VDSP --> CCES Linker error
Question asked by jeffmo77 on Sep 23, 2017
Latest reply on Sep 25, 2017 by Jithul_Janardhanan
Hello,  I've read through all of the discussions about this, but I'm still unable to get my project to build.  I'd really appreciate some assistance...
I have the 21469-EZ Kit board, and I'm just getting started.  I've gotten other projects to build and load just fine.  I created a new CCES project, and began adding files to my project from the VDSP example "21469 AD1939 C Sampled-Based Talkthru 48 or 96 kHz".  I copied the Main.c code into mine and modified for the interrupt, per the discussions here.  I also tried updating the LDF file to the default for CCES.
No matter what I do, I still get the following errors when I call adi_int_InstallHandler:
cc3089: fatal error: Link failed (code:1)
make: *** [Audio Processor.dxe] Error 1
Here is my code:
 * Audio Processor.c
#include "ADDS_21469_EzKit.h"
#include <sys/platform.h>
#include "adi_initialize.h"
#include "Audio Processor.h"
#include <services/int/adi_int.h>
float * DelayLine;
int Index  = 0;
int Sine_Index = 0;
int SPORT1_isr_count = 0;
int SPORT0_isr_count = 0;
void SPORT1_isr_counter(void);
void SPORT0_isr_counter(void);
int main(int argc, char *argv[])
    adi_initComponents();
    initPLL();   // initialize the PLL
    initDDR2DRAM();  // initialize the DDR2
    // Initialize DAI because the SPORT and SPI signals need to be routed
   InitDAI();
   // This function will configure the AD1939 codec on the 21469 EZ-KIT
   Init1939viaSPI();
   // Turn on SPORT0 TX and SPORT1 RX for Multichannel Operation
   enable_SPORT01_MCM_mode();
   // Unmask SPORT1 RX ISR Interrupt
       adi_int_InstallHandler(ADI_CID_SP1I, /*iid - high priority core timer */
                            (ADI_INT_HANDLER_PTR)process_AD1939_samples, /*handler*/
                          (void *)0, /*handler parameter*/
                             true);
       // Enable multichannel operation (SPORT mode and DMA in standby and ready)
           *pSPMCTL0 |= MCEA;
           *pSPMCTL1 |= MCEA;
           SinTableInit();
           // Set up small delay buffer
           DelayLine = (float *) 0x000C4000;
           for (;;)
               asm("idle;");
   return 0;
