We are converting a CVBS NTSC-M video stream to CSI-2 with ADV7280-M having I2P enabled. The converted image is having some de-interlacing issues. The images are attached here with. Looks like even the color bars have similar issue. Our settings are below:
adv7180_write(state, 0x0F, 0x80); //chip reset
msleep(50);
adv7180_write(state, 0x0F, 0x00); //Exit Power Down Mode
adv7180_write(state, 0xFE, 0x88); //Set CSI Map Address
adv7180_write(state, 0xFD, 0x84); //Set VPP Map Address
adv7180_write(state, 0x00, 0x00); //INSEL = CVBS in on Ain 1
adv7180_write(state, 0x0E, 0x80); //ADI Required Write
adv7180_write(state, 0x9C, 0x00); //ADI Required Write
adv7180_write(state, 0x9C, 0xFF); //ADI Required Write
adv7180_write(state, 0x0E, 0x00); //Enter User Sub Map
adv7180_write(state, 0x03, 0x4E); //ADI Required Write
adv7180_write(state, 0x04, 0x57); //Power-up INTRQ pad
adv7180_write(state, 0x13, 0x00); //Enable INTRQ output driver
adv7180_write(state, 0x17, 0x41); //select SH1
adv7180_write(state, 0x1D, 0xC0); //Tri-S LLC output driver
adv7180_write(state, 0x52, 0xCD); //ADI Required Write
adv7180_write(state, 0x80, 0x51); //ADI Required Write
adv7180_write(state, 0x81, 0x51); //ADI Required Write
adv7180_write(state, 0x82, 0x68); //ADI Required Write
adv7180_write(state, 0x38, 0x24); //NTSC comb control Tried with and without this
adv7180_write(state, 0x6A, 0x03); //Output Sync Select 1
adv7180_write(state, 0x6B, 0x01); //Output Sync Select 2
adv7180_vpp_write(state, 0xA3, 0x00); //ADI Required Write
adv7180_vpp_write(state, 0x5B, 0x00); //Advanced Timing Enabled
adv7180_vpp_write(state, 0x55, 0x80); //Enable I2P
//enable fast switch
adv7180_write(state, 0x0E, 0x00); //ADI Required Writes
adv7180_write(state, 0x0E, 0x40); //Select User Sub Map 2
adv7180_write(state, 0xE0, 0x01); //Select fast Switching Mode. Tried with and without this
adv7180_write(state, 0x0E, 0x00); //Select User Map
adv7180_csi_write(state, 0x01, 0x20); //ADI Required Write
adv7180_csi_write(state, 0x02, 0x28); //ADI Required Write
adv7180_csi_write(state, 0x03, 0x38); //ADI Required Write
adv7180_csi_write(state, 0x04, 0x30); //ADI Required Write
adv7180_csi_write(state, 0x05, 0x30); //ADI Required Write
adv7180_csi_write(state, 0x06, 0x80); //ADI Required Write
adv7180_csi_write(state, 0x07, 0x70); //ADI Required Write
adv7180_csi_write(state, 0x08, 0x50); //ADI Required Write
adv7180_csi_write(state, 0xDE, 0x02); //Power up D-PHY
adv7180_csi_write(state, 0xD2, 0xF7); //ADI Required Write
adv7180_csi_write(state, 0xD8, 0x65); //ADI Required Write
adv7180_csi_write(state, 0xE0, 0x09); //ADI Required Write
adv7180_csi_write(state, 0x2C, 0x00); //ADI Required Write
adv7180_csi_write(state, 0x1D, 0x80); //ADI Required Write
adv7180_csi_write(state, 0x00, 0x00); //Power up CSI Block
Enabling/Disabling Fast switch mode is not helping either.
Are we missing some thing? Is it really de-interlacing issue (considering the color bars are also affected)?
Your help will be highly appreciated.
