Color inversion (ADV7842 & ADV7513)
The user experienced color inversion when using the ADV7842 and ADV7513 to convert RGB (PC VGA) to HDMI. The issue was resolved by correcting the polarity of the differential HDMI traces between the ADV7513 and the AD8192 switch. Specifically, the TC0+ and TC0- pins were swapped, and the AD8192's internal register was programmed to reverse the polarity.
Hi all
I have a design with the ADV7842 and the ADV7513.
I have checked all the signal but i did't not find why i have a color inversion.
The input is RGB (PC VGA) and the output is HDMI.
any idea ?
Franck
  • Which scripts are you using?
    Make sure Y1Y0 register in the 7513 is set correctly.  Trying toggling it to see if it fixes the problem
  • Hy Guenter
    input resolution is : 1280x1024@60
    ADV7842 script is
    DEVICE_ADDR_ADV7842_IO_MAP, 0x00, 0x05,   // VID_STD=000101b for SXGA60
    DEVICE_ADDR_ADV7842_IO_MAP, 0x01, 0x82,   // Prim_Mode to graphics input
    DEVICE_ADDR_ADV7842_IO_MAP, 0x02, 0xF6,   // Auto input color space, Limited Range RGB Output
    DEVICE_ADDR_ADV7842_IO_MAP, 0x03, 0x40,   // 24 bit SDR 444
    DEVICE_ADDR_ADV7842_IO_MAP, 0x05, 0x28,   // Disable AV Codes
    DEVICE_ADDR_ADV7842_IO_MAP, 0x0C, 0x40,   // Power up Part
    DEVICE_ADDR_ADV7842_IO_MAP, 0x15, 0xB0,   // Disable Tristate of Pins except for Audio pins
    DEVICE_ADDR_ADV7842_CP_MAP, 0x73, 0xEA,   // Set manual gain of 0x2A8
    DEVICE_ADDR_ADV7842_CP_MAP, 0x74, 0x8A,   // Set manual gain of 0x2A8
    DEVICE_ADDR_ADV7842_CP_MAP, 0x75, 0xA2,   // Set manual gain of 0x2A8
    DEVICE_ADDR_ADV7842_CP_MAP, 0x76, 0xA8,   // Set manual gain of 0x2A8
    DEVICE_ADDR_ADV7842_CP_MAP, 0x85, 0x0B,   // Disable Autodetectmode for Sync_Source for CH1. Force CH1 to use HS&VS
    DEVICE_ADDR_ADV7842_CP_MAP, 0xC3, 0x39,   // ADI recommended write
    DEVICE_ADDR_ADV7842_AFE_DPLL_MAP, 0x0C, 0x1F,   // ADI recommended write
    DEVICE_ADDR_ADV7842_AFE_DPLL_MAP, 0x12, 0x63,   // ADI recommended write
    DEVICE_ADDR_ADV7842_AFE_DPLL_MAP, 0x00, 0x80,   // ADC power Up
    DEVICE_ADDR_ADV7842_AFE_DPLL_MAP, 0x02, 0x00,   // Ain_Sel to 000. (Ain 1,2,3)
    DEVICE_ADDR_ADV7842_AFE_DPLL_MAP, 0xC8, 0x00   // DLL_PHASE - 000000b
    ADV7513 script is:
    0x98, 0x03,                                      // ADI recommended write*
    0x9A, 0xE0,                                      // ADI recommended write*
    0x9C, 0x30,                                      // ADI recommended write*
    0x9D, 0x61,                                      // ADI recommended write
    0xA2, 0xA4,                                      // ADI recommended write*
    0xA3, 0xA4,                                      // ADI Recommended Write*
    0xE0, 0xD0,                                      // ADI Recommended Write*
    0x01, 0x00,                                      // Set 'N' value at 6144
    0x02, 0x18,                                      // Set 'N' value at 6144
    0x03, 0x00,                                      // Set 'N' value at 6144
    0x15, 0x00,                                      // 24-bit, 444 RGB input
    0x16, 0x00,                                      // RGB 444
    0x18, 0x46,                                      // Disable CSC
    0x40, 0x80,                                      // General control packet enable
    0x49, 0xA8,                                      // ADI recommended write*
    0x96, 0x00,                                      // HPD interrupt clear
    0x56, 0x08,                                      // Set active format aspect
    0xAF, 0x04,                                      // Select DVI mode
    0xBA, 0xA0,                                      // Set TX Clock Delay
    0xE4, 0x60,                                      // VCO_Swing_Reference_Voltage
    0x45, DEVICE_ADDR_ADV7513_PACKET_MEM_MAP,        // I2C Address for PACKET MEM REG
    0x43, DEVICE_ADDR_ADV7513_EDID_MAP,              // I2C Address for EDID_MAP
    0xE1, DEVICE_ADDR_ADV7513_CEC_MAP,               // I2C CEC_MAP
    0xF9, DEVICE_ADDR_ADV7513_FIXI2C_MAP,            // I2C Address for FIXI2C_MAP
    i have try to toogle the y0y1 register in the  adv7513 (0x55[6:5]) but no change
    franck
  • How is it inverted.
    When you input a blue screen, what do you get out?
    Please check IO 0x04[7:5] OP_CH_SEL.  If the output digital channels are swapped, you will get strange color conversions too.  I notice you don't seem to be writing it so it will be at the default
  • Hello
    inverted like this
    White --> Black
    Black --> White
    Green  --> magenta
    Red --> cyan
    Yellow --> blue
    franck
    Ce message, ainsi que tous les fichiers joints à ce message,
    peuvent contenir des informations sensibles et/ ou confidentielles
    ne devant pas être divulguées. Si vous n'êtes pas le destinataire
    de ce message (ou que vous recevez ce message par erreur), nous
    vous remercions de le notifier immédiatement à son expéditeur, et
    de détruire ce message. Toute copie, divulgation, modification,
    utilisation ou diffusion, non autorisée, directe ou indirecte, de
    tout ou partie de ce message, est strictement interdite.
    This e-mail, and any document attached hereby, may contain
    confidential and/or privileged information. If you are not the
    intended recipient (or have received this e-mail in error) please
    notify the sender immediately and destroy this e-mail. Any
    unauthorized, direct or indirect, copying, disclosure, distribution
    or other use of the material or parts thereof is strictly
    forbidden.
  • Solved !
    The problem was the connexion between the output of the HDMI transmiter and
    the switch connected behind.
    i just revert the source sign of the HDMI trace and that isolve the problem.
    Good to know !
  • Thanks for the update! Can you clarify what you did to resolve the issue?
    -Matt
  • Hi Matt
    The output HDMI trace from the ADV7513 was connected directly to the switch AD8192.
    The problem was that the polarity of the differential trace was inverted.
    And if the polarity is inverted the color are inverted to !
    I mean for example TC0+ of ADV7513 was connected to TC0- of AD8192
    and TC0- of ADV7513 was connected to TC0+ of AD8192.
    The issue was resolve thanks to the possibility of the AD8192 to reverse the polarity by
    programming the internal register.
    i hope that helps
    Captcha
