How can the "CN0282 - USB Powered DVI/HDMI-to-VGA Converter (HDMI2VGA) with Audio Extraction" be adapted to output component video?
Replace the ADV7125 with a ADV7393 and program the ADV7611 to output 16-bit YCbCr 422.
How are these two parts different? And what are the necessary programmings for the ADV7393?
For two parts different, refer feature support of respective chipset datasheet.
https://ez.analog.com/video/w/documents/801/adv739x-design-support-files
https://www.analog.com/en/products/adv7125.html#product-overview
And also refer below HDMI-to-VGA (HDMI2VGA) Converter Block Diagram in ADV7125 circuit note at www.analog.com/.../CN0282.pdf
Poornima
What are the necessary programmings for the ADV7393?
How do you configure the board either through script or software driver?
In reference script there will be i2c configuration for different resolution which is available at https://ez.analog.com/video/w/documents/801/adv739x-design-support-files
Poornima
