ADV7391 last pixel of each line is black
Product Number: ADV7391
I am using the ADV7391 in monochrome NTSC 640X480 NTSC SD square pixel (YCrCb) mode.
I program the part with I2C conf (Table 79) via a n FPGA:
0x17
0x02
0x00
0x1C
0x01
0x00
0x80
0x10
0x82
0xDB
0x8C
0x55
0x8D
0x55
0x8E
0x55
0x8F
0x25
Clkin = 24.540 MHz.
The pixel 640 of each line is black ( I have a black column on the right of my image). I do not understand why.
Thanks a lot for your help.
HHL
      ADV739x can support RS-170 NTSC Video output successfully. Try setting the 'SD Burst and SD Chroma' =1 to disable the burst. Since it is an NTSC without color.
    The reason for black column on the right of the image might be depend upon the receiver system whether it is ITU-R BT.656-3 or ITU-R BT.656-4. If the receiver system is expecting an ITU-R BT.656-4 output from the ADV739x, then this can result in 10 lines of black video being output at the Top/Side of the screen.
    This generally occurs with NTSC CVBS video inputs but not with PAL CVBS inputs. This is because of difference in the blanking timing between the ITU-R BT.656-3 and ITU-R BT.656-4 standards for digitized NTSC.
    Poornima
