ADV7513 1080p60 output
Hello
We have a request regarding HDMI product ADV7513.
The engineer is evaluating this chip on their own PCB.
He is going to use it as an HDMI converter however he cannot achieve the required result.
Their mode:
Input: 1080p25 4:2:2 YCrCb 8bit embeded sync
Output: They need 1080p60.
Is it possible to implement?
They just have at the output 1080p25. May be they have some errors in the coding? Please find it attached
        auto temp = readReg( 0x41 );
			 // temp |= 1<<1;// генерация SYNC adjust enable
		temp &= ~(1<<6);
        writeReg( 0x41, temp );
    writeReg( 0x48, 0x00);
	writeReg( 0x49, 0xa8);
	writeReg( 0x4c, 0x00);
//    // fixed registers that must be set on power up
	writeReg( 0x96, 0xa4);
    writeReg( 0x98, 0x03);
	writeReg( 0x99, 0x02);
    writeReg( 0x9a, 0xe0 );
    writeReg( 0x9C, 0x30 );
    writeReg( 0x9d, 0x61 );//0x61
    writeReg( 0xA2, 0xA4 );
    writeReg( 0xA3, 0xA4 );
    writeReg( 0xA5, 0x04 );
	writeReg( 0xAB, 0x40 );
	writeReg( 0xba, 0x60 );
    writeReg( 0xbb, 0x00 );
	writeReg( 0xd1, 0xff );
	writeReg( 0xdc, 0x00 );
	writeReg( 0xdd, 0x00 );
	writeReg( 0xde, 0xd8 );//0xd8
	writeReg( 0xdf, 0x01 );
	writeReg( 0xe0, 0xd0 );
	writeReg( 0xE4, 0x60 );
	writeReg( 0xf9, 0x00 );
	writeReg( 0xfa, 0x00 );
	writeReg( 0xfd, 0xe0 );
    writeReg( 0xfe, 0x80 );
        auto temp = readReg( 0xe2 );
		temp |=  1<<1; //CEC  enable ??
        writeReg( 0xe2, temp );
        auto temp = readReg( 0xd0 );
		temp &=  ~(1<<1); //генерация синхросигнала DE
		temp |=  1<<1; //генерация синхросигнала DE
        temp |=  3<<2; //
		temp &= ~(0xf<<4);
		temp |=  0x0f<<4; //invert clock
        writeReg( 0xd0, temp );
        auto temp = readReg( 0xd6 );
		temp |=  1<<4; //TMDS CLK Soft Turn On
       // temp |=  1<<0; //gated clock
        writeReg( 0xd6, temp );
        auto temp = readReg( 0x15 );
        temp &= ~0xF;
        temp |= 0x04;
        writeReg( 0x15, temp );
	  // ставим 8 бит
        auto temp = readReg( 0x16 );
		temp &= ~(3<<2);//style 2
		temp |=  1<<2;//style 2
		temp &= ~(3<<4);
        temp |= 3<<4;//Color Depth for Input Video Data 8 bit
		temp &=  ~(1<<0);//0 = RGB 1 = YCbCr
		temp |=  1<<0;//0 = RGB 1 = YCbCr
		 writeReg( 0x16, temp );
	/*********embeded sync*************************/
        auto temp = readReg( 0xfb );
		temp &= ~(3<<1);
		temp |= 1<<2; //Low Refresh Rate 25Hz
		writeReg( 0xfb, temp );
	writeReg( 0x30, 0x84);
	writeReg( 0x31, 0x02);
	writeReg( 0x32, 0xc0);
	writeReg( 0x33, 0x10);//1080p-50/60
	writeReg( 0x34, 0x05 );
	writeReg( 0x35, 0x2f );
	writeReg( 0x36, 0xe9 );
	writeReg( 0x37, 0x0f );
	writeReg( 0x38, 0x00 );
	writeReg( 0x39, 0x43 );
	writeReg( 0x3a, 0x80 );
	writeReg( 0xd7, 0x84 );
	writeReg( 0xd8, 0x02 );
	writeReg( 0xd9, 0xc0 );
	writeReg( 0xda, 0x10);//1080p-50/60
	writeReg( 0xdb, 0x05 );//
        auto temp = readReg( 0x17 );
        temp &= ~(3<<5);// sync polarity
			 // temp |= 1<<6;// sync polarity
		temp &= ~(1<<2);
		temp |= 1<<0; // DE embeded sync
		temp |= 1<<1; //aspect ratio 16:9
        writeReg( 0x17, temp); //temp  BVA!!
		temp &= ~(1<<7);//4:4:4 output|
    writeReg( 0x40, 0x80 );
        auto temp = readReg(0x18);
	    temp |= 1<<7;//csc enable
        temp &= ~(3<<5);
			  //temp |= 1<<5;
        writeReg( 0x18, temp );
        auto temp = readReg( 0xAF );
        temp &= ~(1<<1);//DVI b0 HDMI b1
  		temp |= 1<<1;//DVI b0 HDMI b1
        writeReg( 0xAF, temp );
	/**********CSC coefficients********************/
	writeReg( 0x18, 0xe7 );
    writeReg( 0x19, 0x34 );
    writeReg( 0x1a, 0x04 );
    writeReg( 0x1b, 0xad );
    writeReg( 0x1c, 0x00 );
	writeReg( 0x1d, 0x00 );
    writeReg( 0x1e, 0x1c );
    writeReg( 0x1f, 0x1b );
    writeReg( 0x20, 0x1d );
	writeReg( 0x21, 0xdc );
	writeReg( 0x22, 0x04 );
	writeReg( 0x23, 0xad );
	writeReg( 0x24, 0x1f );
	writeReg( 0x25, 0x24 );
	writeReg( 0x26, 0x01 );
	writeReg( 0x27, 0x35 );
	writeReg( 0x28, 0x00 );
	writeReg( 0x29, 0x00 );
	writeReg( 0x2a, 0x04 );
	writeReg( 0x2b, 0xad );
	writeReg( 0x2c, 0x08 );
	writeReg( 0x2d, 0x7c );
	writeReg( 0x2e, 0x1b );
	writeReg( 0x2f, 0x77 );
	// Audio init
    writeReg( 0x01, 0x00 );
    writeReg( 0x02, 0x18 );
	writeReg( 0x03, 0x00 );
        auto temp = readReg( 0x0a );
        temp &= ~(7<<4);
        writeReg( 0x0a, temp );
        auto temp = readReg( 0x0b );
        temp &= ~(1<<7);//SPDIF disable
        writeReg( 0x0b, temp );
        auto temp = readReg( 0x0c );
        temp &= ~(0x0f<<2);
		temp |= 0x0f<<2;//enable I2S
        writeReg( 0x0c, temp );
		temp &= ~(0x0f<<4);
        temp |= 1<<5;
        writeReg( 0x015, temp );
        temp &= ~(3<<2);
		temp |= 3<<2;
/************HDCP INIT**************/
//        auto temp = readReg( 0xAF );
//			  temp |= 1<<4;
//        temp |= 1<<7;
//        writeReg( 0xAF, temp );
///***** ожидание старта HDCP******/
//		{ auto temp = readReg( 0x97 );
//			  temp &= 0x40;
//			  while (temp==0)
//					temp = readReg( 0x97 );
//				  temp &= 0x40;
//			  temp |= 1<<6;
//        writeReg( 0x97, temp );
//        auto temp = readReg( 0xc8 );
//			  temp &= 0x04;
//			  while (temp==0)
//				  temp = readReg( 0xc8 );
//					temp &= 0x04;
	/********** AVIInfoFrame***********/
        auto temp = readReg( 0x4a );
		temp &= ~(7<<5);
		temp |= 3<<5; //1 = Use automatically generated checksum  1 = AVI Packet I2C update active 1 = Audio InfoFrame Packet I2C update active
		writeReg( 0x4a, temp );
        auto temp = readReg( 0x52 );
		temp &= ~(7<<0);
		temp |= 0x02<<0; //version of InfoFrame
		writeReg( 0x52, temp );
        auto temp = readReg( 0x53 );
		temp &= ~(0x0f<<0);
		temp |= 0x0d<<0; //length of InfoFrame
		writeReg( 0x53, temp );
		/*****Like in AD source**********/
		auto temp = readReg( 0x3b );//pixel repeat mode 0x3B[6:5] to 0b10 or 0b11.
		temp &=  ~(3<<5); // auto mode
			//temp |=  1<<6; // manual mode
			//  temp |=  1<<5; // max mode
		writeReg( 0x3b, temp );
		temp &=  ~(3<<1); // pixel repetition
		temp |=  1<<1;    // pixel repetition
//			  temp &=  ~(3<<3); // input freq mult
//			  temp |=  1<<3;    // input freq mult
        auto temp = readReg(0x3c);//
		temp &=  ~(0x3f<<0); //
		temp |=  0x10<<0; // //1080p-60
			 // temp |=  0x1f<<0; // //1080p-50
			 // temp |=  0x22<<0; // //1080p-30
			 // temp |=  0x4<<0; // //1080p-25
		writeReg(0x3d,temp);
        auto temp = readReg( 0x55 );
		temp &= ~(3<<5);//RGB
		temp |= 1<<6; //YCrCb 4:4:4
		writeReg( 0x55, temp );
        auto temp = readReg( 0x56 );
		temp &= ~(3<<4);//aspect ratio
		temp |= 1<<5; //aspect ratio 16:9
		temp &= ~(0x0f<<0);//
		temp |= 1<<3;////aspect ratio 16:9
		writeReg( 0x56, temp );
    time_service::delay_ms(20);
Regards
Evgeny
      ADV7511 is just an HDMI transmitter. It has no memory and can't do any frame rate conversion but ADV8005 can do frame rate conversion as well scaling(720 --> 1080).
      Please note that ADV7511/ADV7513, the resolution that comes in is the resolution that goes out. The device does not have the ability to modify the resolution or the frame rate.
    Poornima
  • Hello Poornima,
    Thanks for your reply.
    There is still another additional question:
    How to understand the purpose of register 0x3C?
       User programmed VIC to sent to Rx (value defined in CEA861D)?
    Evgeny
      By using registers 0x3B, 0x3C and 0x3D you can manually configure the ADV7513 to use x2 pixel repetition and also set the VIC code manually.
      For more details please refer at  ADV7511W Programming Guide & here search the above corresponding registers.
    Poornima
  • Hello Poornima,
    I have one more question.
    Working mode of ADV7513:
    Input: 1080p30 4: 2: 2 YCrCb 8bit embeded sync
    Output: 1080p30 DVI mode displayed on one of the monitors well.
    1080p30 HDMI mode is displayed on the same monitor, but with periodic loss of sync.
    On other monitors, they write that they are synchronized in 1080p30 mode, but the video is not displayed.
    How it can be fixed?
    Evgeny
    		temp &= ~(1<<6);
            temp |=  3<<2; //
    		temp &= ~(0xf<<4);
            temp &= ~0xF;
            temp |= 0x04;
    	  // ставим 8 бит
    		temp &= ~(3<<4);
    		temp &= ~(3<<1);
    		temp &= ~(1<<2);
            temp &= ~(3<<5);
    			  //temp |= 1<<5;
    	// Audio init
            temp &= ~(7<<4);
            temp &= ~(0x0f<<2);
    		temp &= ~(0x0f<<4);
            temp |= 1<<5;
            temp &= ~(3<<2);
    		temp |= 3<<2;
    //			  temp |= 1<<4;
    //        temp |= 1<<7;
    //			  temp &= 0x40;
    //			  while (temp==0)
    //				  temp &= 0x40;
    //			  temp |= 1<<6;
    //			  temp &= 0x04;
    //			  while (temp==0)
    //					temp &= 0x04;
    		temp &= ~(7<<5);
    		temp &= ~(7<<0);
    		temp &= ~(0x0f<<0);
      Some of your configuration seems different from the reference one, Could you please crosscheck your configuration with attached one 2047.ADV7619-VER.1.9c.zip
     72 writes corresponds to ADV7511.
    Poornima
