Hello everyone,
This is not a question but rather a design note for people who are planning to use ADV739x chips. Especially for people having problems on I2C communication with ADV739x chips.
I have spent a fair amount of time to solve this problem. I am glad I did. But I would prefer to find a post about this. That's why I am writing the solution here.
I2C Problem
Problem Statement: Although everything (timing, i2c addresses, waveforms etc.) seems correct, ADV739x does not send the ACK bit.
Solution: If your design complies with all the timings related to I2C part but you still do not get any ACK bit.
Please make sure that you leave a hold time (1us min.) before changing the SDA line after every falling edge of SCL.
As far as I checked the datasheet, this is not mentioned. The waveform should look like this:
Normally, in an I2C communication, SDA line is sampled on the rising edges of SCL. I think this is little different for ADV739x. There should be some delay on SDA line so that after falling edge instants of SCL, the SDA should change with a 1us min. delay.
small corrections
[edited by: sgenc at 7:31 AM (GMT 0) on 8 Aug 2019]
