Improving signal strength on AD9880
We're using the AD9880 in a design and we find that we are seeing issues on our prototypes which seem to be related to TMDS signal strength. An example setup which shows the problem particularly badly is:
Lenovo X301 DIsplayport output > DP to DVI adaptor > 2m DVI cable > AD9880
Running at 1080p60 (148.5MHz pixel clock) using a generic DVI cable.
We see two kinds of error, one is 'sparkles' - occasional pixels which are the wrong colour and the other is that we sometimes get vsync and hsync signals at the wrong times.
Switching the cable out for a high-quality, thick gauge alternative seems to make the problem much better, but with such a short run, I would hope that this isn't necessary.
Of the 20 units we've tested, the extent of the issue is very varied, the worst examples have such frequent sync signal errors that the image is unusable and the better ones show only a few sparkles per minute and are almost perfect. The same effect can be seen by replacing the AD9880 on a partcular PCB and seeing that the severity of the problem varies significantly, even over devices in the same batch.
Similarly, some video sources are better than others, in particular it seems that laptops with integrated graphics are bad, whether they have default Displayport or HDMI output. The Lenovo X301 is one such bad example, using the Intel GS45 chipset, but the Dell E6400 which uses the GM45 chipset and an extra Nvidia graphics processor is just fine.
We can see the errors on the output of the AD9880 using a scope, so we are fairly sure that the problem is not to do with reception of data later on in the system, but for reference, the 9880 is driving into a Xilinx Spartan 6 LXT using 1v8 I/O.
We have tried experimenting with the PLL registers 0x4D, 0x4E and 0x4F, but they don't seem to fix the problems. Are there any other register settings we can try to improve the reception quality before resorting to looking at hardware changes?
Thanks
James.
  • Hi James,
    i have pretty much exactly the same issues that you are seeing with the errant syncs when running through the 9880, although i dont see spotty video in this case. my scope captures do not show any reason why the errant syncs occur, except that when i get an errant vysnc and hsync, the errant hsync is always trailing the errant vsync by approx 4ns, or you can see it as each vsync and hsync are lined up with the control bit timing within the CH0 stream during inactive DE. So looking at the CH0 through active dif probes and the snyc outputs doesnt show anything that would allude to why the errant syncs occur, but i'm not too sure if there's a delay between the control bits on CH0 to when the output of the syncs occur.
    i have this issue in through my AD FAE and hope to get answers soon. I've attach some scope shots that might be helpful:
    datach0errantvsync.bmp is an errant vsync while looking at CH0 stream
    errantvsynctop3.bmp, top trace is vsync and bottom trace is hsync and the errant hsync occurs approximately 14 ns after a valid low to high transition, notice the delay of ~4ns from the errant vsync to hsync.
    Rolland
  • FormerMember
    0 FormerMember
on Apr 19, 2011 4:13 PM
Hi Rolland,
Can you capture a full VSync pulse with both leading and trailing edges and the glitch.  I'd like to see where the glitch occurs within the VSYNC pulse.
Thanks
  • Guenter,
    The errant sync pulses occur throughout the frame at random periods, however i'm attaching a scope shot that shows both the hsync and vsync glitches while DE should be active, not shown but the hsync and vsync are negative polarity and the glitches occur during the high side of both syncs.
    Rolland
  • Hi Rolland,
    A couple of things to try in order:
    1) Invert the clock signal and see if this helps, check Register 0x24 bit 0.  Of course the clock sink would have to handle the inverted clock correctly.
    2) Increase the 1.8V supply to 1.85-1.9V  (pins 30, 32 and 48 (if possible)
    3) Lower the 3.3V supply to 3.0V (pins 10, 90, 100) (if possible)
    Let me know how this works.
  • Guenter,
    I'm figuring out a way to change the voltage on the 1.8 and 3.3V. Can you tell me the reasoning behgind that suggestion and would i have to chnage both or one at time?
    thanks,
    Rolland
  • Hi Rolland,
    Raising the 1.8V on this part raises the threshold voltage for the incomming TMDS signalling.  Lowering the 3.3V will also increase the threshold but not as much as raising the 1.8V.
    I'd suggest changing the 1.8V first.  Usually it's the easier one to change compared to the 3.3V.  Only if that didn't help then change the 3.3V.
  • Hi James,
    We have exactly the same problem with the AD9880.
    Could you solve this problem yet!
    Thanks, Malikcis
  • Malickis,
    We were able to set the TMDS registers in the AD9880, these are not documented in the datasheets, however we had found the following information from AD to be very helpful
    (Note that we found setting Regs 0x53 and 0x59 to 0 instead of what AD recommend, however that is in our setup, your's may be different).
    AD9880 TMDS PLL Settings 1-19-06
    The recommendations for the AD9880* TMDS PLL settings (register 0x4D - 0x50) are
    being updated. These settings will be incorporated into the next revision of the AD9880
    data sheet. These settings are a result of more data being compiled through our
    Compliance Testing Lab. These settings are outlined in Table 1 below.
    Table 1: AD9880 TMDS PLL Settings
    Register      Old Setting      New Setting           Description
    0x4D           0x36           0x3B              Bits[6:4] set the C1 loop filter values (high freq).
        Bits [3:0] set the Ch. Pump Current value (high freq)
    0x4E           0x36            0x6D             Bits [6:4] set the C1 loop filter values (low freq).
        Bits [3:0] set the Ch. Pump Current value (low freq)
    0x4F           0x33            0x54              Bits [7:5] set the C2 loop filter values.
        Bits [4:0] set the R1 loop filter values
    0x50           0x20            0x90              This sets the VCO gear manually.
    0x53           0x3F            0x3F               Phase Recovery Loop control
    0x59           0x20            0x20               Controls TMDS clock termination connect
    * These settings also apply to the AD9380, AD9381, AD9396, AD9397, and AD9398.
  • Hi Rolland,
    This feedback solved all of our 1080p60 related AD9880 problems.
    Thank you very much for sharing this information.
    Malikcis,
    Thank you,
    EZ Admin
