ADXL372 acceleration threshold
Question asked by FlyShock on Oct 13, 2017
Latest reply on Oct 19, 2017 by FlyShock
Hi everyone,
I have an ADXL372 MEMS accelerometer. It is working fine, I can read the data out of it and configure it.
There are several cases where I get into troubles.
The one I want to talk about is about triggering on acceleration thresholds.
The following parameters are applied:
ODR: 6400Hz
BW: 3200 HZ
High pass filter disabled
Activity threshold on all axis set to 10 (which is written as 100 since we should get 100mg/LSB)
   -->THRESH_ACT_X_H = 0x0C
   -->THRESH_ACT_X_L = 0x81   (same applied to all other axis)
Interrupt (INT1) mapped to Activity event
The activity timer is set to 0 (so as soon as I get a value above threshold, it should trigger)
From this I get 2 different scenarios.
If I set the threshold to 10G (as explained above), I never get any trigger. I can smash the board and nothing happen.
I checked the acceleration I get by reading the value while the sensor is set to stream data when ready, I can get peaks up to 150G.
If I set the threshold to 3G, I can trigger.
From what I observed, it looks like the threshold value scale is not what I expected or I am doing something wrong.
Thanks for your help.
