I have a question about packet format (sequence) of MIPI Transmission of ADV7480.
I summarized the question to attached file "ADV7480_MIPI_Transmission_format_sequence.xlsx".
Please refer it.
Thank you!
Best regards.
Tamu
ADV7480
Production
The ADV7480 is a combined HDMI®/MHL® receiver targeted at
connectivity enabled head units requiring a wired, uncompressed
digital audio/video link from...
Datasheet
ADV7480 on Analog.com
Please refer it.
Thank you!
Best regards.
Tamu
Hi Tamu-San,
Does ADV7480 output "UYVY" packet sequence (format) as MIPI Transmission ?
Yes, If it is an 8 bit Cb/Y/Cr/Y[7:0] is equivalent to UYVY in YUV sequence (i.e Cb - U,Cr - V, Y- Y).
Also by using below register, You can swap from UYVY to VYUY
Register -0x27 SWPC -This control is used to swap Cr and Cb samples of the SDP block only.(0 = No swapping ,1 = Swap Cr and Cb values)
Register, 0x3E CP_UV_DVAL_INV- This control is used to swap the order of the Cr and Cb in the chroma stream for 4:2:2 output modes.(0 = Do not swap order of Cr and Cb samples ,1 = Swap order of Cr and Cb samples).
Note: Y U V - Y Cb Cr, U Y V Y -Cb Y Cr Y, V Y U Y- Cr Y Cb Y.
Poornima.S
Thank you !
