extract VITC data from the ADV7181D
I'm trying to extract VITC data from the ADV7181D and there are some anomalies with the I2C register map.
Looking at the datasheet ADV7181D_Manual_Rev0.pdf from https://ez.analog.com/video/w/documents/760/adv7181d-design-support-files
the register at 0x0E ( ADI Control ) is defined in Table 69. The active bit is bit 5 - SUB_USR_EN.
In the document ADV7181D_ADV7181D@_ADV7341-VER.1.0c.txt also from the same source,  which contains initialization scripts the only bit of that register to be controlled is bit 7.
In the first script ##SD CVBS##:AUTODETECT CVBS IN NTSC/PAL/SECAM, 8-Bit 422 encoder, for example :
there are also register accesses in the User 1 space beyond the range of that space.
The limit of the space is 0x9C, but registers from 0xB1 to 0xF6 are accessed.
I could go on but hopefully this will whet your appetite!
Please can you explain these anomalies so I can have confidence that I have the correct documentation?
