Fail Building Refrence Design: DAQ2+ZC702+Vivado 2016.2
Question asked by Mingda on Oct 6, 2017
Latest reply on Oct 9, 2017 by rejeesh
I was trying to build the reference design for my DAQ2+ZC706 board, with Vivado 2016.2. When building the project, everything worked well from the beginning. I had built all library components before building the project. But when building the project, the error was shown:
open_run: Time (s): cpu = 00:00:41 ; elapsed = 00:00:40 . Memory (MB): peak = 2709.684 ; gain = 594.422
INFO: [Timing 38-2] Deriving generated clocks
INFO: [Timing 38-91] UpdateTimingParams: Speed grade: -2, Delay Type: min_max.
INFO: [Timing 38-191] Multithreading enabled for timing update using a maximum of 2 CPUs
report_timing_summary: Time (s): cpu = 00:00:37 ; elapsed = 00:00:22 . Memory (MB): peak = 2858.977 ; gain = 149.293
error copying "daq2_zc706.runs/impl_1/system_top.sysdef": no such file or directory
while executing
"file copy -force $project_name.runs/impl_1/system_top.sysdef $project_name.sdk/system_top.hdf"
invoked from within
"if [expr [get_property SLACK [get_timing_paths]] < 0] {
file copy -force $project_name.runs/impl_1/system_top.sysdef $project_name.sdk/system_top_..."
(procedure "adi_project_run" line 26)
invoked from within
"adi_project_run daq2_zc706"
(file "system_project.tcl" line 15)
INFO: [Common 17-206] Exiting Vivado at Thu Oct 05 17:41:23 2017...
Below is the list I have checked before I turn to Engineering Zone, hope these jobs also help.
1. Open the .xpr project, the log shows there is an error generating the bit file. (Attachment: Figure1)
2. Checked the library components, confirmed that the libraries are all built.
3. entered the folder "projects\daq2\zc706\daq2_zc706.sdk" but didn't find "system_top.hdf"
Is there any way that I can solve this issue?
Thanks!
