ADV7123 -> ADV7182 loop back
The user is experiencing an issue where the ADV7182 detects interlaced PAL video only when looped back from the ADV7393 but not from the ADV7123. The final answer indicates this is a duplicate of another thread and advises against creating duplicate threads for tracking purposes. The status register 0x10 shows PAL B/G/H/I/D in both cases, but 0x13 indicates interlaced video detection in Case 1 and not in Case 2.
Hi all,
I am using ADV7393, ADV7123, ADV7182 in the following manner
Case 1: ADV7393 -> ADV7182 loop back
Giving PAL interlaced format to AD7393 which analog output is loopbacked to ADV7182 analog input
Reading status registers of ADV7182
0x10 = 0x48 (AD_RESULT[2:0] always PAL B/PAL G/PAL H/PAL I/PAL D)
0x13 = 0x4C (bit[6]: '1' -> interlaced video detected, bit[4]: '0' -> free run mode inactive, bit[2]: '1' -> SD_OP_50Hz bit always 1)
Case 2: ADV7123 -> ADV7182 loop back
Giving PAL interlaced format to AD7123 which analog output is loopbacked to ADV7182 analog input
0x10 = 0xC9 (AD_RESULT[2:0] always PAL B/PAL G/PAL H/PAL I/PAL D)
0x13 = 0x0D (bit[6]: '0' -> interlaced video not detected, bit[4]: '0' -> free run mode inactive, bit[2]: '1' -> SD_OP_50Hz bit always 1)
NOTE: Giving PAL interlaced video in both cases and reading ADV7182 status register post loopback.it is giving interlace video detected only in case 1 and interlace video not detected in case 2 but it should detect in both cases.
Can anyone will help on this issue??
