Adv7619 VS Clock not Stable @4K30Hz
Hello;
Adv7619 is used in our products. Among the mass productioned products, some products have unstable images when input 4k30Hz source (resolution below 4k is normal). The measurement found that the output VS clock was unstable (jitter), and the HS output was stable.
The problem phenomenon is the same no matter using portA or portB . TMDS, DE are locked. The following interrupts keep showing when problem occurs:
Attached is the regesiter map: Could you help on this issue; please? Many thanks!
adv7619_print.txt
[ADV7619_KDBG]: chip0 HDMI_LVL_INT ST1-4: 0x11 0x0c 0x5b 0x00
[ADV7619_KDBG]: chip0 HDMI_LVL_INT ST1-4: 0x00 0x00 0x02 0x00
[ADV7619_KDBG]: chip0 fmt_change=0x5b, digital=0x0, avi=0x1
[ADV7619_KPRT]: chip0 AVI infoframe version 2 (13 byte)
[ADV7619_KPRT]:   |-- color space: YCbCr4:4:4
[ADV7619_KMSG]: chip0 intf[0xa0000] detected HDMI mode, cs=YUV_709 Hs+/Vs+ pixrept=1x
[ADV7619_KMSG]:   Timing: pix clock = 296976562 Hz, 8-bits per channel
[ADV7619_KMSG]:     Horz: ht=4400 hfp=176 hwp=88 hbp=296 ha=3840
[ADV7619_KMSG]:     Fid0: vt=2250.0 vfp=8.0 vwp=10.0 vbp=72.0 va=2160
[ADV7619_KDBG]: chip0 intf[0xa0000] opt timing filled!
adv7619_query_dv_timings: 3840x2160p30.0 (4400x2250)
  |- horizontal: hfp=176 +hsync=88 hbp=296
  |- vertical_0: vfp=8 +vsync=10 vbp=72
  |- pixelclock: 297000000, flags: 0x0, standards: 0x1
[ADV7619_KMSG]: chip0 intf[0xa0000] set predefined video timing
[ADV7619_KMSG]: chip0 intf[0xa0000] detected vid std = 3840x2160@p30Hz cs=0x8
adv7619 regs table:
io regs :
0x00=0x19  0x01=0x05  0x02=0xf4  0x03=0x54  0x04=0x62  0x05=0x28  0x06=0xa0  0x07=0x40
0x08=0x14  0x09=0x00  0x0a=0x90  0x0b=0x44  0x0c=0x42  0x0d=0x1e  0x0e=0x0f  0x0f=0x1e
0x10=0x00  0x11=0x00  0x12=0xc0  0x13=0x0d  0x14=0x5a  0x15=0x80  0x16=0x43  0x17=0x5a
0x18=0x34  0x19=0x83  0x1a=0x02  0x1b=0x01  0x1c=0x00  0x1d=0x00  0x1e=0x00  0x1f=0x00
0x20=0xf0  0x21=0x08  0x22=0x00  0x23=0x03  0x24=0x00  0x25=0x00  0x26=0x00  0x27=0x00
0x28=0x00  0x29=0x00  0x2a=0x00  0x2b=0x00  0x2c=0x00  0x2d=0x00  0x2e=0x00  0x2f=0x00
0x30=0x88  0x31=0x00  0x32=0x00  0x33=0x40  0x34=0x00  0x35=0x00  0x36=0x00  0x37=0x00
0x38=0x00  0x39=0x00  0x3a=0x00  0x3b=0x00  0x3c=0x00  0x3d=0x00  0x3e=0x00  0x3f=0x03
0x40=0xf1  0x41=0xf0  0x42=0x04  0x43=0x00  0x44=0x00  0x45=0x00  0x46=0x00  0x47=0x04
0x48=0x00  0x49=0x00  0x4a=0x00  0x4b=0x00  0x4c=0x00  0x4d=0x00  0x4e=0x00  0x4f=0x00
0x50=0x00  0x51=0x00  0x52=0x00  0x53=0x00  0x54=0x00  0x55=0x00  0x56=0x00  0x57=0x00
0x58=0x00  0x59=0x00  0x5a=0x00  0x5b=0x08  0x5c=0x00  0x5d=0x00  0x5e=0x00  0x5f=0x00
0x60=0x00  0x61=0x11  0x62=0x00  0x63=0x13  0x64=0x13  0x65=0x40  0x66=0x0c  0x67=0x00
0x68=0x9a  0x69=0x9a  0x6a=0xd3  0x6b=0x08  0x6c=0x00  0x6d=0x9b  0x6e=0x9b  0x6f=0x01
0x70=0x00  0x71=0x00  0x72=0x01  0x73=0x01  0x74=0x00  0x75=0x00  0x76=0x00  0x77=0x00
0x78=0x00  0x79=0x11  0x7a=0x11  0x7b=0x00  0x7c=0x00  0x7d=0x00  0x7e=0x04  0x7f=0x04
0x80=0x00  0x81=0x00  0x82=0x00  0x83=0x42  0x84=0x42  0x85=0x00  0x86=0x00  0x87=0x00
0x88=0x00  0x89=0x00  0x8a=0x00  0x8b=0x00  0x8c=0x00  0x8d=0x00  0x8e=0x00  0x8f=0x00
0x90=0x00  0x91=0x00  0x92=0x00  0x93=0x00  0x94=0x00  0x95=0x00  0x96=0x00  0x97=0x00
0x98=0x00  0x99=0x00  0x9a=0x00  0x9b=0x00  0x9c=0x00  0x9d=0x00  0x9e=0x00  0x9f=0x00
0xa0=0x00  0xa1=0x00  0xa2=0x00  0xa3=0x00  0xa4=0x00  0xa5=0x00  0xa6=0x00  0xa7=0x00
0xa8=0x00  0xa9=0x00  0xaa=0x00  0xab=0x00  0xac=0x00  0xad=0x00  0xae=0x00  0xaf=0x00
0xb0=0x00  0xb1=0x00  0xb2=0x00  0xb3=0x00  0xb4=0x00  0xb5=0x00  0xb6=0x00  0xb7=0x43
0xb8=0xe0  0xb9=0x00  0xba=0x00  0xbb=0x08  0xbc=0x0f  0xbd=0xff  0xbe=0x00  0xbf=0x00
0xc0=0x00  0xc1=0x0e  0xc2=0x00  0xc3=0x00  0xc4=0x00  0xc5=0x00  0xc6=0x00  0xc7=0x00
0xc8=0x00  0xc9=0x00  0xca=0x00  0xcb=0x00  0xcc=0x00  0xcd=0x00  0xce=0x00  0xcf=0x00
0xd0=0x02  0xd1=0x0d  0xd2=0x7f  0xd3=0x33  0xd4=0x7f  0xd5=0x7f  0xd6=0x00  0xd7=0x00
0xd8=0x2d  0xd9=0x15  0xda=0xf1  0xdb=0x5f  0xdc=0x40  0xdd=0x00  0xde=0x00  0xdf=0x00
0xe0=0x00  0xe1=0x00  0xe2=0x04  0xe3=0x00  0xe4=0x01  0xe5=0x00  0xe6=0x00  0xe7=0x04
0xe8=0x04  0xe9=0x00  0xea=0x20  0xeb=0xc1  0xec=0x00  0xed=0x00  0xee=0x00  0xef=0x00
0xf0=0x00  0xf1=0x00  0xf2=0x00  0xf3=0x00  0xf4=0x20  0xf5=0x2a  0xf6=0x00  0xf7=0x00
0xf8=0x24  0xf9=0x2c  0xfa=0x26  0xfb=0x28  0xfc=0x00  0xfd=0x22  0xfe=0x00  0xff=0x00
cp regs :
0x00=0x00  0x01=0x00  0x02=0x00  0x03=0x00  0x04=0x00  0x05=0x00  0x06=0x00  0x07=0x00
0x08=0x00  0x09=0x02  0x0a=0x22  0x0b=0x00  0x0c=0x02  0x0d=0x07  0x0e=0x4c  0x0f=0x99
0x10=0x08  0x11=0x64  0x12=0x08  0x13=0x02  0x14=0x7a  0x15=0xb1  0x16=0x05  0x17=0xb9
0x18=0x27  0x19=0x08  0x1a=0x04  0x1b=0x20  0x1c=0xb7  0x1d=0xa7  0x1e=0xfa  0x1f=0x93
0x20=0x20  0x21=0x00  0x22=0x00  0x23=0x00  0x24=0x00  0x25=0x00  0x26=0x00  0x27=0x00
0x30=0x00  0x31=0x00  0x32=0x00  0x33=0x00  0x34=0x00  0x35=0x08  0x36=0x00  0x37=0x00
0x38=0x00  0x39=0x00  0x3a=0x80  0x3b=0x80  0x3c=0x00  0x3d=0x00  0x3e=0x80  0x3f=0x00
0x40=0x5c  0x41=0x02  0x42=0x3b  0x43=0xd4  0x44=0x03  0x45=0x33  0x46=0x00  0x47=0x00
0x50=0xc0  0x51=0x00  0x52=0x40  0x53=0x00  0x54=0x00  0x55=0x00  0x56=0x00  0x57=0x08
0x58=0x00  0x59=0x00  0x5a=0x00  0x5b=0x00  0x5c=0x01  0x5d=0x00  0x5e=0x00  0x5f=0x00
0x60=0x00  0x61=0x00  0x62=0x20  0x63=0x00  0x64=0x00  0x65=0x00  0x66=0x00  0x67=0x00
0x68=0xf0  0x69=0x04  0x6a=0x00  0x6b=0x00  0x6c=0x10  0x6d=0x00  0x6e=0x00  0x6f=0x00
0x70=0x00  0x71=0x00  0x72=0x00  0x73=0x10  0x74=0x04  0x75=0x01  0x76=0x00  0x77=0xff
0x78=0xff  0x79=0xff  0x7a=0xff  0x7b=0x05  0x7c=0xc0  0x7d=0x00  0x7e=0x00  0x7f=0x00
0x80=0x00  0x81=0xc0  0x82=0x04  0x83=0x00  0x84=0x0c  0x85=0x03  0x86=0x0b  0x87=0x00
0x88=0x00  0x89=0x00  0x8a=0x20  0x8b=0x40  0x8c=0x00  0x8d=0x00  0x8e=0x00  0x8f=0x40
0x90=0x00  0x91=0x00  0x92=0x00  0x93=0x00  0x94=0x00  0x95=0x00  0x96=0x00  0x97=0xf0
0xa0=0x00  0xa1=0x00  0xa2=0x00  0xa3=0x00  0xa4=0x03  0xa5=0x00  0xa6=0x00  0xa7=0x00
0xa8=0x00  0xa9=0x00  0xaa=0x00  0xab=0x00  0xac=0x00  0xad=0x00  0xae=0x60  0xaf=0x00
0xb0=0x00  0xb1=0x0d  0xb2=0x39  0xb3=0x00  0xb4=0x00  0xb5=0xf9  0xb6=0x20  0xb7=0x91
0xb8=0x00  0xb9=0x09  0xba=0x01  0xbb=0x00  0xbc=0x00  0xbd=0x18  0xbe=0x00  0xbf=0x12
0xc0=0x00  0xc1=0x00  0xc2=0x00  0xc3=0x39  0xc4=0x44  0xc5=0x91  0xc6=0x00  0xc7=0x00
0xc8=0x00  0xc9=0x2c  0xca=0x00  0xcb=0x60  0xcc=0x1a  0xcd=0xff  0xce=0x7f  0xcf=0x00
0xd0=0x00  0xd1=0x00  0xd2=0x00  0xd3=0x00  0xd4=0x00  0xd5=0x00  0xd6=0x00  0xd7=0x00
0xd8=0x00  0xd9=0x00  0xda=0x00  0xdb=0x19  0xdc=0x64  0xdd=0x12  0xde=0xc5  0xdf=0x78
0xe0=0xd0  0xe1=0x09  0xe2=0x18  0xe3=0x00  0xe4=0x00  0xe5=0x00  0xe6=0x50  0xe7=0x00
0xe8=0x01  0xe9=0x01  0xea=0x01  0xeb=0x08  0xec=0x00  0xed=0x0c  0xee=0x00  0xef=0x00
0xf0=0x23  0xf1=0x40  0xf2=0x04  0xf3=0xd4  0xf4=0x50  0xf5=0x00  0xf6=0x00  0xf7=0x15
0xf8=0x03  0xf9=0x33  0xfa=0x01  0xfb=0x00  0xfc=0x08  0xfd=0xca  0xfe=0x00  0xff=0x08
cec regs :
0x08=0x00  0x09=0x00  0x0a=0x00  0x0b=0x00  0x0c=0x00  0x0d=0x00  0x0e=0x00  0x0f=0x00
0x10=0x00  0x11=0x00  0x12=0x13  0x13=0x57  0x14=0x00  0x15=0x00  0x16=0x00  0x17=0x00
0x18=0x00  0x19=0x00  0x1a=0x00  0x1b=0x00  0x1c=0x00  0x1d=0x00  0x1e=0x00  0x1f=0x00
0x20=0x00  0x21=0x00  0x22=0x00  0x23=0x00  0x24=0x00  0x25=0x00  0x26=0x00  0x27=0x10
0x28=0xff  0x29=0x0f  0x2a=0x3e  0x2b=0x07  0x2c=0x00  0x2d=0x0f  0x2e=0xbb  0x2f=0x0e
0x30=0xae  0x31=0x10  0x32=0xc7  0x33=0x0c  0x34=0xef  0x35=0x0b  0x36=0xe2  0x37=0x0d
0x38=0xfb  0x39=0x08  0x3a=0x64  0x3b=0x06  0x3c=0xd1  0x3d=0x09  0x3e=0xf6  0x3f=0x02
0x40=0x19  0x41=0x05  0x42=0x3e  0x43=0x06  0x44=0x4b  0x45=0x03  0x46=0xac  0x47=0x0c
0x48=0x96  0x49=0x02  0x4a=0x00  0x4b=0xe0  0x4c=0x00  0x4d=0x01  0x4e=0x0c  0x4f=0x03
0x50=0x25  0x51=0x04  0x52=0x32  0x53=0x00  0x54=0x00  0x55=0x00  0x56=0x00  0x57=0x00
0x58=0x00  0x59=0x00  0x5a=0x00  0x5b=0x00  0x5c=0x00  0x5d=0x00  0x5e=0x00  0x5f=0x00
0x60=0x00  0x61=0x00  0x62=0x00  0x63=0x00  0x64=0x00  0x65=0x00  0x66=0x00  0x67=0x00
0x68=0x00  0x69=0x00  0x6a=0x00  0x6b=0x00  0x6c=0x00  0x6d=0x00  0x6e=0x00  0x6f=0x00
0x70=0x00  0x71=0x00  0x72=0x00  0x73=0x00  0x74=0x00  0x75=0x00  0x76=0x00  0x77=0x00
0x78=0x6d  0x79=0x8f  0x7a=0x82  0x7b=0x04  0x7c=0x0d  0x7d=0x70  0x7e=0x42  0x7f=0x41
0x80=0x00  0x81=0x00  0x82=0x00  0x83=0x00  0x84=0x00  0x85=0x00  0x86=0x00  0x87=0x00
0xb0=0x00  0xb1=0x00  0xb2=0x00  0xb3=0x00  0xb4=0x00  0xb5=0x00  0xb6=0x00  0xb7=0x00
0xb8=0x00  0xb9=0x00  0xba=0x00  0xbb=0x00  0xbc=0x00  0xbd=0x00  0xbe=0x00  0xbf=0x00
0xc0=0x00  0xc1=0x00  0xc2=0x00  0xc3=0x00  0xc4=0x00  0xc5=0x00  0xc6=0x00  0xc7=0x00
0xd8=0x00  0xd9=0x00  0xda=0x00  0xdb=0x00  0xdc=0x00  0xdd=0x00  0xde=0x00  0xdf=0x00
0xe0=0x00  0xe1=0x00  0xe2=0x00  0xe3=0x00  0xe4=0x00  0xe5=0x00  0xe6=0x00  0xe7=0x00
0xe8=0x00  0xe9=0x00  0xea=0x00  0xeb=0x00  0xec=0x00  0xed=0x00  0xee=0x00  0xef=0x00
0xf0=0x00  0xf1=0x00  0xf2=0x00  0xf3=0x00  0xf4=0x00  0xf5=0x00  0xf6=0x00  0xf7=0x00
0xf8=0x00  0xf9=0x00  0xfa=0x00  0xfb=0x00  0xfc=0x00  0xfd=0x00  0xfe=0x00  0xff=0x00
infoframe regs :
0x10=0x00  0x11=0x00  0x12=0x00  0x13=0x00  0x14=0x00  0x15=0x00  0x16=0x00  0x17=0x00
0x20=0x00  0x21=0x00  0x22=0x00  0x23=0x00  0x24=0x00  0x25=0x00  0x26=0x00  0x27=0x00
0x30=0x00  0x31=0x00  0x32=0x00  0x33=0x00  0x34=0x00  0x35=0x00  0x36=0x00  0x37=0x00
0x38=0x00  0x39=0x00  0x3a=0x00  0x3b=0x00  0x3c=0x00  0x3d=0x00  0x3e=0x00  0x3f=0x00
0x40=0x00  0x41=0x00  0x42=0x00  0x43=0x00  0x44=0x00  0x45=0x00  0x46=0x00  0x47=0x00
0x50=0x00  0x51=0x00  0x52=0x00  0x53=0x00  0x54=0x49  0x55=0x03  0x56=0x0c  0x57=0x00
0x58=0x20  0x59=0x00  0x5a=0x00  0x5b=0x00  0x5c=0x00  0x5d=0x00  0x5e=0x00  0x5f=0x00
0x78=0x00  0x79=0x00  0x7a=0x00  0x7b=0x00  0x7c=0x00  0x7d=0x00  0x7e=0x00  0x7f=0x00
0xe0=0x82  0xe1=0x00  0xe2=0x00  0xe3=0x84  0xe4=0x00  0xe5=0x00  0xe6=0x83  0xe7=0x00
0xe8=0x00  0xe9=0x85  0xea=0x00  0xeb=0x00  0xec=0x81  0xed=0x01  0xee=0x05  0xef=0x04
0xf0=0x00  0xf1=0x00  0xf2=0x05  0xf3=0x00  0xf4=0x00  0xf5=0x06  0xf6=0x00  0xf7=0x00
0xf8=0x0a  0xf9=0x00  0xfa=0x00  0xfb=0x00  0xfc=0x00  0xfd=0x00  0xfe=0x00  0xff=0x00
hdmi regs :
0x00=0x08  0x01=0x00  0x02=0x03  0x03=0x98  0x04=0x23  0x05=0xb0  0x06=0x28  0x07=0xaf
0x08=0x02  0x09=0x08  0x0a=0x70  0x0b=0x08  0x0c=0x70  0x0d=0x04  0x0e=0x8f  0x0f=0x1f
0x10=0xa5  0x11=0x7d  0x12=0x02  0x13=0x7f  0x14=0x3f  0x15=0xff  0x16=0xff  0x17=0x00
0x18=0x00  0x19=0x00  0x1a=0x88  0x1b=0x00  0x1c=0x0e  0x1d=0x00  0x1e=0x11  0x1f=0x30
0x20=0x00  0x21=0xb0  0x22=0x00  0x23=0x58  0x24=0x01  0x25=0x26  0x26=0x11  0x27=0x94
0x28=0x11  0x29=0x94  0x2a=0x00  0x2b=0x10  0x2c=0x00  0x2d=0x10  0x2e=0x00  0x2f=0x14
0x30=0x00  0x31=0x14  0x32=0x00  0x33=0x90  0x34=0x00  0x35=0x90  0x36=0x00  0x37=0x00
0x38=0x00  0x39=0x00  0x3a=0x00  0x3b=0x00  0x3c=0x02  0x3d=0x00  0x3e=0x69  0x3f=0x46
0x40=0x00  0x41=0x40  0x42=0x00  0x43=0x0f  0x44=0x45  0x45=0x04  0x46=0x0f  0x47=0x00
0x48=0x00  0x49=0x00  0x4a=0x00  0x4b=0x00  0x4c=0x40  0x4d=0x00  0x4e=0xfe  0x4f=0x08
0x50=0x00  0x51=0x94  0x52=0x7d  0x53=0x00  0x54=0x00  0x55=0x00  0x56=0x58  0x57=0xa3
0x58=0x07  0x59=0xa3  0x5a=0x00  0x5b=0x00  0x5c=0x00  0x5d=0x00  0x5e=0x00  0x5f=0x00
0x60=0x0f  0x61=0x0f  0x62=0x00  0x63=0x00  0x64=0x00  0x65=0x00  0x66=0x00  0x67=0x00
0x68=0x00  0x69=0x00  0x6a=0x00  0x6b=0x00  0x6c=0xa4  0x6d=0x00  0x6e=0x04  0x6f=0x08
0x70=0x02  0x71=0x00  0x72=0x04  0x73=0x00  0x74=0x00  0x75=0x00  0x76=0x04  0x77=0x00
0x78=0x00  0x79=0x00  0x7a=0x00  0x7b=0x07  0x7c=0xff  0x7d=0x00  0x7e=0x00  0x7f=0x00
0x80=0x00  0x81=0x00  0x82=0x00  0x83=0xfc  0x84=0x03  0x85=0x10  0x86=0x9b  0x87=0x04
0x88=0x09  0x89=0x03  0x8a=0xa3  0x8b=0x08  0x8c=0x00  0x8d=0x08  0x8e=0x00  0x8f=0x08
0x90=0x00  0x91=0x00  0x92=0x08  0x93=0x03  0x94=0x08  0x95=0x03  0x96=0x03  0x97=0xc0
0x98=0xff  0x99=0xa3  0x9a=0xff  0x9b=0x03  0x9c=0x00  0x9d=0x40  0x9e=0x00  0x9f=0x00
0xa0=0x00  0xa1=0x07  0xa2=0x00  0xa3=0x00  0xa4=0x16  0xa5=0x16  0xa6=0x16  0xa7=0x00
0xa8=0x00  0xa9=0xf0  0xaa=0x00  0xab=0xf0  0xac=0x00  0xad=0xf0  0xae=0x00  0xaf=0x00
0xb8=0x00  0xb9=0x00  0xba=0x02  0xbb=0x00  0xbc=0x00  0xbd=0x03  0xbe=0xc4  0xbf=0x00
0xc0=0xff  0xc1=0x00  0xc2=0x00  0xc3=0x00  0xc4=0x00  0xc5=0x00  0xc6=0x00  0xc7=0x00
0xd0=0x00  0xd1=0x00  0xd2=0x05  0xd3=0x00  0xd4=0x00  0xd5=0x00  0xd6=0x02  0xd7=0x00
0xd8=0x00  0xd9=0x00  0xda=0x01  0xdb=0x00  0xdc=0x00  0xdd=0x00  0xde=0x00  0xdf=0x00
0xe0=0x00  0xe1=0x00  0xe2=0x00  0xe3=0x00  0xe4=0x00  0xe5=0x01  0xe6=0x00  0xe7=0x00
0xe8=0x00  0xe9=0x01  0xea=0x00  0xeb=0x00  0xec=0x00  0xed=0x00  0xee=0x00  0xef=0x82
edid regs :
0x00=0x00  0x01=0xff  0x02=0xff  0x03=0xff  0x04=0xff  0x05=0xff  0x06=0xff  0x07=0x00
0x08=0x4d  0x09=0xd9  0x0a=0x03  0x0b=0x24  0x0c=0x01  0x0d=0x01  0x0e=0x01  0x0f=0x01
0x10=0x01  0x11=0x17  0x12=0x01  0x13=0x03  0x14=0x80  0x15=0x7a  0x16=0x44  0x17=0x78
0x18=0x0a  0x19=0x0d  0x1a=0xc9  0x1b=0xa0  0x1c=0x57  0x1d=0x47  0x1e=0x98  0x1f=0x27
0x20=0x12  0x21=0x48  0x22=0x4c  0x23=0x21  0x24=0x08  0x25=0x00  0x26=0x81  0x27=0x80
0x28=0x01  0x29=0x01  0x2a=0x01  0x2b=0x01  0x2c=0x01  0x2d=0x01  0x2e=0x01  0x2f=0x01
0x30=0x01  0x31=0x01  0x32=0x01  0x33=0x01  0x34=0x01  0x35=0x01  0x36=0x02  0x37=0x3a
0x38=0x80  0x39=0x18  0x3a=0x71  0x3b=0x38  0x3c=0x2d  0x3d=0x40  0x3e=0x58  0x3f=0x2c
0x40=0x45  0x41=0x00  0x42=0xc2  0x43=0xad  0x44=0x42  0x45=0x00  0x46=0x00  0x47=0x1e
0x48=0x01  0x49=0x1d  0x4a=0x00  0x4b=0x72  0x4c=0x51  0x4d=0xd0  0x4e=0x1e  0x4f=0x20
0x50=0x6e  0x51=0x28  0x52=0x55  0x53=0x00  0x54=0xc2  0x55=0xad  0x56=0x42  0x57=0x00
0x58=0x00  0x59=0x1e  0x5a=0x00  0x5b=0x00  0x5c=0x00  0x5d=0xfc  0x5e=0x00  0x5f=0x53
0x60=0x4f  0x61=0x4e  0x62=0x59  0x63=0x20  0x64=0x54  0x65=0x56  0x66=0x20  0x67=0x20
0x68=0x2a  0x69=0x30  0x6a=0x37  0x6b=0x0a  0x6c=0x00  0x6d=0x00  0x6e=0x00  0x6f=0xfd
0x70=0x00  0x71=0x30  0x72=0x3e  0x73=0x0e  0x74=0x46  0x75=0x0f  0x76=0x00  0x77=0x0a
0x78=0x20  0x79=0x20  0x7a=0x20  0x7b=0x20  0x7c=0x20  0x7d=0x20  0x7e=0x01  0x7f=0x7a
0x80=0x02  0x81=0x03  0x82=0x43  0x83=0xf0  0x84=0x53  0x85=0x1f  0x86=0x10  0x87=0x14
0x88=0x05  0x89=0x13  0x8a=0x04  0x8b=0x20  0x8c=0x22  0x8d=0x3c  0x8e=0x3e  0x8f=0x12
0x90=0x16  0x91=0x03  0x92=0x07  0x93=0x11  0x94=0x15  0x95=0x02  0x96=0x06  0x97=0x01
0x98=0x26  0x99=0x09  0x9a=0x07  0x9b=0x07  0x9c=0x15  0x9d=0x07  0x9e=0x50  0x9f=0x83
0xa0=0x01  0xa1=0x00  0xa2=0x00  0xa3=0x78  0xa4=0x03  0xa5=0x0c  0xa6=0x00  0xa7=0x30
0xa8=0x00  0xa9=0xb8  0xaa=0x3c  0xab=0x2f  0xac=0xd0  0xad=0x8a  0xae=0x01  0xaf=0x02
0xb0=0x03  0xb1=0x04  0xb2=0x01  0xb3=0x40  0xb4=0x00  0xb5=0x7f  0xb6=0x20  0xb7=0x30
0xb8=0x70  0xb9=0x80  0xba=0x90  0xbb=0x76  0xbc=0xe2  0xbd=0x00  0xbe=0xfb  0xbf=0xe3
0xc0=0x05  0xc1=0x1f  0xc2=0x01  0xc3=0x02  0xc4=0x3a  0xc5=0x80  0xc6=0xd0  0xc7=0x72
0xc8=0x38  0xc9=0x2d  0xca=0x40  0xcb=0x10  0xcc=0x2c  0xcd=0x45  0xce=0x80  0xcf=0xc2
0xd0=0xad  0xd1=0x42  0xd2=0x00  0xd3=0x00  0xd4=0x1e  0xd5=0x01  0xd6=0x1d  0xd7=0x00
0xd8=0xbc  0xd9=0x52  0xda=0xd0  0xdb=0x1e  0xdc=0x20  0xdd=0xb8  0xde=0x28  0xdf=0x55
0xe0=0x40  0xe1=0xc2  0xe2=0xad  0xe3=0x42  0xe4=0x00  0xe5=0x00  0xe6=0x1e  0xe7=0x01
0xe8=0x1d  0xe9=0x80  0xea=0xd0  0xeb=0x72  0xec=0x1c  0xed=0x16  0xee=0x20  0xef=0x10
0xf0=0x2c  0xf1=0x25  0xf2=0x80  0xf3=0xc2  0xf4=0xad  0xf5=0x42  0xf6=0x00  0xf7=0x00
0xf8=0x9e  0xf9=0x00  0xfa=0x00  0xfb=0x00  0xfc=0x00  0xfd=0x00  0xfe=0x00  0xff=0x50
rep regs :
0x08=0x00  0x09=0x00  0x0a=0xab  0x0b=0x00  0x0c=0x00  0x0d=0x00  0x0e=0x00  0x0f=0x00
0x40=0x81  0x41=0x00  0x42=0x00  0x43=0x00  0x44=0x00  0x45=0x00  0x46=0x00  0x47=0x00
0x50=0x00  0x51=0x00  0x52=0x10  0x53=0x00  0x54=0x00  0x55=0x00  0x56=0x10  0x57=0x00
0x58=0x00  0x59=0x00  0x5a=0x10  0x5b=0x00  0x5c=0x00  0x5d=0x00  0x5e=0x10  0x5f=0x00
0x60=0x00  0x61=0x3f  0x62=0x00  0x63=0x3f  0x64=0x00  0x65=0x3f  0x66=0x00  0x67=0x3f
0x68=0x00  0x69=0x3f  0x6a=0x00  0x6b=0x3f  0x6c=0x00  0x6d=0x3f  0x6e=0x00  0x6f=0x3f
0x70=0x00  0x71=0x00  0x72=0x01  0x73=0x00  0x74=0x01  0x75=0x00  0x76=0x01  0x77=0x00
0x78=0x00  0x79=0x88  0x7a=0x04  0x7b=0x00  0x7c=0x00  0x7d=0x00  0x7e=0x00  0x7f=0xb1
dpll regs :
0x80=0x80  0x81=0x20  0x82=0x80  0x83=0x02  0x84=0x02  0x85=0x0a  0x86=0x0a  0x87=0x0a
0x88=0xf8  0x89=0x66  0x8a=0xfc  0x8b=0x13  0x8c=0xf8  0x8d=0x15  0x8e=0xde  0x8f=0x86
0x90=0xc1  0x91=0x91  0x92=0x82  0x93=0x70  0x94=0x00  0x95=0x00  0x96=0x00  0x97=0x00
0x98=0xff  0x99=0x0f  0x9a=0xff  0x9b=0x00  0x9c=0x00  0x9d=0x00  0x9e=0x00  0x9f=0x00
0xa0=0x00  0xa1=0x02  0xa2=0x02  0xa3=0xff  0xa4=0xff  0xa5=0xff  0xa6=0xf8  0xa7=0x66
0xa8=0xfc  0xa9=0x13  0xaa=0xf8  0xab=0x15  0xac=0xde  0xad=0x86  0xae=0xc1  0xaf=0x91
0xb0=0x82  0xb1=0x70  0xb2=0xff  0xb3=0x0f  0xb4=0xff  0xb5=0x01  0xb6=0x00  0xb7=0x00
0xb8=0x00  0xb9=0x00  0xba=0x00  0xbb=0x00  0xbc=0x00  0xbd=0x6f  0xbe=0x23  0xbf=0xfa
0xc0=0xc0  0xc1=0x98  0xc2=0x80  0xc3=0x80  0xc4=0x30  0xc5=0x02  0xc6=0x03  0xc7=0x00
0xc8=0x00  0xc9=0x00  0xca=0x00  0xcb=0x00  0xcc=0x40  0xcd=0x0a  0xce=0x96  0xcf=0x03
0xd0=0x25  0xd1=0x23  0xd2=0xe1  0xd3=0xae  0xd4=0xff  0xd5=0xe1  0xd6=0x05  0xd7=0x00
0xd8=0x00  0xd9=0x1b  0xda=0x04  0xdb=0x80  0xdc=0x00  0xdd=0x00  0xde=0x00  0xdf=0x00
0xe0=0x00  0xe1=0x00  0xe2=0x00  0xe3=0x00  0xe4=0x06  0xe5=0x06  0xe6=0x00  0xe7=0x00
0xf8=0x00  0xf9=0x0d  0xfa=0xf8  0xfb=0x0f  0xfc=0xe1  0xfd=0x00  0xfe=0x00  0xff=0x00
