ADV7341 20 bit YCbCr In
The user is troubleshooting color issues with a 20-bit 525i YCbCr input on an ADV7341 dev board, which results in a black and white picture. The final answer indicates the issue was resolved offline or through a multi-part answer, with a note that 0x87 = 20 enables SD input standard autodetect and the input clock should be 13.5 MHz for 20-bit and 27 MHz for 10-bit.
I have an ADV7181 dev board.
I am checking the ADV7341 on the board for CVBS out.
I am inserting a 525i YCbCr 10 bit and 20 bit signal into the AD7341, I have disconnected the ADV7181.
When I set my input for 10 bit it works fine.
When I set for 20 bit with the following inputs to the Register Control  3.56 I get a good black and white picture, but no color.
I have set register 0x80 for Y/C swap for the ADV7181 board and verified I have CbCr input to C 9-0. I have Hsync and Vsync positive.
If I set my input for EIA/DEA 861 sync compliance and Register 0x86 to 0x08 for SD EIA/CEA I get no picture.
Do you have any ideas to fix my 20 bit no color? And no picture for EIA 861 compliance?
Table 69. 20-Bit 525i YCrCb In, YPrPb and CVBS/Y-C Out Subaddress
Setting
Description
0x17
0x02
Software reset.
0x00
0xFC
All DACs enabled. PLL enabled (16×).
0x01
0x80
SD input mode.
Y/C swap
0x80
0x10
NTSC standard. SSAF luma filter enabled. 1.3 MHz chroma filter enabled.
0x82
0xC9
Pixel data valid. YPrPb and CVBS/Y-C out. SSAF PrPb filter enabled. Active video edge control enabled. Pedestal enabled.
0x88
0x18
20-bit input enabled.
0x8A
0x0C
Timing Mode 2 (slave). HSYNC/VSYNC
The only thing different from the scripts is 0x87 = 20 turning on SD input standard autodetect.
Also the input clock should be 13.5Mhz for 20 bit and 27Mhz for 10 bit, just checking
    Thank you,
    EZ Admin
