DELAY = 10 /
REGW = X00, X00 / ; INSEL = CVBS in on Ain 1
REGW = X27, XFF /
REGW = X0D, XFF /
REGW = X0F, X00 / ; Exit power down mode;PWRDWN 1-Active[5], Reset[7] 1-Active
REGW = X0E, X00 / ; Enter User Sub Map
REGW = X9C, X00 / ; ADI Required Write
REGW = X9C, XFF / ; ADI Required Write
REGW = X03, X4E / ; ADI Required Write
REGW = X04, X57 / ; Enable Intrq pin
REGW = X13, X00 / ; Enable INTRQ output driver
REGW = X17, X41 / ; select SH1
REGW = X1D, XC0 / ; Tri-State LLC output driver
REGW = X52, XCD / ; ADI Required Write
REGW = X80, X51 / ; ADI Required Write
REGW = X81, X51 / ; ADI Required Write
REGW = X82, X68 / ; ADI Required Write
REGW = XFD, X84 / ; Set VPP Map Address
DEVADR = 0x84 /
DELAY = 5 /
REGW = X0E, X00 /
REGW = XA3, X00 / ; ADI Required Write
REGW = X5B, X00 / ; Advanced Timing Enabled
REGW = X55, X80 / ; Enable I2P
DEVADR = 0x42 /
DELAY = 5 /
REGW = XFE, X88 / ; Set CSI Map Address
DEVADR = 0x88 /
REGW = X0E, X00 /
REGW = X01, X20 / ; ADI Required Write
REGW = X02, X28 / ; ADI Required Write
REGW = X03, X38 / ; ADI Required Write
REGW = X04, X30 / ; ADI Required Write
REGW = X05, X30 / ; ADI Required Write
REGW = X06, X80 / ; ADI Required Write
REGW = X07, X70 / ; ADI Required Write
REGW = X08, X50 / ; ADI Required Write
REGW = XDE, X02 / ; Power up D-PHY
REGW = XD2, XF7 / ; ADI Required Write
REGW = XD8, X65 / ; ADI Required Write
REGW = XE0, X09 / ; ADI Required Write
REGW = X2C, X00 / ; ADI Required Write
REGW = X1D, X80 / ; ADI Required Write
REGW = X00, X00 / ; Power up CSI Block
