HMC7044 PLL2 is not locked
Question asked by fuji38 on Oct 3, 2017
Latest reply on Oct 5, 2017 by fuji38
Hello all,
I started using a HMC7044 evaluation board. Since there is an issue on controlling via USB-SPI, I am using a FPGA as the SPI controller. At first, as described in UG-826, I tried out the quick start configuration by extracting the register settings from the file "HMC7044_983MHz_122p88MHz_VCXO_DoublerON.py". However output frequency is not 983 MHz, but 860 MHz. It looks like PLL2 is not locked, and the internal VCO is stuck at low frequency.
The condition is:
- Connected 122.882 MHz at CLKIN0_RFSYNC_P input
- GPIO1 LED (PLL1 Lock) turns on.
- GPIO2 LED (PLL2 Lock) is off.
- CLKOUT10 frequency is 860.173 MHz
I added FSM restart and PLL2 status readout at the end of SPI sequence. There were 24 (0x18) autotune errors in the readout . That is:
# restart
time.sleep(0.01) # wait for 10 ms
rd = hmc7044.read(0x0001)
hmc7044.write(0x0001, rd | 0x01) # restart dividers/FSMs
hmc7044.write(0x0001, rd) # negate restart bit
# show PLL2 status
hmc7044.read(0x008c) # PLL2 autotune value
hmc7044.read(0x008d) # PLL2 autotune error (LSB)
hmc7044.read(0x008e) # PLL2 autotune error (MSB)
hmc7044.read(0x008f) # PLL2 autotune FMS state
debug: HMC7044 read(0x0001) --> 0x00
debug: HMC7044 write(0x0001, 0x01)
debug: HMC7044 write(0x0001, 0x00)
debug: HMC7044 read(0x008C) --> 0x1F
debug: HMC7044 read(0x008D) --> 0x18
debug: HMC7044 read(0x008E) --> 0x00
debug: HMC7044 read(0x008F) --> 0x00
Any ideas on fixing the issue?
Thank you,
--fuji
