AD8116 circuit
The user is experiencing 20mVp-p noise on the output pins of the AD8118 32x32 analog crosspoint switch in single-ended operation at 300 MHz. The engineer recommends keeping the 75 Ω and 150 Ω resistors and using a 27 Ω resistor for the inverting input to match the Thevenin resistance. Differential operation is suggested for better noise reduction.
Hi ,
We are using AD8118 32x 32 Analog crosspoint ,
We are using this in as a single Ended operation with input data speed of 300 Mhz , i have attached the power circuit for one channelh.
We are seeing a 20mVp-p noise on the output pins .Up till now we were using AD8118 and were seeing a 6-8 Vp-p noise .
Could you please let me know with regards to the following ,
We have seen there is no change even after removing the 75 Ω and 150 Ω resistor(Circled red) and connecting it to ground directly .
1. Is it fine to remove the 75 Ω and 150 Ω resistor and connecting it to ground directly .
    If there is not problem then , we are thing of putting a Decoupling capcitor to reduce the noise .
2.If noise Reduction is considered , which is the better Diffrential  or Single - Ended operation .
Please let me know with regards to this .
Thanking you
With best regards and wishes
  • Hello wallman16,
    I'm not clear which part exhibited the most noise.  The AD8118 has approximately 3.5x input referred voltage noise as the AD8116, so I would expect that you would see more noise with the AD8118.  The 3.5x factor correlates well with the noise numbers you presented.
    I do not recommend making the resistor changes you indicated in your drawing.  I recommend that you make the resistor that feeds the inverting input of the driver 27 ohms; this resistor should equal the Thevenin resistance looking back to the source from the non-inverting input.  In this case it is 36 || (75 + 39), presuming a 75 ohm source.  The load on the unused output should remain at 150 ohms.  The major noise source in these switches is the input referred voltage noise -- the external resistor values are small enough that their noise contributions are negligible.
    --Jonathan
    Thank you,
    EZ Admin
