adv7611 can't sync 1080p
Hi
I'm working with adv7611 (FMC-HDMI from DIGILENT).
My simple test system is like below.
(labtop) - adv7611 HDMI in - FPGA video processing - VGA out - (monitor)
I have configured adv7611 with ADV7611-VER.3.0c.txt from https://ez.analog.com/video/w/documents/789/adv7611-design-support-files.
labtop find a second display device and display well at 480p, 720p but 1080p is not.
When I change the resolution to 1080p and then, the display has some wrong screen aspect ratio.
What should I do now?
7211 was typo. Fix 7611 now.
[edited by: jhlee12 at 7:42 AM (GMT -4) on 12 Jun 2021]
      We don't find find any ADV7211 part in our video forum, If we have the specification for that part then only we can suggest why this part is not supporting for 1080p video format.
    Poornima
  • I'm so sorry. There was typo. It is adv7611.
      Please let us know which source you are using for 1080p input.
      Also refer the attached script for configuring the 1080p input 1817.ADV7611-VER.3.0c.txt.zip and ignore the writes to address 72 which corresponds to ADV7511.
    Poornima
  • I configured ADV7611 using the below code and EDID also.
    Actually, I have 2 sources in my system. One is FPGA Testpattern source that throughout ADV7511 HDMI output and the other one is my laptop.  Testpattern source is working at 1080p very well but my laptop source doesn't very well 1080p.  The laptop can recognize the device and display resolution recommend 720x480 and also display well. When I have changed the resolution 1280x720 is also displaying well. But how come at 1080 resolution, the display aspect ratio is weird. Why did this happen? Because EDID setting is not preferred for 1080p?  I think this is just EDID problem because my test pattern is working well. Am I wrong? What can I miss any problem possibility? Please give me any advice.
    :6-1f Port A, 1080p Any Color Space In (YCrCb 444 24bit from ADV761x) Through HDMI Out 444 YCrCb VIC[16,31,32]:
    98 FF 80 ; I2C reset
    98 F4 80 ; CEC
    98 F5 7C ; INFOFRAME
    98 F8 4C ; DPLL
    98 F9 64 ; KSV
    98 FA 6C ; EDID
    98 FB 68 ; HDMI
    98 FD 44 ; CP
    98 01 06 ; Prim_Mode =110b HDMI-GR
    98 02 F5 ; Auto CSC, YCrCb out, Set op_656 bit
    98 03 40 ; 24 bit SDR 444 Mode 0
    98 05 28 ; AV Codes Off
    98 06 A6 ; Invert VS,HS pins
    98 0B 44 ; Power up part
    98 0C 42 ; Power up part
    98 14 7F ; Max Drive Strength
    98 15 80 ; Disable Tristate of Pins
    98 19 83 ; LLC DLL phase
    98 33 40 ; LLC DLL enable
    44 BA 01 ; Set HDMI FreeRun
    64 40 81 ; Disable HDCP 1.1 features
    68 9B 03 ; ADI recommended setting
    68 C1 01 ; ADI recommended setting
    68 C2 01 ; ADI recommended setting
    68 C3 01 ; ADI recommended setting
    68 C4 01 ; ADI recommended setting
    68 C5 01 ; ADI recommended setting
    68 C6 01 ; ADI recommended setting
    68 C7 01 ; ADI recommended setting
    68 C8 01 ; ADI recommended setting
    68 C9 01 ; ADI recommended setting
    68 CA 01 ; ADI recommended setting
    68 CB 01 ; ADI recommended setting
    68 CC 01 ; ADI recommended setting
    68 00 00 ; Set HDMI Input Port A
    68 83 FE ; Enable clock terminator for port A
    68 6F 0C ; ADI recommended setting
    68 85 1F ; ADI recommended setting
    68 87 70 ; ADI recommended setting
    68 8D 04 ; LFG
    68 8E 1E ; HFG
    68 1A 8A ; unmute audio
    68 57 DA ; ADI recommended setting
    68 58 01 ; ADI recommended setting
    68 03 98 ; DIS_I2C_ZERO_COMPR
    68 75 10 ; DDC drive strength
    ## EDID ##
    :ADV7611 EDID 8 bit only NO DSD or HBR Support:
    64 77 00 ; Disable the Internal EDID
    6C 00 00 ;
    6C 01 FF ;
    6C 02 FF ;
    6C 03 FF ;
    6C 04 FF ;
    6C 05 FF ;
    6C 06 FF ;
    6C 07 00 ;
    6C 08 06 ;
    6C 09 8F ;
    6C 0A 07 ;
    6C 0B 11 ;
    6C 0C 01 ;
    6C 0D 00 ;
    6C 0E 00 ;
    6C 0F 00 ;
    6C 10 17 ;
    6C 11 11 ;
    6C 12 01 ;
    6C 13 03 ;
    6C 14 80 ;
    6C 15 0C ;
    6C 16 09 ;
    6C 17 78 ;
    6C 18 0A ;
    6C 19 1E ;
    6C 1A AC ;
    6C 1B 98 ;
    6C 1C 59 ;
    6C 1D 56 ;
    6C 1E 85 ;
    6C 1F 28 ;
    6C 20 29 ;
    6C 21 52 ;
    6C 22 57 ;
    6C 23 00 ;
    6C 24 00 ;
    6C 25 00 ;
    6C 26 01 ;
    6C 27 01 ;
    6C 28 01 ;
    6C 29 01 ;
    6C 2A 01 ;
    6C 2B 01 ;
    6C 2C 01 ;
    6C 2D 01 ;
    6C 2E 01 ;
    6C 2F 01 ;
    6C 30 01 ;
    6C 31 01 ;
    6C 32 01 ;
    6C 33 01 ;
    6C 34 01 ;
    6C 35 01 ;
    6C 36 8C ;
    6C 37 0A ;
    6C 38 D0 ;
    6C 39 8A ;
    6C 3A 20 ;
    6C 3B E0 ;
    6C 3C 2D ;
    6C 3D 10 ;
    6C 3E 10 ;
    6C 3F 3E ;
    6C 40 96 ;
    6C 41 00 ;
    6C 42 81 ;
    6C 43 60 ;
    6C 44 00 ;
    6C 45 00 ;
    6C 46 00 ;
    6C 47 18 ;
    6C 48 01 ;
    6C 49 1D ;
    6C 4A 80 ;
    6C 4B 18 ;
    6C 4C 71 ;
    6C 4D 1C ;
    6C 4E 16 ;
    6C 4F 20 ;
    6C 50 58 ;
    6C 51 2C ;
    6C 52 25 ;
    6C 53 00 ;
    6C 54 81 ;
    6C 55 49 ;
    6C 56 00 ;
    6C 57 00 ;
    6C 58 00 ;
    6C 59 9E ;
    6C 5A 00 ;
    6C 5B 00 ;
    6C 5C 00 ;
    6C 5D FC ;
    6C 5E 00 ;
    6C 5F 56 ;
    6C 60 41 ;
    6C 61 2D ;
    6C 62 31 ;
    6C 63 38 ;
    6C 64 30 ;
    6C 65 39 ;
    6C 66 41 ;
    6C 67 0A ;
    6C 68 20 ;
    6C 69 20 ;
    6C 6A 20 ;
    6C 6B 20 ;
    6C 6C 00 ;
    6C 6D 00 ;
    6C 6E 00 ;
    6C 6F FD ;
    6C 70 00 ;
    6C 71 17 ;
    6C 72 3D ;
    6C 73 0D ;
    6C 74 2E ;
    6C 75 11 ;
    6C 76 00 ;
    6C 77 0A ;
    6C 78 20 ;
    6C 79 20 ;
    6C 7A 20 ;
    6C 7B 20 ;
    6C 7C 20 ;
    6C 7D 20 ;
    6C 7E 01 ;
    6C 7F 1C ;
    6C 80 02 ;
    6C 81 03 ;
    6C 82 34 ;
    6C 83 71 ;
    6C 84 4D ;
    6C 85 82 ;
    6C 86 05 ;
    6C 87 04 ;
    6C 88 01 ;
    6C 89 10 ;
    6C 8A 11 ;
    6C 8B 14 ;
    6C 8C 13 ;
    6C 8D 1F ;
    6C 8E 06 ;
    6C 8F 15 ;
    6C 90 03 ;
    6C 91 12 ;
    6C 92 35 ;
    6C 93 0F ;
    6C 94 7F ;
    6C 95 07 ;
    6C 96 17 ;
    6C 97 1F ;
    6C 98 38 ;
    6C 99 1F ;
    6C 9A 07 ;
    6C 9B 30 ;
    6C 9C 2F ;
    6C 9D 07 ;
    6C 9E 72 ;
    6C 9F 3F ;
    6C A0 7F ;
    6C A1 72 ;
    6C A2 57 ;
    6C A3 7F ;
    6C A4 00 ;
    6C A5 37 ;
    6C A6 7F ;
    6C A7 72 ;
    6C A8 83 ;
    6C A9 4F ;
    6C AA 00 ;
    6C AB 00 ;
    6C AC 67 ;
    6C AD 03 ;
    6C AE 0C ;
    6C AF 00 ;
    6C B0 10 ;
    6C B1 00 ;
    6C B2 88 ;
    6C B3 2D ;
    6C B4 00 ;
    6C B5 00 ;
    6C B6 00 ;
    6C B7 FF ;
    6C B8 00 ;
    6C B9 0A ;
    6C BA 20 ;
    6C BB 20 ;
    6C BC 20 ;
    6C BD 20 ;
    6C BE 20 ;
    6C BF 20 ;
    6C C0 20 ;
    6C C1 20 ;
    6C C2 20 ;
    6C C3 20 ;
    6C C4 20 ;
    6C C5 20 ;
    6C C6 00 ;
    6C C7 00 ;
    6C C8 00 ;
    6C C9 FF ;
    6C CA 00 ;
    6C CB 0A ;
    6C CC 20 ;
    6C CD 20 ;
    6C CE 20 ;
    6C CF 20 ;
    6C D0 20 ;
    6C D1 20 ;
    6C D2 20 ;
    6C D3 20 ;
    6C D4 20 ;
    6C D5 20 ;
    6C D6 20 ;
    6C D7 20 ;
    6C D8 00 ;
    6C D9 00 ;
    6C DA 00 ;
    6C DB FF ;
    6C DC 00 ;
    6C DD 0A ;
    6C DE 20 ;
    6C DF 20 ;
    6C E0 20 ;
    6C E1 20 ;
    6C E2 20 ;
    6C E3 20 ;
    6C E4 20 ;
    6C E5 20 ;
    6C E6 20 ;
    6C E7 20 ;
    6C E8 20 ;
    6C E9 20 ;
    6C EA 00 ;
    6C EB 00 ;
    6C EC 00 ;
    6C ED 00 ;
    6C EE 00 ;
    6C EF 00 ;
    6C F0 00 ;
    6C F1 00 ;
    6C F2 00 ;
    6C F3 00 ;
    6C F4 00 ;
    6C F5 00 ;
    6C F6 00 ;
    6C F7 00 ;
    6C F8 00 ;
    6C F9 00 ;
    6C FA 00 ;
    6C FB 00 ;
    6C FC 00 ;
    6C FD 00 ;
    6C FE 00 ;
    6C FF DA ;
    64 77 00 ; Set the Most Significant Bit of the SPA location to 0
    64 52 20 ; Set the SPA for port B.
    64 53 00 ; Set the SPA for port B.
    64 70 9E ; Set the Least Significant Byte of the SPA location
    64 74 03 ; Enable the Internal EDID for Ports
     If your laptop supports 720 and 480 then it should work for 1080p, the above EDID can support 1080p as well.
     Can you please check with other laptops as well as any other source like player and let us know.
    Source may not transmit unless they have a valid EDID to work with So Please refer below thread for configuring the internal EDID,
     https://ez.analog.com/video/f/q-a/11866/how-can-i-use-adv7611-with-an-internal-edid
    Poornima
