AD8108 output
We are planning to use AD8108 but would like to know about signal deterioration on the output .
Input : Video Generator
Please let me know if there is any recommendation with regards to avoid output signal deterioration
Thanking you
With best regards and wishes
  • FormerMember
    0 FormerMember
I'm not sure what degradation you are worried about.  As long as the bandwidth of the video is below 325MHz and the input/output terminations are correct then you should not see any problems.
What formats are going to be using?
  • Hi ,
    Thank you for the information .
    If we you take 5Mhz as example from input Video Generator  . what are the things to be take care off while designing .
    And would liek to know the Gain details at these frequency .
    Thanking you
  • FormerMember
    0 FormerMember
    The AD8108 has a gain of 1, while the AD8109 offers a gain of 2.  The frequency response is shown in the data sheet figures.
    http://www.analog.com/static/imported-files/data_sheets/AD8108_8109.pdf
    While designing pay attention to clean power sources, good decoupling and good routing.
