What is the difference between "ADV7610BBCZ-P" and "ADV7610BBCZ"
Category: Datasheet/Specs
Product Number: ADV7610
I am currently using "ADV7610BBCZ-P" and am considering switching to "ADV7610BBCZ".
If the HDCP function is not used after changing to "ADV7610BBCZ", is it necessary to change the register settings?
        No, Register settings are not required if you are changing from Non-keyed part (ADV7610BBCZ-P) to Keyed part (ADV7610BBCZ) .
        For example If the source transmits the unencrypted data then the device can able to display the video (i.e When source outputs Un-protected video the ADV7610 part will work just fine, either in HDMI or DVI).
        But if you are changing from keyed part (ADV7610BBCZ) to non-keyed part (ADV7610BBCZ-P), Here you will get a snow video for encrypted content (i.e source transmits protected content,  ADV7610BBCZ-P will not have any valid keys to decrypt the video, then it will output 'snow' ).
    Poornima
