supersequencer software error windows 10
Question asked by GWSL2012 on Oct 12, 2017
Latest reply on May 9, 2018 by hopal
Hello all,
I encountered a problem with the supersequencer software on windows 10.
Upon starting the application, it crashes with a message box saying  "Evaluation Software funktioniert nicht mehr" = "Evaluation Software has stopped working".
I have installed LabView Runtime Engine Version 2011 as well as .NET Framework 3.5.
Originally I had installed the current (2017) version of the LabView Runtime Engine. However with this, the following Error Message appeared upon starting the application:
"LabView Runtime Engine could not be found.  SuperSequencerEval requires a LabView Runtime Engine Version 2011 (or compatible) [...]"
From
Does supersequencer software 4.2.3 run on Windows 8?
I learned that super sequencer software requires .net framework 3.5
Ideas anyone?
Does anyone have SuperSequencer running on a Windows 10? If so, could you please share which .NET Framework Version an LabView RunTime Engine you are using.
Stefan
