Help:AD9984A in 1080i60
Question asked by Chilton on Nov 2, 2011
Latest reply on Nov 3, 2011 by Chilton
When i use 1080i60/50(YUV) as input signal,the output image continuous shake up an down
(the function of my board is YUV to HDMI, AD9984 is used as YUV receiver and the HDMI transmitter is Sil9134 )
The same situation does not appear in the combination of the TVP7002 and Sil9134.
The picture below is the waveform of HSYNC and VSYNC.
Register configuration:
    ad9984_wr(0x01,0x89);
    ad9984_wr(0x02,0x80);
    ad9984_wr(0x03,0xA8);
    ad9984_wr(0x04,0x80);//Phase Adjust
    ad9984_wr(0x05,0x40);//gain and offset
    ad9984_wr(0x06,0x00);
    ad9984_wr(0x07,0x40);
    ad9984_wr(0x08,0x00);
    ad9984_wr(0x09,0x40);
    ad9984_wr(0x0A,0x00);
    ad9984_wr(0x0B,0x40);
    ad9984_wr(0x0C,0x00);
    ad9984_wr(0x0D,0x00);
    ad9984_wr(0x0E,0x80);
    ad9984_wr(0x0F,0x40);
    ad9984_wr(0x10,0x00);
    ad9984_wr(0x11,0x20); //Sync Separator Threshold
    ad9984_wr(0x12,0xC8);
    ad9984_wr(0x13,0x2C);//Hsync Duration  20
    ad9984_wr(0x14,0xCC);
    ad9984_wr(0x15,0x06);//Vsync Duration
    ad9984_wr(0x16,0x04);//Precoast
    ad9984_wr(0x17,0x04);//Postcoast
    ad9984_wr(0x18,0x0A);//Coast and Clamp select
    ad9984_wr(0x19,0x28);//this reg also affects the luma
    ad9984_wr(0x1A,0x20);
    ad9984_wr(0x1B,0xF3);//Clamp and Offset
    ad9984_wr(0x1C,0xFF);
    ad9984_wr(0x1D,0x78);//128mV trigger
    ad9984_wr(0x1E,0xE4);//SOG select and filter
    ad9984_wr(0x1F,0xB3);//4:2:2 YCbCr mode
    ad9984_wr(0x20,0x03);//clock select
    ad9984_wr(0x21,0x20);
    ad9984_wr(0x22,0x32);
    ad9984_wr(0x23,0x14);//Sync Filter Window Width
    ad9984_wr(0x28,0xBF);
    ad9984_wr(0x29,0x02);
    ad9984_wr(0x2C,0x00);// Auto-Offset
    ad9984_wr(0x2D,0xE8);
    ad9984_wr(0x2E,0xE0);
    ad9984_wr(0x34,0x00);//SOG Filter Disable
    ad9984_wr(0x36,0x00);//Disable low VCO gear
    ad9984_wr(0x3C,0x0E);//Auto Gain
    ad9984_wr(0x3C,0x00);
