ADV7842 3D_Comb(TBC=Off) , Output picture has small waving noise issue at CVBS input.
When I start 3D_Comb function, Output picture has small waving noise issue at when I used CVBS input.
However, this issue doesn't happen when I used Y/C input.
also, when I stopped 3D_Comb, this issue disappear even I used CVBS input.
System contens
3D_Comb = On
TBC=Off
64Mb SDR
It seems this issue is relating 3D Comb function.
How can I fix this?
Bogey
  • Hi Bogey,
    Some questions for you:
    Q1. Do you see this issue on EVAL-ADV7842-7511 when you run SW driver?
    Q2. Do you see this issue on EVAL-ADV7842-7511 when you configure with scripts?
    -Matt
  • Hi Matt,
    Here is my answer.
    If you have any more queation, pleae let me know.
    Ans,
    I did not try SW driver.  I don't have SW driver.
    Ans,
    Yes, I could see this issue on EVAL=ADV7842-7511.
    I use 2 kind SCRIP.  SDR and DDR version.
    Both verions have same issue.
    SDR
    94 75 06  ;add-yt(SD-RAM 64Mb)
    94 74 00  ;add-yt(SD-RAM 64Mb)
    94 79 33  ;add-yt(SD-RAM 64Mb)
    94 6F 01 ;add-yt(SD-RAM 64Mb)
    94 60 01  ;add-yt(SD-RAM 64Mb)
    94 7A 66 ;add-yt(SD-RAM 64Mb)
    94 7B 8F ;add-yt(SD-RAM 64Mb)
    DDR
    94 75 0A ;
    94 74 00  ;
    94 79 33  ;
    94 6F 00 ;
    94 60 01  ;
    94 7A A5 ;
    94 7B 8F ;
    It seems ADV7842-7511 has multi issues at 3D_Comb.
    My system had random dots noise and Waving noise..
    I modfied GND line more strong, then randum dots noise has gone.  but, waving noise still remain.
    I can see same issues on EVAL-ADV7842-7511.
    Bogey
    attachment.zip
  • Hi Bogey,
    If you have the EVAL-ADV7842-7511, then you have the software (SW) driver. It is also known as the repeater software.
    If you have EVAL-ADV7842-7511, this software starts automatically.
    If you have EVAL-ADV7842-7511P, this software can be started by typing "startrep" at the command line.
    -Matt
  • Hi Matt,
    Let me ask about Driver Software.
    I used AVESServer 1.03 115k and AVES2 2.04.36.
    Are you menioning this Software?
    If not, please let me know Sfrware name.
    Bogey,
  • Hi Bogey,
    AVES is software that runs on Windows and allows you to read/write registers.
    The software driver (also known as repeater software) runs on the Blackfin processor, uses RS232 for input/output, and configures the ADV7842/ADV7511 to accept a particular input (CVBS, S-Video, VGA, HDMI) and output over HDMI.
    Just use RS232 communications program like Teraterm and watch RS232 output after power-up. Make sure AVES software is closed. Only one program can access RS232 port at a time.
    -Matt
  • Hi Matt,
    Could you tell me RS232C Configuration?
    I used Hyperterminal for monitoring.
    I can see Garbled characters.
    Defoult setting are
    2400 bps
    8 bit data
    Non Parity
    Stop bit=1
    Hardware flow control
    How can I fix?
    Bogey
  • Try 115.2kbaud, 8 bit, no parity, 1 stop bit, HW flow control off
  • Hi Bogey,
    This information is in the user guide for EVAL-ADV7842-7511. It can be found at the following location:
    http://ez.analog.com/docs/DOC-1681
    -Matt
  • Hi Matt,
    I set up EVAL-ADV7842-7511 with REPEATER.
    EVAL-ADVL7842 worked fine.  and I can connect RS232C with EVAL-ADV7842-7511.
    Here is enviroment.
    CVBC (NTCS source) --> EVAL-ADV7842-7511--> Momitor.
    There is no noise issue at this time.  I can see good Color chart without noise.
    However, I'm not sure 3D_Comb is working or not at this time.
    I tried to overwrite 3D_Comb enable bit.  but, I could not change "SPD MAP:12h[0]=1".
    My operation with CMAND LINE with REPEATER was
    "rep i2cw 784 9012 01 <CR>"
    then , I got ERROR comment.
    "UI: 35803 Command exction failed"
    Please advise operation how I can write "SPD MAP:12h[0]=1".
    Also, please tell me 90:12h is correct address of 3D_Comb enabled in EVAL-ADV7842-7511?
    Bogey
  • Hi Matt,
    Now, I could check SW Driver(REPEATER) is working with 3D_Comb=ON.
    EVAL-ADV7842-7511 with SW Driver REPEATER doesn't have 3D_Comb noise issue.
    I think my 3D_Comb noise issue may be some test environment noise issue.
    My test environment is
    I guess NTCS source had noise.
    How do you think?
    Bogey
