[ADV8005]Simultaneous output of SD encoder Y/C and RGB
Currently, on my board, DAC1 to DAC6 of the ADV8005 are configured as follows.
I use only the SD encoder, not the ED/HD encoder.
DAC1: Y
DAC2: C
DAC3: Y
DAC4: C
DAC5: none
DAC6: none
I would like to change it as follows. Is it possible for the SD encoder output simultaneous Y/C and RGB?
If possible, please tell me which register should be set.
DAC1: Y
DAC2: C
DAC3: none
DAC4: G
DAC5: B
DAC6: R
Thank you.
Parents Reply
      Yes,  ED/HD output standard support only the formats that are mentioned in the 0xE430 register.
      Note: ADV8005 includes a high-speed digital-to-analog video encoder. Its a 12-bit video DACs provide support for composite (CVBS), S-video (Y/C) and component (YPrPb/RGB) analog outputs in either SD, ED, or HD video formats video formats up to 1080p.
    Poornima
Children
No Data
