Analog Input on ADV7481
Software Version: Linux 5.10.72
We are using ADV7481 connected through MIPI-CSI2 to an NXP i.MX8 MPlus processor..
The ADV chip is confugured to use 2 video pipelines:
1) HDMI input with MIPI-CSI TXA output
2) VGA converted to YPbPr input with MIPI-CSI TXB output.
We managed to properly build linux v4l2 pipelines:
HDMI is working properly, but YPbPr has issue. Image is duplicated several times:
Something seems to be wrong with VGA input resolution. Can you please help us to properly configure ADV7481?
Best Regards,
Bruno
      Please refer the below script for YPrPb input to MIPI-CSI output & crosscheck your register configuration with referred script.
     ":04-01 Analog YPrPb to MIPI TX-B CSI 1-Lane - Autodetect YPrPb In, Ain 1,2,3 - MIPI Out:"
    Poornima
  • Hi Poornima,
    I followed mentioned script 04-01 Analog YPrPb to MIPI TX-B CSI 1-Lane - Autodetect YPrPb In, Ain 1,2,3 - MIPI Out:
    The resulting image posted was taken by using this script.
    I also tried to change several SDP registers to see if I can change the resulting image without success.
    The reading of SDP Status 1, 2 and 3 gives the values St1=0x09, St2=0x10, St3=0x00
    It seems that VSync is OK and HSync not.
    Can you tell me if HSync signal must have a minimum length ?
    Bruno
       Could you please check with scope what does the V & H sync timing look like ?
     Please ensure with below possible problems,
        a) Layout/trace issues with board causing impedance problems
        b) Power supply noise problems especially with Pvdd
        c) Incorrect scripts being used
    Also it seems "INST_HLOCK" doesn't get lock when checking with status registers.
    Kindly note 'INST_HLOCK' is an instantaneous horizontal lock indicator, so it must be based on a line-to-line evaluation of the horizontal synchronization pulse of the incoming video, and is very likely to be faster than the IN_LOCK and LOST_LOCK status bits.
    Poornima
    We made further tests with a pattern generator capable of producing different resolutions directly connected to ADV's YPrPb input.
    1) with PAL output (line length = 64 usec) we have the following correct image:
    2) with VGA-480 60Hz output (line length = 31.7 usec) we have almost doubled image:
    3) with XGA-1024-768 60Hz output (line length = 20.8 usec) we have almost trippled image:
    It seems that ADV 7481 can only capture input with line length 64 usec.
    Is there a way to configure different YPrPb input line length ?
    What is the highest input resolution supported ?
    We also measured HSYNC at ADV's input : The pulse amplitude is -200 mV, duration 4 usec.
    Bruno
        ADV7481 is capable of decoding a large selection of baseband video signals in composite (both single-ended and differential), S-Video, and component formats in SDP core.
       So in SDP core we can processes only PAL,NTSC and SECAM signal types. The Video standards supported by the SDP include PAL , PAL 60 , PAL M, PAL N, PAL NC, NTSC M/J, NTSC 4.43, and SECAM.
     Could you please check the VGA and XGA formats in HDMI interface and let us know the result.
    Poornima
