Question from customer:
How can I use ADV7611 with an internal EDID?
Strong EMC design
ADV7611
Recommended for New Designs
The ADV7611 is offered in automotive, professional (no HDCP), and industrial versions. The operating temperature range is −40°C to +85°C.
The UG-180...
Datasheet
ADV7611 on Analog.com
Make sure that you don't have external EDID attached to DDC lines.
Following script sets ADV7611 to receive HDMI and output it as YCrCb 444.
Text in bold shows :EDID: script taken from scripts we recommend on our Design Support Files page
( https://ez.analog.com/docs/DOC-1745 ). It was inserted into standard HDMI input script.
An EDID content is written to map 6C byte by byte: 6C 00 00, 6C 01 FF, 6C 02 FF and etc.
Just modify values of writes to desired and you will have your custom EDID working from
an Internal EDID RAM. Last write (in bold) will make it visible to HDMI ports:
64 74 03 ; Enable the Internal EDID for Ports
You may also drop writes to ADV7511 (if you don't have it on your board).
All writes to ADV7511 start with I2C address 72 and can be found at the bottom of the script.
## HDMI IN ADV7611 - HDMI OUT ADV7511 ##
:6-1d Port A, 480i,576i,240p,288p,480p 576p Any Color Space In (YCrCb 444 24bit from ADV761x) Through HDMI Out 444 YCrCb VIC[1-3,6-14,17,18,21-29,30]:
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
64 77 00 ; Disable the Internal EDID
6C 00 00 ;
6C 01 FF ;
6C 02 FF ;
6C 03 FF ;
6C 04 FF ;
6C 05 FF ;
6C 06 FF ;
6C 07 00 ;
6C 08 06 ;
6C 09 8F ;
6C 0A 07 ;
6C 0B 11 ;
6C 0C 01 ;
6C 0D 00 ;
6C 0E 00 ;
6C 0F 00 ;
6C 10 17 ;
6C 11 11 ;
6C 12 01 ;
6C 13 03 ;
6C 14 80 ;
6C 15 0C ;
6C 16 09 ;
6C 17 78 ;
6C 18 0A ;
6C 19 1E ;
6C 1A AC ;
6C 1B 98 ;
6C 1C 59 ;
6C 1D 56 ;
6C 1E 85 ;
6C 1F 28 ;
6C 20 29 ;
6C 21 52 ;
6C 22 57 ;
6C 23 00 ;
6C 24 00 ;
6C 25 00 ;
6C 26 01 ;
6C 27 01 ;
6C 28 01 ;
6C 29 01 ;
6C 2A 01 ;
6C 2B 01 ;
6C 2C 01 ;
6C 2D 01 ;
6C 2E 01 ;
6C 2F 01 ;
6C 30 01 ;
6C 31 01 ;
6C 32 01 ;
6C 33 01 ;
6C 34 01 ;
6C 35 01 ;
6C 36 8C ;
6C 37 0A ;
6C 38 D0 ;
6C 39 8A ;
6C 3A 20 ;
6C 3B E0 ;
6C 3C 2D ;
6C 3D 10 ;
6C 3E 10 ;
6C 3F 3E ;
6C 40 96 ;
6C 41 00 ;
6C 42 81 ;
6C 43 60 ;
6C 44 00 ;
6C 45 00 ;
6C 46 00 ;
6C 47 18 ;
6C 48 01 ;
6C 49 1D ;
6C 4A 80 ;
6C 4B 18 ;
6C 4C 71 ;
6C 4D 1C ;
6C 4E 16 ;
6C 4F 20 ;
6C 50 58 ;
6C 51 2C ;
6C 52 25 ;
6C 53 00 ;
6C 54 81 ;
6C 55 49 ;
6C 56 00 ;
6C 57 00 ;
6C 58 00 ;
6C 59 9E ;
6C 5A 00 ;
6C 5B 00 ;
6C 5C 00 ;
6C 5D FC ;
6C 5E 00 ;
6C 5F 56 ;
6C 60 41 ;
6C 61 2D ;
6C 62 31 ;
6C 63 38 ;
6C 64 30 ;
6C 65 39 ;
6C 66 41 ;
6C 67 0A ;
6C 68 20 ;
6C 69 20 ;
6C 6A 20 ;
6C 6B 20 ;
6C 6C 00 ;
6C 6D 00 ;
6C 6E 00 ;
6C 6F FD ;
6C 70 00 ;
6C 71 17 ;
6C 72 3D ;
6C 73 0D ;
6C 74 2E ;
6C 75 11 ;
6C 76 00 ;
6C 77 0A ;
6C 78 20 ;
6C 79 20 ;
6C 7A 20 ;
6C 7B 20 ;
6C 7C 20 ;
6C 7D 20 ;
6C 7E 01 ;
6C 7F 1C ;
6C 80 02 ;
6C 81 03 ;
6C 82 34 ;
6C 83 71 ;
6C 84 4D ;
6C 85 82 ;
6C 86 05 ;
6C 87 04 ;
6C 88 01 ;
6C 89 10 ;
6C 8A 11 ;
6C 8B 14 ;
6C 8C 13 ;
6C 8D 1F ;
6C 8E 06 ;
6C 8F 15 ;
6C 90 03 ;
6C 91 12 ;
6C 92 35 ;
6C 93 0F ;
6C 94 7F ;
6C 95 07 ;
6C 96 17 ;
6C 97 1F ;
6C 98 38 ;
6C 99 1F ;
6C 9A 07 ;
6C 9B 30 ;
6C 9C 2F ;
6C 9D 07 ;
6C 9E 72 ;
6C 9F 3F ;
6C A0 7F ;
6C A1 72 ;
6C A2 57 ;
6C A3 7F ;
6C A4 00 ;
6C A5 37 ;
6C A6 7F ;
6C A7 72 ;
6C A8 83 ;
6C A9 4F ;
6C AA 00 ;
6C AB 00 ;
6C AC 67 ;
6C AD 03 ;
6C AE 0C ;
6C AF 00 ;
6C B0 10 ;
6C B1 00 ;
6C B2 88 ;
6C B3 2D ;
6C B4 00 ;
6C B5 00 ;
6C B6 00 ;
6C B7 FF ;
6C B8 00 ;
6C B9 0A ;
6C BA 20 ;
6C BB 20 ;
6C BC 20 ;
6C BD 20 ;
6C BE 20 ;
6C BF 20 ;
6C C0 20 ;
6C C1 20 ;
6C C2 20 ;
6C C3 20 ;
6C C4 20 ;
6C C5 20 ;
6C C6 00 ;
6C C7 00 ;
6C C8 00 ;
6C C9 FF ;
6C CA 00 ;
6C CB 0A ;
6C CC 20 ;
6C CD 20 ;
6C CE 20 ;
6C CF 20 ;
6C D0 20 ;
6C D1 20 ;
6C D2 20 ;
6C D3 20 ;
6C D4 20 ;
6C D5 20 ;
6C D6 20 ;
6C D7 20 ;
6C D8 00 ;
6C D9 00 ;
6C DA 00 ;
6C DB FF ;
6C DC 00 ;
6C DD 0A ;
6C DE 20 ;
6C DF 20 ;
6C E0 20 ;
6C E1 20 ;
6C E2 20 ;
6C E3 20 ;
6C E4 20 ;
6C E5 20 ;
6C E6 20 ;
6C E7 20 ;
6C E8 20 ;
6C E9 20 ;
6C EA 00 ;
6C EB 00 ;
6C EC 00 ;
6C ED 00 ;
6C EE 00 ;
6C EF 00 ;
6C F0 00 ;
6C F1 00 ;
6C F2 00 ;
6C F3 00 ;
6C F4 00 ;
6C F5 00 ;
6C F6 00 ;
6C F7 00 ;
6C F8 00 ;
6C F9 00 ;
6C FA 00 ;
6C FB 00 ;
6C FC 00 ;
6C FD 00 ;
6C FE 00 ;
6C FF DA ;
64 77 00 ; Set the Most Significant Bit of the SPA location to 0
64 52 20 ; Set the SPA for port B.
64 53 00 ; Set the SPA for port B.
64 70 9E ; Set the Least Significant Byte of the SPA location
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 F5 ; Auto CSC, YCrCb out, Set op_656 bit
98 03 40 ; 24 bit SDR 444 Mode 0
98 05 28 ; AV Codes Off
98 0B 44 ; Power up part
98 0C 42 ; Power up part
98 14 7F ; Max Drive Strength
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL enable
44 BA 01 ; Set HDMI FreeRun
64 40 81 ; Disable HDCP 1.1 features
68 9B 03 ; ADI recommended setting
68 C1 01 ; ADI recommended setting
68 C2 01 ; ADI recommended setting
68 C3 01 ; ADI recommended setting
68 C4 01 ; ADI recommended setting
68 C5 01 ; ADI recommended setting
68 C6 01 ; ADI recommended setting
68 C7 01 ; ADI recommended setting
68 C8 01 ; ADI recommended setting
68 C9 01 ; ADI recommended setting
68 CA 01 ; ADI recommended setting
68 CB 01 ; ADI recommended setting
68 CC 01 ; ADI recommended setting
68 00 00 ; Set HDMI Input Port A
68 83 FE ; Enable clock terminator for port A
68 6F 0C ; ADI recommended setting
68 85 1F ; ADI recommended setting
68 87 70 ; ADI recommended setting
68 8D 04 ; LFG
68 8E 1E ; HFG
68 1A 8A ; unmute audio
68 57 DA ; ADI recommended setting
68 58 01 ; ADI recommended setting
68 75 10 ; DDC drive strength
72 01 00 ; Set N Value(6144)
72 02 18 ; Set N Value(6144)
72 03 00 ; Set N Value(6144)
72 15 00 ; Input 444 (RGB or YCrCb) with Separate Syncs, 44.1kHz fs
72 16 70 ; Output format 444, 24-bit input
72 18 46 ; CSC disabled
72 40 80 ; General Control packet enable
72 41 10 ; Power down control
72 48 08 ; Data right justified
72 49 A8 ; Set Dither_mode - 12-to-10 bit
72 4C 00 ; 8 bit Output
72 55 40 ; Set YCrCb 444 in AVinfo Frame
72 56 08 ; Set active format Aspect
72 96 20 ; HPD Interrupt clear
72 98 03 ; ADI Recommended Write
72 99 02 ; ADI Recommended Write
72 9C 30 ; PLL Filter R1 Value
72 9D 61 ; Set clock divide
72 A2 A4 ; ADI Recommended Write
72 A3 A4 ; ADI Recommended Write
72 A5 04 ; ADI Recommended Write
72 AB 40 ; ADI Recommended Write
72 AF 16 ; Set HDMI Mode
72 BA 60 ; No clock delay
72 D1 FF ; ADI Recommended Write
72 DE D8 ; ADI Recommended Write
72 E4 60 ; VCO_Swing_Reference_Voltage
72 FA 7D ; Nbr of times to search for good phase
End
Please see https://ez.analog.com/thread/13613 regarding this.
This thread has been closed a long time ago. Please start a new question.
Poornima
Sure, but it is still relevant, i.e., I haven't found a thread that seems to resolve the EDID issue with adv7611
So far these ones are relevant:
ADV7611: Internal EDID stays disabled (as above)
(ADV7611) To enable internal EDID. (marked as answered, but with no answer given)
