[ADV7480] About laptop audio output
The user is troubleshooting an issue where audio is not output from a Windows 10 laptop to a monitor equipped with the ADV7480 HDMI receiver. The final answer suggests that the EDID supports only LPCM audio and recommends toggling the HPA line to force the PC to re-read the EDID. The sequence to toggle HPA should be executed from the HPD=H state and involves setting specific register values. The user should also verify the audio stream format being played from the laptop.
We are evaluating the ADV780 product.
I am checking the video/audio output by connecting the HDMI output of a Windows 10 laptop (Dynabook R73)
to a monitor equipped with ADV7480.
The video from the PC is output, but the audio from the PC is not output.
(PC audio driver itself does not recognize)
What could be the cause?
For monitors without ADV7480, PC audio is output.
Best regards.
  • Hi Tatsuya San,
      Please note that,by using Consumer electronic equipment or PCs as an HDMI audio/video source can be very difficult since their functionality depends on their settings as well as the HDMI receiver's EDID
      For example everything depends on the source.  If the source doesn't get a valid EDID it may just begin transmitting in DVI mode with no audio and no HDCP.
     Please verify your EDID data supports Audio Since source output can change based on EDID data provided.
     Can you please inform customers to use a DVI/HDMI generator (such as Quantum Data/Astro) in order to test digital audio over HDMI. Please check with ASTRO equipment.
    Poornima
    Thank you for your reply.
    In the past, I was able to output video and audio from a Windows 10 laptop
    using HDMI receivers from other manufacturers.
    This time, I am using the same PC and ADV7480 as at that time,
    but the video is output, but the audio is not.
    The difference in EDID settings is Product ID, year of manufacture, EDID Revision,
    and check Sum.
    Is there any other possible cause other than EDID?
    Best regards.
  • Hi Tatsuya San,
            Could you please share your EDID bytes, We will check it and let you know the status.
    Poornima
    The EDID setting list is attached below.
    XLSX
    Best regards.
  • Hi Tatsuya San,
            It seems your corresponding EDID would support only LPCM audio.
            Please let us know, the audio stream that you are playing from the laptop.
            Also Please note sometimes PC has failed to get the correct EDID, So toggle the HPA line to force the PC to re-read the EDID and follow either below two sequence,
           This must be done after the EDID is loaded.
    1) Set HPA_MAN_VALUE_A = 1 ; sets bit high
    2) HPA_TRISTATE_A = 0 ;  make HPA pin an output
    3) set HPA_MAN_VALUE = 0 ; Pulls HPA pin low
    4) wait 100ms ; just delay a bit
    5) set HPA_TRISTATE = 1 ; makes HPA pin an input
    6) External pull up resistor will create the rising edge on the HPD  causing the PC to re-read the EDID
    Or
    1) HPA_MAN_VALUE_X =1
    2) HPA_A pin active =0
    3)  HPA_MAN_VALUE_A =0, sets HPA low
    4)  load up the EDID
    5) HPA_MAN_VALUE_A =1, sets HPA high, forces source to reload EDID
    Poornima
    Sorry for the late thank you.
    I have additional questions.
    Q1) Can the above sequence be executed from the HPD=H state?
    Q2) In the above sequence, is the following correct register setting procedure
           for the ADV7480 device?
          1) HDMI Rx-MAP(0x68) Register Addr(0xF8) Data (0x01)
          2) HDMI Rx-MAP(0x68) Register Addr(0xF9) Data (0x00)
          3) HDMI Rx-MAP(0x68) Register Addr(0xF8) Data (0x00)
          4) 100ms wait
          5) HDMI Rx-MAP(0x68) Register Addr(0xF9) Data (0x01)
     Or
          1) HPA_MAN_VALUE_X=1
          4) load up the EDID
          1) HDMI Rx-MAP(0x68) Register Addr(0x6C) Data (0x01)
          4) ??
          5) HDMI Rx-MAP(0x68) Register Addr(0xF8) Data (0x01)
          How can we control "4)"?
    Best regards.
  • Hi Tatsuya San,
    Please find the below comments,
    YES, the sequence should be executed from HPD High state.
    Please note When the sink toggles the HPA line low then high, It tells the source to read the EDID data.  Normally with source will not read the EDID until it sees a low to high transition( By spec, the low to high HPD transition should cause the source to read the EDID).
    Q2) How can we control "4)"?
    Please configure the below EDID in your script.
    And this CEA write would indicate the CEA tag is present "6C 80 02" .
    64 74 00 ; Disable the Internal EDID for all ports
    6C 00 00 ;
    6C 01 FF ;
    6C 02 FF ;
    6C 03 FF ;
    6C 04 FF ;
    6C 05 FF ;
    6C 06 FF ;
    6C 07 00 ;
    6C 08 06 ;
    6C 09 8F ;
    6C 0A 07 ;
    6C 0B 11 ;
    6C 0C 01 ;
    6C 0D 00 ;
    6C 0E 00 ;
    6C 0F 00 ;
    6C 10 17 ;
    6C 11 11 ;
    6C 12 01 ;
    6C 13 03 ;
    6C 14 80 ;
    6C 15 0C ;
    6C 16 09 ;
    6C 17 78 ;
    6C 18 0A ;
    6C 19 1E ;
    6C 1A AC ;
    6C 1B 98 ;
    6C 1C 59 ;
    6C 1D 56 ;
    6C 1E 85 ;
    6C 1F 28 ;
    6C 20 29 ;
    6C 21 52 ;
    6C 22 57 ;
    6C 23 00 ;
    6C 24 00 ;
    6C 25 00 ;
    6C 26 01 ;
    6C 27 01 ;
    6C 28 01 ;
    6C 29 01 ;
    6C 2A 01 ;
    6C 2B 01 ;
    6C 2C 01 ;
    6C 2D 01 ;
    6C 2E 01 ;
    6C 2F 01 ;
    6C 30 01 ;
    6C 31 01 ;
    6C 32 01 ;
    6C 33 01 ;
    6C 34 01 ;
    6C 35 01 ;
    6C 36 8C ;
    6C 37 0A ;
    6C 38 D0 ;
    6C 39 8A ;
    6C 3A 20 ;
    6C 3B E0 ;
    6C 3C 2D ;
    6C 3D 10 ;
    6C 3E 10 ;
    6C 3F 3E ;
    6C 40 96 ;
    6C 41 00 ;
    6C 42 81 ;
    6C 43 60 ;
    6C 44 00 ;
    6C 45 00 ;
    6C 46 00 ;
    6C 47 18 ;
    6C 48 01 ;
    6C 49 1D ;
    6C 4A 80 ;
    6C 4B 18 ;
    6C 4C 71 ;
    6C 4D 1C ;
    6C 4E 16 ;
    6C 4F 20 ;
    6C 50 58 ;
    6C 51 2C ;
    6C 52 25 ;
    6C 53 00 ;
    6C 54 81 ;
    6C 55 49 ;
    6C 56 00 ;
    6C 57 00 ;
    6C 58 00 ;
    6C 59 9E ;
    6C 5A 00 ;
    6C 5B 00 ;
    6C 5C 00 ;
    6C 5D FC ;
    6C 5E 00 ;
    6C 5F 56 ;
    6C 60 41 ;
    6C 61 2D ;
    6C 62 31 ;
    6C 63 38 ;
    6C 64 30 ;
    6C 65 39 ;
    6C 66 41 ;
    6C 67 0A ;
    6C 68 20 ;
    6C 69 20 ;
    6C 6A 20 ;
    6C 6B 20 ;
    6C 6C 00 ;
    6C 6D 00 ;
    6C 6E 00 ;
    6C 6F FD ;
    6C 70 00 ;
    6C 71 17 ;
    6C 72 3D ;
    6C 73 0D ;
    6C 74 2E ;
    6C 75 11 ;
    6C 76 00 ;
    6C 77 0A ;
    6C 78 20 ;
    6C 79 20 ;
    6C 7A 20 ;
    6C 7B 20 ;
    6C 7C 20 ;
    6C 7D 20 ;
    6C 7E 01 ;
    6C 7F 1C ;
    6C 80 02 ;
    6C 81 03 ;
    6C 82 3D ;
    6C 83 71 ;
    6C 84 4D ;
    6C 85 82 ;
    6C 86 05 ;
    6C 87 04 ;
    6C 88 01 ;
    6C 89 10 ;
    6C 8A 11 ;
    6C 8B 14 ;
    6C 8C 13 ;
    6C 8D 1F ;
    6C 8E 06 ;
    6C 8F 15 ;
    6C 90 03 ;
    6C 91 12 ;
    6C 92 3E ;
    6C 93 0F ;
    6C 94 7F ;
    6C 95 07 ;
    6C 96 17 ;
    6C 97 1F ;
    6C 98 38 ;
    6C 99 1F ;
    6C 9A 07 ;
    6C 9B 30 ;
    6C 9C 2F ;
    6C 9D 07 ;
    6C 9E 72 ;
    6C 9F 3F ;
    6C A0 7F ;
    6C A1 72 ;
    6C A2 4F ;
    6C A3 7F ;
    6C A4 00 ;
    6C A5 57 ;
    6C A6 7F ;
    6C A7 00 ;
    6C A8 5F ;
    6C A9 7F ;
    6C AA 01 ;
    6C AB 37 ;
    6C AC 7F ;
    6C AD 72 ;
    6C AE 67 ;
    6C AF 7F ;
    6C B0 00 ;
    6C B1 83 ;
    6C B2 4F ;
    6C B3 00 ;
    6C B4 00 ;
    6C B5 67 ;
    6C B6 03 ;
    6C B7 0C ;
    6C B8 00 ;
    6C B9 10 ;
    6C BA 00 ;
    6C BB B8 ;
    6C BC 2D ;
    6C BD 01 ;
    6C BE 1D ;
    6C BF 00 ;
    6C C0 72 ;
    6C C1 51 ;
    6C C2 D0 ;
    6C C3 1E ;
    6C C4 20 ;
    6C C5 6E ;
    6C C6 28 ;
    6C C7 55 ;
    6C C8 00 ;
    6C C9 81 ;
    6C CA 49 ;
    6C CB 00 ;
    6C CC 00 ;
    6C CD 00 ;
    6C CE 1E ;
    6C CF D6 ;
    6C D0 09 ;
    6C D1 80 ;
    6C D2 A0 ;
    6C D3 20 ;
    6C D4 E0 ;
    6C D5 2D ;
    6C D6 10 ;
    6C D7 10 ;
    6C D8 60 ;
    6C D9 A2 ;
    6C DA 00 ;
    6C DB 81 ;
    6C DC 60 ;
    6C DD 00 ;
    6C DE 08 ;
    6C DF 08 ;
    6C E0 18 ;
    6C E1 8C ;
    6C E2 0A ;
    6C E3 D0 ;
    6C E4 90 ;
    6C E5 20 ;
    6C E6 40 ;
    6C E7 31 ;
    6C E8 20 ;
    6C E9 0C ;
    6C EA 40 ;
    6C EB 55 ;
    6C EC 00 ;
    6C ED 81 ;
    6C EE 60 ;
    6C EF 00 ;
    6C F0 00 ;
    6C F1 00 ;
    6C F2 18 ;
    6C F3 00 ;
    6C F4 00 ;
    6C F5 00 ;
    6C F6 00 ;
    6C F7 00 ;
    6C F8 00 ;
    6C F9 00 ;
    6C FA 00 ;
    6C FB 00 ;
    6C FC 00 ;
    6C FD 00 ;
    6C FE 00 ;
    6C FF 46 ;
    64 71 00 ; Set the Most Significant Bit of the SPA location to 0
    64 52 20 ; Set the SPA for port B
    64 53 00 ; Set the SPA for port B.
    64 70 B9 ; Set the Least Significant Byte of the SPA location
    64 74 03 ; Enable the Internal EDID for ports
    End
    Please refer (+) How can I use ADV7611 with an internal EDID - Q&A - Video - EngineerZone (analog.com)
    Poornima
    I would like to ask a question regarding the answer to Q1 above.
    Is it correct that the Hot Plug Detect (HPD) transition always starts from H,
    HPD=H → HPD=L → HPD=H?
    Best regards.
  • Hi Tatsuya San,
             HPD=H → HPD=L → HPD=H ?
                Yes, the below suggested sequence is given by expert so it should be H -> L -> H
    4)  load up the EDID
    Poornima
    Sorry for asking so many questions.
    Before and after the HDMI device is connected,
    does the HPD sequence look like the following?
    ①Before connecting an HDMI device: HPD = L
    ②After connecting HDMI equipment:
     1) HPD=H
        2) HPD = L
        3) 100ms wait
        4) HPD=H
        In this case, how long should HPD=H be maintained in 1)?
    Best regards.
