happen other symptom, for example no output DCLK and abnormal DCLK waveform.
    But as this waveform, this symptom is Vsync delay.
    Isshin Kida
  • FormerMember
    0 FormerMember on Feb 15, 2023 10:48 AM in reply to IsshinKida
    OK, lets break this up into 2 parts.
    Part 1, the crystal.  For proper operation the crystal circuit needs the correct load caps to balance the rest of the oscillator circuit in the chip.  If the load caps are incorrect the crystal may not oscillate at all or possibly at the wrong frequency.  If you probe either side of the crystal the probed capacitance can affect the oscillation operation.  If the load caps are temperature sensitive then it can affect the oscillation.  This is why load caps are always C0G (NPO) material, better temp coefficients.
    Part 2, 2 clock offset.
       a) First of all I'd like to see a scope trace of Ain1, VS and HS.  Is anything changing with the source.
       b) I'm a bit confused by the statement 'reading the script file'.  The script files are are write only to the ADV7182.  Normally you'd only be reading something back is if your controller is trying to read back what the auto-detect setting are.
       c) I assume the 2 clock offset stays consistent after you do the first scope capture and it doesn't revert back to a good case.
       d) is there any change while doing the I2C writes, you are coupling noise into Ain1 messing with the sync pulses?
       e) Even if the sync pulse timing changes a bit can not the downstream device handle it.  What truly makes it a good or bad case as long the the timing is consistent.
    Poornima, do you have a setup to duplicate this issue?
  • Hi Guenter,
           Sorry, Here we don't have ADV728x based eval board.
    Poornima
  • Dear Guenter-san and Poornima-san,
    -If we can send you EVAL-ADV7182AEBZ, can you try to duplicate this symptom?
    -Noted, Part1,
    -About Part2,
    --> We tried to change some source. It also happne this symptom.
    -->Sorry,I confused you. 'reading the script file' is mistook, correct operaion is "Write the script file".
    -->Yes, your understanding is correct.
    -->We don't change anythin whilw doing I2C write.
    --> This symptom problem is unstable V-sync.
    If Sync is unstable, video image position is shifted.
    Isshin Kida
