I need the DVP Eval Latest Source software 10-14-11. Can someone tell me where to download it from?
Thanks Daniel
Thanks Daniel
Please note that when you order EVAL-ADV7282-M eval board, you would receive a piece of paper explaining about how to log in to our FTP site and downloading the register control software for this board.
Thank you very much, but now the EVAL-ADV7280A device is not recognized
Greetings Daniel ...
Please make sure with below things,
Copy the folder called 'ADV7280_CUST' to the location :
C:\Users\USER_NAME\Documents\Analog Devices\DVP Eval Latest Source 10-14-11\xml\New Boards\
If you place the folder in any other location then the DVP Eval Latest source will not detect the new board files.
Example - Do not place the 'ADV7280_CUST' folder in the location:
C:\Users\rhinchy\Documents\Analog Devices\DVP Eval Latest Source 10-14-11\xml\New Boards\Recent Boards Added
Could you please check that the 'ADV7280_Cust' folder downloaded correctly from the FTP site. The 'ADV7280_Cust' folder should contain:
ADV7280_Cust.xml
ADV7391.xml
board_info.txt
A folder called 'Scripts'. The 'Scripts' folder contains a text file called ADV7280_CUST-VER.4.4.txt
Also please refer here https://ez.analog.com/video/f/q-a/9272/adv7281-m-evb-usb-driver/7471#7471
https://ez.analog.com/video/f/q-a/8031/eval-adv7280ebz/12798
Poornima
ADV7280_Cust.xml
ADV7391.xml
board_info.txt
Poornima
Thank you very much now give me those errors.
Greetings Daniel ..
Please try below sequence and let us know,
a. Power up the chip as normal
b. With a jumper wire or probe, pull the reset pin low to get a good solid hardware reset after power up.
c.Try I2C transaction again.
Poornima
Everything is working now. Thank you.
Daniel
Glad to hear this!
Poornima
