ADV7619 chip not transfer
Hello I make custom Board and use ADV7619 HDMI Rx chip
Now EDID OK.
Because Moninfo detect Board
But
Chip Output Pin (P[0] ~ P[48], Vsync, Hsycn, DE)
why not trasnfer???
I set freerun mode , then  data, vsync, hsync, DE pin swing
I thank internal pattern generation,
I want to take TMDS.
Our system
PC -> CustomBoard(ADV7619)
Please your Script ...
Parents
    on Aug 19, 2021 11:25 AM
    Hi
          Please use this script 2047.ADV7619-VER.1.9c.zip based upon your input resolution.
          Register configuration related manuals are available at https://ez.analog.com/video/w/documents/773/adv7619-design-support-files
    Poornima
  • I test your scrip below.........
    that is not operation
    did you test your script???
    because my script
    1. windows detect OK
    2. TMDS transfer OK at HDMI cable
    3. ADV7611 not trasnfer data signals.
    bur your script
    1. windows detect NO
    2. TMDS transfer NO at HDMI cable
    why your script windows not detect???
    your script doc write????
    ##02 HDMI Input to ADV7619, Input Pixel Frequency <= 170MHz ##
    :02-01 480i,576i,480p,576p In - 24-bit RGB 444 Out:
    98 FF 80 ; I2C reset
    98 F4 80 ; CEC
    98 F5 7C ; INFOFRAME
    98 F8 4C ; DPLL
    98 F9 64 ; KSV
    98 FA 6C ; EDID
    98 FB 68 ; HDMI
    98 FD 44 ; CP
    68 C0 03 ; ADI Required Write
    98 01 06 ; Prim_Mode =110b HDMI-GR
    98 02 F7 ; Auto CSC, RGB out, Set op_656 bit
    98 03 40 ; 24 bit SDR 444 Mode 0
    98 05 28 ; AV Codes Off
    98 06 A0 ; No inversion on VS,HS pins
    98 0C 42 ; Power up part
    98 15 80 ; Disable Tristate of Pins
    98 19 83 ; LLC DLL phase
    98 33 40 ; LLC DLL MUX enable
    44 BA 01 ; Set HDMI FreeRun
    44 6C 00 ; Required ADI write
    64 40 81 ; Disable HDCP 1.1 features
    4C B5 01 ; Setting MCLK to 256Fs
    68 C0 03 ; ADI Required write
    68 00 08 ; Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
    68 02 03 ; ALL BG Ports enabled
    68 03 98 ; ADI Required Write
    68 10 A5 ; ADI Required Write
    68 1B 08 ; ADI Required Write
    68 45 04 ; ADI Required Write
    68 97 C0 ; ADI Required Write
    68 3D 10 ; ADI Required Write
    68 3E 69 ; ADI Required Write
    68 3F 46 ; ADI Required Write
    68 4E FE ; ADI Required Write
    68 4F 08 ; ADI Required Write
    68 50 00 ; ADI Required Write
    68 57 A3 ; ADI Required Write
    68 58 07 ; ADI Required Write
    68 6F 08 ; ADI Required Write
    68 83 FC ; Enable clock terminators for port A & B
    68 84 03 ; ADI Required Write
    68 85 11 ; ADI Required Write
    68 86 9B ; ADI Required Write
    68 89 03 ; ADI Required Write
    68 9B 03 ; ADI Required Write
    68 93 03 ; ADI Required Write
    68 5A 80 ; ADI Required Write
    68 9C 80 ; ADI Required Write
    68 9C C0 ; ADI Required Write
    68 9C 00 ; ADI Required Write
    72 01 00 ; Set N Value(6144)
    72 02 18 ; Set N Value(6144)
    72 03 00 ; Set N Value(6144)
    72 15 00 ; Input 444 (RGB or YCrCb) with Separate Syncs, 44.1kHz fs
    72 16 61 ; YCrCb 444
    72 18 46 ; CSC disabled
    72 3B 80 ; PR Auto Mode
    72 40 80 ; General Control Packet Enable
    72 41 10 ; Power Down control
    72 48 08 ; Data right justified
    72 49 A8 ; Set Dither_mode - 12-to-10 bit
    72 4C 04 ; 8 bit Output
    72 55 00 ; Set RGB 444 in AVinfo Frame
    72 56 08 ; Set active format Aspect
    72 96 20 ; HPD Interrupt clear
    72 98 03 ; ADI Required Write
    72 99 02 ; ADI Required Write
    72 9C 30 ; PLL Filter R1 Value
    72 9D 61 ; Set clock divide
    72 A2 A4 ; ADI Required Write
    72 A3 A4 ; ADI Required Write
    72 AF 16 ; Set HDMI Mode
    72 BA 60 ; No clock delay
    72 DE 9C ; ADI Required Write
    72 E4 60 ; VCO Swing Reference Voltage
    72 FA 7D ; Nbr of times to search for good phase
    End
    on Aug 20, 2021 5:06 PM in reply to tony1
     You might have not written the EDID with respect to map address 0x6C, These writes are available in the 1817.ADV7611-VER.3.0c.txt.zip
    Please note PC generally do not work unless they see a valid EDID &  PC will only recognize a sink only when they detect an valid EDID .
    Refer below thread for EDID initialization script,
    https://ez.analog.com/message/31879#31879
    Instead of PC as an source could you please check with other sources like generator and let us know the result.
    Please make sure the crystal pins are oscillating at the right  frequency (i.e 28.6363 MHZ) ?
    Also make sure with below HDMI frontend locking status registers to check whether input device is correctly recognized.
              a) Registers HDMI 0x04, 0x07, 0x1B, 0xE0
              b) Registers IO 0x6A, 0x6B
              c) And also signals on the VS, HS and DE pins.
    Poornima
Reply
    Poornima
Children
No Data
