I config 640*480 resolution VGA input to get RGB888 TTL output , regisiter list as blow,in black pattern ,R/G/B channel 0 is a hsync waveform.
could you give me a answer ,Tks!
42 03 14 0042 05 02 0042 06 08 0042 1D 40 00//Vertical Scale Value 142 6a 40 00//42 3a 01 00//Powerdown ADC342 3c 59 00//5C42 67 01 00//01 Force RGB (Range 0-255) input42 68 f2 00//RGB Output/CSC configuration in automaticmode42 69 00 0042 6B ee 0042 7b 0c 00//AV Code42 7c 00 00//polarity+42 85 03 0042 86 0b 0042 87 63 0042 88 5a 00//PLL_DIV_RATIO42 8a 10 0042 c9 04 0042 f4 3f 0042 b5 01 ff
Could you please crosscheck your configuration with reference script under ##GR VGA 640x480## at 4682.ADV7441A_Evaluation_Board_Documents.zip
Also refer PLL recommended settings for GR Modes in ADV7441A…
I have already check the setting"##GR VGA 640x480## at 4682.ADV7441A_Evaluation_Board_Documents.zip",There is none similar input format and output format, like VGA input 640*480P60Hz/1280*720P60Hz…
Also refer PLL recommended settings for GR Modes in ADV7441A hardware manuals.
Note: Normally HS timing is based on a pixel clock count, VS, DE and FIELD are based on the HS counts. FIELD and DE existence are based on the format, FIELD delineates the odd and even fields of a frame in interlaced formats and DE defines the active video in progressive formats.
Poornima
I have already check the setting"##GR VGA 640x480## at 4682.ADV7441A_Evaluation_Board_Documents.zip",There is none similar input format and output,Thanks!
I have already check the setting"##GR VGA 640x480## at 4682.ADV7441A_Evaluation_Board_Documents.zip",There is none similar input format and output format, like VGA input 640*480P60Hz/1280*720P60Hz, RGB888 TTL output, Thanks!
Please let me know, Have you verified with RGB444 TTL output ? or you have issue only with RGB888 TTL output.
