hs_err_pid error in SDK2015.4.2
Question asked by SKTYLDD on Sep 19, 2017
Latest reply on Sep 20, 2017 by DragosB
hello
There are the following errors when I use the No-OS codes in AD9361 No-OS Software [Analog Devices Wiki] , the SDK version I use is 2015.4.2,could you please tell me how to solve it?
thank you very much.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_UNCAUGHT_CXX_EXCEPTION (0xe06d7363) at pc=0x000007fefd96a06d, pid=3528, tid=6704
# JRE version: Java(TM) SE Runtime Environment (8.0_45-b15) (build 1.8.0_45-b15)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.45-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [KERNELBASE.dll+0x1a06d]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x00000000180fb000): VMThread [stack: 0x0000000019160000,0x0000000019260000] [id=6704]
siginfo: ExceptionCode=0xe06d7363, ExceptionInformation=0x0000000019930520 0x000000001925f4c8 0x000007fef0c02cb8 0x000007fef0b50000
Registers:
RAX=0x000000006edccf39, RBX=0x000007fef0c02cb8, RCX=0x000000001925ed10, RDX=0x00000000000000d0
RSP=0x000000001925f320, RBP=0x000000001925f450, RSI=0x00000000ffffffff, RDI=0x00000000286ee610
R8 =0x0000000000000000, R9 =0x0000000000000000, R10=0x000007fef0b50000, R11=0x000000001925f360
R12=0x0000000000000001, R13=0x0000000000000008, R14=0x0000000000000000, R15=0xffffffffffffffff
RIP=0x000007fefd96a06d, EFLAGS=0x0000000000000206
Top of Stack: (sp=0x000000001925f320)
0x000000001925f320: 000007fef0c02cb8 00000000ffffffff
0x000000001925f330: 00000000286ee610 00000000002ccdb0
0x000000001925f340: 00000001e06d7363 0000000000000000
0x000000001925f350: 000007fefd96a06d 000007fe00000004
0x000000001925f360: 0000000019930520 000000001925f4c8
0x000000001925f370: 000007fef0c02cb8 000007fef0b50000
0x000000001925f380: 0000000000000000 000000001925f408
0x000000001925f390: 0000000000000028 00000000286ee600
0x000000001925f3a0: 000000001a7c50c0 0000000000000000
0x000000001925f3b0: 000007fffff98000 0000000077b5f4e3
0x000000001925f3c0: 0000000000000000 0000000000000008
0x000000001925f3d0: 0000000000000001 00000000286ee610
0x000000001925f3e0: 00000000ffffffff 000007fef0bae92c
0x000000001925f3f0: 000007fef0c02cb8 000000001925f460
0x000000001925f400: 0000000000000001 000007fef0b500f8
0x000000001925f410: 00000001e06d7363 0000000000000000
Instructions: (pc=0x000007fefd96a06d)
0x000007fefd96a04d: 54 24 24 48 89 4c 24 28 4d 85 c9 0f 85 6a 03 00
0x000007fefd96a05d: 00 89 4c 24 38 48 8d 4c 24 20 ff 15 33 02 03 00
0x000007fefd96a06d: 48 81 c4 c8 00 00 00 c3 90 90 90 90 90 90 90 90
0x000007fefd96a07d: 90 90 90 48 83 ec 28 65 48 8b 04 25 30 00 00 00
Register to memory mapping:
RAX=0x000000006edccf39 is an unknown value
RBX=0x000007fef0c02cb8 is an unknown value
RCX=0x000000001925ed10 is an unknown value
RDX=0x00000000000000d0 is an unknown value
RSP=0x000000001925f320 is an unknown value
RBP=0x000000001925f450 is an unknown value
RSI=0x00000000ffffffff is an unallocated location in the heap
RDI=0x00000000286ee610 is an unknown value
R8 =0x0000000000000000 is an unknown value
R9 =0x0000000000000000 is an unknown value
R10=0x000007fef0b50000 is an unknown value
R11=0x000000001925f360 is an unknown value
R12=0x0000000000000001 is an unknown value
R13=0x0000000000000008 is an unknown value
R14=0x0000000000000000 is an unknown value
R15=0xffffffffffffffff is an unknown value
Stack: [0x0000000019160000,0x0000000019260000], sp=0x000000001925f320, free space=1020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [MSVCR110.dll+0x5e92c]
C [MSVCR110.dll+0x1315c]
C [MSVCR110.dll+0x136a9]
C [MSVCR110.dll+0x13e9c]
C [MSVCR110.dll+0x239e]
C [MSVCR110.dll+0xaf9e]
C [MSVCP110.dll+0x397b9]
C [librdi_common.dll+0x14283e]
C [librdi_common.dll+0x141449]
C 0x000007fef2542400
C 0x000007fef2542682
C [ntdll.dll+0x22ac1]
C [ntdll.dll+0x228d0]
C [MSVCR100.dll+0x20ccd]
V [jvm.dll+0x20f135]
V [jvm.dll+0x247ef7]
V [jvm.dll+0x247196]
V [jvm.dll+0x247631]
V [jvm.dll+0x24784e]
V [jvm.dll+0x29853a]
C [MSVCR100.dll+0x21d9f]
C [MSVCR100.dll+0x21e3b]
C [kernel32.dll+0x159cd]
C [ntdll.dll+0x2a561]
VM_Operation (0x000000000012f500): Exit, mode: safepoint, requested by thread 0x0000000006528000
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x000000001f00b800 JavaThread "pool-2-thread-2" [_thread_blocked, id=2108, stack(0x0000000029f60000,0x000000002a060000)]
0x000000001f008000 JavaThread "pool-2-thread-1" [_thread_blocked, id=3692, stack(0x000000002a060000,0x000000002a160000)]
0x000000001e14a800 JavaThread "Thread-18" daemon [_thread_blocked, id=6300, stack(0x0000000029e60000,0x0000000029f60000)]
0x000000001948c000 JavaThread "TCF Locator DNS Lookup" daemon [_thread_blocked, id=1780, stack(0x0000000025dd0000,0x0000000025ed0000)]
0x0000000019489000 JavaThread "TCF Locator Timer" daemon [_thread_blocked, id=6244, stack(0x0000000025cd0000,0x0000000025dd0000)]
0x000000001948b000 JavaThread "TCF Locator Receiver" daemon [_thread_blocked, id=1208, stack(0x0000000025bd0000,0x0000000025cd0000)]
0x0000000019485000 JavaThread "TCF Timer Dispatcher" daemon [_thread_blocked, id=6676, stack(0x0000000024c80000,0x0000000024d80000)]
0x000000001eaee800 JavaThread "EMF Reference Cleaner" daemon [_thread_blocked, id=6524, stack(0x000000001f2d0000,0x000000001f3d0000)]
0x0000000019521000 JavaThread "Service Thread" daemon [_thread_blocked, id=1400, stack(0x0000000019d60000,0x0000000019e60000)]
0x0000000019483800 JavaThread "C1 CompilerThread2" daemon [_thread_blocked, id=6948, stack(0x0000000019c60000,0x0000000019d60000)]
0x0000000019480800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=5952, stack(0x0000000019b60000,0x0000000019c60000)]
0x000000001946b000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=6536, stack(0x0000000019a60000,0x0000000019b60000)]
0x0000000019468800 JavaThread "Attach Listener" daemon [_thread_blocked, id=6492, stack(0x0000000019960000,0x0000000019a60000)]
0x0000000018161800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6060, stack(0x0000000019860000,0x0000000019960000)]
0x0000000018107800 JavaThread "Finalizer" daemon [_thread_blocked, id=6936, stack(0x0000000019360000,0x0000000019460000)]
0x0000000018100800 JavaThread "Reference Handler" daemon [_thread_blocked, id=3268, stack(0x0000000019260000,0x0000000019360000)]
0x0000000006528000 JavaThread "main" [_thread_blocked, id=4868, stack(0x0000000000030000,0x0000000000130000)]
Other Threads:
=>0x00000000180fb000 VMThread [stack: 0x0000000019160000,0x0000000019260000] [id=6704]
VM state:at safepoint (shutting down)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x00000000064ee190] Threads_lock - owner thread: 0x00000000180fb000
Heap:
PSYoungGen total 143360K, used 26617K [0x00000000f5580000, 0x00000000ffa80000, 0x0000000100000000)
eden space 118784K, 22% used [0x00000000f5580000,0x00000000f6f7e630,0x00000000fc980000)
from space 24576K, 0% used [0x00000000fc980000,0x00000000fc980000,0x00000000fe180000)
to space 25088K, 0% used [0x00000000fe200000,0x00000000fe200000,0x00000000ffa80000)
ParOldGen total 101376K, used 45372K [0x00000000e0000000, 0x00000000e6300000, 0x00000000f5580000)
object space 101376K, 44% used [0x00000000e0000000,0x00000000e2c4f370,0x00000000e6300000)
Metaspace used 80262K, capacity 87072K, committed 87296K, reserved 1124352K
class space used 9886K, capacity 12001K, committed 12032K, reserved 1048576K
Card table byte_map: [0x0000000016160000,0x0000000016270000] byte_map_base: 0x0000000015a60000
Marking Bits: (ParMarkBitMap*) 0x000000006f604040
Begin Bits: [0x0000000016670000, 0x0000000016e70000)
End Bits: [0x0000000016e70000, 0x0000000017670000)
Polling page: 0x00000000064c0000
CodeCache: size=245760Kb used=31310Kb max_used=31321Kb free=214449Kb
bounds [0x0000000006a90000, 0x0000000008970000, 0x0000000015a90000]
total_blobs=9549 nmethods=8706 adapters=750
compilation: enabled
Compilation events (10 events):
Event: 515.067 Thread 0x0000000019483800 nmethod 10744 0x0000000007e113d0 code [0x0000000007e11820, 0x0000000007e13ce8]
Event: 515.085 Thread 0x0000000019480800 nmethod 10716 0x0000000008955990 code [0x0000000008955d40, 0x00000000089591a0]
Event: 515.085 Thread 0x0000000019480800 10728 4 org.eclipse.osgi.framework.internal.core.FilterImpl::matchCase (267 bytes)
Event: 515.113 Thread 0x0000000019480800 nmethod 10728 0x000000000895d350 code [0x000000000895d5c0, 0x000000000895fb80]
Event: 515.113 Thread 0x0000000019480800 10743 4 java.io.File::<init> (113 bytes)
Event: 515.116 Thread 0x0000000019480800 nmethod 10743 0x00000000072417d0 code [0x0000000007241940, 0x0000000007241d38]
Event: 515.151 Thread 0x0000000019480800 10745 4 java.io.File::isDirectory (43 bytes)
Event: 515.154 Thread 0x0000000019480800 nmethod 10745 0x0000000008432f50 code [0x00000000084330a0, 0x00000000084332a8]
Event: 515.178 Thread 0x0000000019483800 10746 3 org.eclipse.osgi.framework.internal.core.AbstractBundle::close (52 bytes)
Event: 515.179 Thread 0x0000000019483800 nmethod 10746 0x00000000084334d0 code [0x0000000008433700, 0x0000000008434408]
GC Heap History (10 events):
Event: 106.776 GC heap before
{Heap before GC invocations=17 (full 4):
PSYoungGen total 128000K, used 103424K [0x00000000f5580000, 0x00000000fed80000, 0x0000000100000000)
eden space 103424K, 100% used [0x00000000f5580000,0x00000000fba80000,0x00000000fba80000)
from space 24576K, 0% used [0x00000000fd380000,0x00000000fd380000,0x00000000feb80000)
to space 25600K, 0% used [0x00000000fba80000,0x00000000fba80000,0x00000000fd380000)
ParOldGen total 101376K, used 50499K [0x00000000e0000000, 0x00000000e6300000, 0x00000000f5580000)
object space 101376K, 49% used [0x00000000e0000000,0x00000000e3150f80,0x00000000e6300000)
Metaspace used 76996K, capacity 83622K, committed 83968K, reserved 1122304K
class space used 9574K, capacity 11663K, committed 11776K, reserved 1048576K
Event: 106.785 GC heap after
Heap after GC invocations=17 (full 4):
PSYoungGen total 129024K, used 9284K [0x00000000f5580000, 0x00000000ff980000, 0x0000000100000000)
eden space 103424K, 0% used [0x00000000f5580000,0x00000000f5580000,0x00000000fba80000)
from space 25600K, 36% used [0x00000000fba80000,0x00000000fc3912b0,0x00000000fd380000)
to space 24576K, 0% used [0x00000000fe180000,0x00000000fe180000,0x00000000ff980000)
ParOldGen total 101376K, used 50507K [0x00000000e0000000, 0x00000000e6300000, 0x00000000f5580000)
object space 101376K, 49% used [0x00000000e0000000,0x00000000e3152f80,0x00000000e6300000)
Event: 430.458 GC heap before
{Heap before GC invocations=18 (full 4):
PSYoungGen total 129024K, used 91849K [0x00000000f5580000, 0x00000000ff980000, 0x0000000100000000)
eden space 103424K, 79% used [0x00000000f5580000,0x00000000fa621278,0x00000000fba80000)
Metaspace used 79051K, capacity 86004K, committed 86272K, reserved 1124352K
class space used 9781K, capacity 11941K, committed 12032K, reserved 1048576K
Event: 430.467 GC heap after
Heap after GC invocations=18 (full 4):
PSYoungGen total 143360K, used 7234K [0x00000000f5580000, 0x00000000ff980000, 0x0000000100000000)
eden space 118784K, 0% used [0x00000000f5580000,0x00000000f5580000,0x00000000fc980000)
from space 24576K, 29% used [0x00000000fe180000,0x00000000fe890a38,0x00000000ff980000)
to space 24576K, 0% used [0x00000000fc980000,0x00000000fc980000,0x00000000fe180000)
ParOldGen total 101376K, used 50515K [0x00000000e0000000, 0x00000000e6300000, 0x00000000f5580000)
object space 101376K, 49% used [0x00000000e0000000,0x00000000e3154f80,0x00000000e6300000)
Event: 430.467 GC heap before
{Heap before GC invocations=19 (full 5):
Event: 430.830 GC heap after
Heap after GC invocations=19 (full 5):
PSYoungGen total 143360K, used 0K [0x00000000f5580000, 0x00000000ff980000, 0x0000000100000000)
from space 24576K, 0% used [0x00000000fe180000,0x00000000fe180000,0x00000000ff980000)
ParOldGen total 101376K, used 55523K [0x00000000e0000000, 0x00000000e6300000, 0x00000000f5580000)
object space 101376K, 54% used [0x00000000e0000000,0x00000000e3638db8,0x00000000e6300000)
Event: 495.436 GC heap before
{Heap before GC invocations=20 (full 5):
PSYoungGen total 143360K, used 67044K [0x00000000f5580000, 0x00000000ff980000, 0x0000000100000000)
eden space 118784K, 56% used [0x00000000f5580000,0x00000000f96f91e8,0x00000000fc980000)
Metaspace used 79451K, capacity 86266K, committed 86528K, reserved 1124352K
class space used 9792K, capacity 11942K, committed 12032K, reserved 1048576K
Event: 495.440 GC heap after
Heap after GC invocations=20 (full 5):
PSYoungGen total 143360K, used 1203K [0x00000000f5580000, 0x00000000ffa80000, 0x0000000100000000)
from space 24576K, 4% used [0x00000000fc980000,0x00000000fcaace30,0x00000000fe180000)
ParOldGen total 101376K, used 55531K [0x00000000e0000000, 0x00000000e6300000, 0x00000000f5580000)
object space 101376K, 54% used [0x00000000e0000000,0x00000000e363adb8,0x00000000e6300000)
Event: 495.440 GC heap before
{Heap before GC invocations=21 (full 6):
Event: 495.662 GC heap after
Heap after GC invocations=21 (full 6):
PSYoungGen total 143360K, used 0K [0x00000000f5580000, 0x00000000ffa80000, 0x0000000100000000)
Metaspace used 79424K, capacity 86224K, committed 86528K, reserved 1124352K
class space used 9788K, capacity 11935K, committed 12032K, reserved 1048576K
Deoptimization events (10 events):
Event: 514.373 Thread 0x0000000006528000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000000000834de0c method=org.eclipse.equinox.internal.event.EventHandlerTracker.getHandlers(Ljava/lang/String;)Ljava/util/Set; @ 28
Event: 514.374 Thread 0x0000000006528000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000088fbd80 method=org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(Lorg/eclipse/e4/core/internal/contexts/ContextChangeEvent;)Z @ 62
Event: 514.374 Thread 0x0000000006528000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000088a4b8c method=org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(Lorg/eclipse/e4/core/contexts/IEclipseContext;I[Ljava/lang/Object;)Z @ 173
Event: 514.428 Thread 0x0000000006528000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000000000847d4c8 method=org.eclipse.swt.graphics.Resource.dispose()V @ 15
Event: 514.947 Thread 0x0000000006528000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000000007334860 method=org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.shouldActivateFor(Ljava/lang/String;Lorg/eclipse/osgi/baseadaptor/BaseData;Lorg/eclipse/core/runtime/internal/ada彦Z箍 €@
Event: 514.969 Thread 0x000000001a527800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000000006fe99d8 method=org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(Ljava/lang/Object;Ljava/lang/Object;ILjava/lang/Object;)V @ 16
Internal exceptions (10 events):
Event: 513.990 Thread 0x000000001bbc1800 Exception <a 'java/lang/InterruptedException'> (0x00000000f59867c8) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u45\3627\hotspot\src\share\vm\runtime\objectMonitor.cpp, line 1683]
Event: 514.054 Thread 0x0000000006528000 Implicit null exception at 0x0000000006baad4c to 0x0000000006baada9
Event: 514.055 Thread 0x0000000006528000 Implicit null exception at 0x000000000729a061 to 0x000000000729a239
Event: 514.055 Thread 0x0000000006528000 Implicit null exception at 0x0000000008469f89 to 0x000000000846b2c1
Event: 514.209 Thread 0x0000000006528000 Implicit null exception at 0x00000000086fb224 to 0x00000000086fb569
Event: 514.420 Thread 0x000000001e147800 Exception <a 'java/lang/InterruptedException'> (0x00000000f6800558) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u45\3627\hotspot\src\share\vm\runtime\objectMonitor.cpp, line 1683]
Event: 514.992 Thread 0x000000002045d800 Exception <a 'java/lang/InterruptedException'> (0x00000000f6b00d08) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u45\3627\hotspot\src\share\vm\runtime\objectMonitor.cpp, line 1683]
Event: 514.992 Thread 0x000000001a17d800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000f6c55308) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u45\3627\hotspot\src\share\vm\prims\jvm.cpp, line 3211]
Event: 514.992 Thread 0x000000001a50b800 Exception <a 'java/lang/InterruptedException'> (0x00000000f6d7e208) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u45\3627\hotspot\src\share\vm\runtime\objectMonitor.cpp, line 1683]
Event: 515.178 Thread 0x000000001a527800 Exception <a 'java/lang/InterruptedException'> (0x00000000f6b00268) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u45\3627\hotspot\src\share\vm\runtime\objectMonitor.cpp, line 1683]
Events (10 events):
Event: 514.992 Thread 0x000000001a50b800 Thread exited: 0x000000001a50b800
Event: 515.178 Thread 0x000000001a527800 Thread exited: 0x000000001a527800
Event: 515.178 Thread 0x000000001a18a800 Thread exited: 0x000000001a18a800
Event: 515.178 loading class java/util/IdentityHashMap$KeyIterator
Event: 515.178 loading class java/util/IdentityHashMap$IdentityHashMapIterator
Event: 515.179 loading class java/util/IdentityHashMap$IdentityHashMapIterator done
Event: 515.179 loading class java/util/IdentityHashMap$KeyIterator done
Event: 515.179 Thread 0x0000000019487800 Thread added: 0x0000000019487800
Event: 515.179 Thread 0x0000000019487800 Thread exited: 0x0000000019487800
Event: 515.180 Executing VM operation: Exit
Dynamic libraries:
0x0000000000400000 - 0x000000000044f000 D:\vivado2015.4\SDK\2015.4\eclipse\win64.o\eclipse.exe
0x0000000077b10000 - 0x0000000077cba000 C:\Windows\SYSTEM32\ntdll.dll
0x00000000778f0000 - 0x0000000077a0f000 C:\Windows\system32\kernel32.dll
0x000007fefd950000 - 0x000007fefd9ba000 C:\Windows\system32\KERNELBASE.dll
0x0000000077a10000 - 0x0000000077b0a000 C:\Windows\system32\USER32.dll
0x000007feffa60000 - 0x000007feffac7000 C:\Windows\system32\GDI32.dll
0x000007feff330000 - 0x000007feff33e000 C:\Windows\system32\LPK.dll
0x000007feffad0000 - 0x000007feffb9b000 C:\Windows\system32\USP10.dll
0x000007fefdb60000 - 0x000007fefdbff000 C:\Windows\system32\msvcrt.dll
0x000007fefc140000 - 0x000007fefc334000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757\COMCTL32.dll
0x000007feffba0000 - 0x000007feffc11000 C:\Windows\system32\SHLWAPI.dll
0x000007fefe460000 - 0x000007fefe48e000 C:\Windows\system32\IMM32.DLL
0x000007feff220000 - 0x000007feff329000 C:\Windows\system32\MSCTF.dll
0x0000000072000000 - 0x0000000072012000 D:\vivado2015.4\SDK\2015.4\eclipse\win64.o\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20140116-2212\eclipse_1503.dll
0x000007fefe380000 - 0x000007fefe45b000 C:\Windows\system32\ADVAPI32.dll
0x000007fefe230000 - 0x000007fefe24f000 C:\Windows\SYSTEM32\sechost.dll
0x000007fefda30000 - 0x000007fefdb5d000 C:\Windows\system32\RPCRT4.dll
0x000007fefc700000 - 0x000007fefc70c000 C:\Windows\system32\VERSION.dll
0x000007fefbf60000 - 0x000007fefbfb6000 C:\Windows\system32\uxtheme.dll
0x000007fef7700000 - 0x000007fef770f000 C:\Windows\system32\hbhsp\IpConfigWin7.dll
0x00000000717b0000 - 0x0000000071883000 C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCP90.dll
0x0000000071700000 - 0x00000000717a3000 C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCR90.dll
0x000007fefb700000 - 0x000007fefb762000 C:\Windows\system32\RASAPI32.dll
0x000007fefb460000 - 0x000007fefb47c000 C:\Windows\system32\rasman.dll
0x000007feffa10000 - 0x000007feffa5d000 C:\Windows\system32\WS2_32.dll
0x000007feff800000 - 0x000007feff808000 C:\Windows\system32\NSI.dll
0x000007fefc710000 - 0x000007fefc73d000 C:\Windows\system32\ntmarta.dll
0x000007fefdc00000 - 0x000007fefdc52000 C:\Windows\system32\WLDAP32.dll
0x000007fefd480000 - 0x000007fefd4d7000 C:\Windows\system32\apphelp.dll
0x000007fef9630000 - 0x000007fef9c3b000 C:\Windows\system32\SOGOUPY.IME
0x000007fefaf40000 - 0x000007fefaf47000 C:\Windows\system32\MSIMG32.dll
0x000007fefa3e0000 - 0x000007fefa434000 C:\Windows\system32\OLEACC.dll
0x000007feffc20000 - 0x000007feffe1c000 C:\Windows\system32\ole32.dll
0x000007fefe490000 - 0x000007feff21b000 C:\Windows\system32\SHELL32.dll
0x000000006ee00000 - 0x000000006f683000 D:\vivado2015.4\SDK\2015.4\tps\win64\jre\bin\server\jvm.dll
0x000007fef7380000 - 0x000007fef7389000 C:\Windows\system32\WSOCK32.dll
0x000007fefd9d0000 - 0x000007fefda0b000 C:\Windows\system32\WINMM.dll
0x0000000077ce0000 - 0x0000000077ce7000 C:\Windows\system32\PSAPI.DLL
0x000000006dce0000 - 0x000000006ddb2000 C:\Windows\system32\MSVCR100.dll
0x0000000073a50000 - 0x0000000073a5f000 D:\vivado2015.4\SDK\2015.4\tps\win64\jre\bin\verify.dll
0x000000006edd0000 - 0x000000006edf9000 D:\vivado2015.4\SDK\2015.4\tps\win64\jre\bin\java.dll
0x000007fef7790000 - 0x000007fef7926000 C:\Program Files (x86)\SogouInput\Components\PicFace\1.0.0.1045\PicFace64.dll
0x000007feff810000 - 0x000007feff8ea000 C:\Windows\system32\OLEAUT32.dll
0x000007fefd5d0000 - 0x000007fefd5df000 C:\Windows\system32\profapi.dll
0x000000006edb0000 - 0x000000006edc6000 D:\vivado2015.4\SDK\2015.4\tps\win64\jre\bin\zip.dll
0x000007fef7760000 - 0x000007fef778a000 C:\Program Files (x86)\SogouInput\Components\SgAppender\1.0.0.207\SgAppender_Dll64.dll
0x000007fef7710000 - 0x000007fef775e000 C:\Program Files (x86)\SogouInput\Components\SGImeGuard\1.0.0.27\SGImeGuard64.dll
0x000007fefcd90000 - 0x000007fefcda8000 C:\Windows\system32\CRYPTSP.dll
0x000007fefca90000 - 0x000007fefcad7000 C:\Windows\system32\rsaenh.dll
0x000007fefd780000 - 0x000007fefd79e000 C:\Windows\system32\USERENV.dll
0x000007fefd3d0000 - 0x000007fefd3df000 C:\Windows\system32\CRYPTBASE.dll
0x0000000069d80000 - 0x0000000069d9a000 D:\vivado2015.4\SDK\2015.4\tps\win64\jre\bin\net.dll
0x000007fefcd30000 - 0x000007fefcd85000 C:\Windows\system32\mswsock.dll
0x000007fefcd20000 - 0x000007fefcd27000 C:\Windows\System32\wship6.dll
0x000007fefaf80000 - 0x000007fefafa7000 C:\Windows\system32\IPHLPAPI.DLL
0x000007fefaf60000 - 0x000007fefaf6b000 C:\Windows\system32\WINNSI.DLL
0x000007fefa220000 - 0x000007fefa238000 C:\Windows\system32\dhcpcsvc.DLL
0x000007fefa200000 - 0x000007fefa211000 C:\Windows\system32\dhcpcsvc6.DLL
0x0000000069d60000 - 0x0000000069d71000 D:\vivado2015.4\SDK\2015.4\tps\win64\jre\bin\nio.dll
0x00000000066f0000 - 0x00000000067af000 C:\Program Files (x86)\SogouInput\7.2.0.2548\Resource.dll
0x000007fefda10000 - 0x000007fefda28000 C:\Windows\system32\dwmapi.dll
0x0000000180000000 - 0x00000001800a6000 C:\Windows\system32\hbhsp\prtrech64.dll
0x000007fefae20000 - 0x000007fefae91000 C:\Windows\system32\WINSPOOL.DRV
0x000007fefd3a0000 - 0x000007fefd3c5000 C:\Windows\system32\SspiCli.dll
0x000000001b1d0000 - 0x000000001b27c000 C:\Windows\system32\hbhsp\recfnt.dll
0x000007fefb2a0000 - 0x000007fefb2b5000 C:\Windows\system32\NLAapi.dll
0x000007fef1280000 - 0x000007fef1295000 C:\Windows\system32\napinsp.dll
0x000007fef08f0000 - 0x000007fef0909000 C:\Windows\system32\pnrpnsp.dll
0x000007fefcbb0000 - 0x000007fefcc0b000 C:\Windows\system32\DNSAPI.dll
0x000007fef3a80000 - 0x000007fef3a8b000 C:\Windows\System32\winrnr.dll
0x000000001b5a0000 - 0x000000001b5e2000 C:\Windows\system32\hbhsp\MinLSP64.dll
0x000007fefc6f0000 - 0x000007fefc6f7000 C:\Windows\System32\wshtcpip.dll
0x000007fef9620000 - 0x000007fef9628000 C:\Windows\system32\rasadhlp.dll
0x000007fefa250000 - 0x000007fefa2a3000 C:\Windows\System32\fwpuclnt.dll
0x000000001f9b0000 - 0x000000001fa58000 C:\Users\710-6\.Xilinx\SDK\2015.4\org.eclipse.osgi\bundles\303\1\.cp\swt-win32-4335.dll
0x000007feff970000 - 0x000007feffa07000 C:\Windows\system32\comdlg32.dll
0x000007feff4d0000 - 0x000007feff7f1000 C:\Windows\system32\WININET.dll
0x000007fefd770000 - 0x000007fefd774000 C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll
0x000007fefd9c0000 - 0x000007fefd9c4000 C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
0x000007fefd6d0000 - 0x000007fefd6d4000 C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll
0x000007fefd6c0000 - 0x000007fefd6c3000 C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll
0x0000000077cd0000 - 0x0000000077cd3000 C:\Windows\system32\normaliz.DLL
0x000007fefdf40000 - 0x000007fefe20a000 C:\Windows\system32\iertutil.dll
0x000007fefd760000 - 0x000007fefd765000 C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll
0x000007fefd7a0000 - 0x000007fefd90d000 C:\Windows\system32\CRYPT32.dll
0x000007fefd5e0000 - 0x000007fefd5ef000 C:\Windows\system32\MSASN1.dll
0x000007fefbfc0000 - 0x000007fefc0ec000 C:\Windows\system32\propsys.dll
0x000007fefe2e0000 - 0x000007fefe379000 C:\Windows\system32\CLBCatQ.DLL
0x000000001c640000 - 0x000000001c65e000 C:\Users\710-6\.Xilinx\SDK\2015.4\org.eclipse.osgi\bundles\303\1\.cp\swt-gdip-win32-4335.dll
0x000007fefbd40000 - 0x000007fefbf57000 C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23807_none_14556b8e8b95d1fc\gdiplus.dll
0x000007fefb9a0000 - 0x000007fefbb01000 C:\Windows\system32\WindowsCodecs.dll
0x000000001c990000 - 0x000000001c9a2000 C:\Users\710-6\.Xilinx\SDK\2015.4\org.eclipse.osgi\bundles\121\1\.cp\os\win32\x86_64\localfile_1_0_0.dll
0x000007fef4310000 - 0x000007fef4321000 C:\Users\710-6\.Xilinx\SDK\2015.4\org.eclipse.osgi\bundles\124\1\.cp\jWinHttp-1.0.0.dll
0x000007fef56c0000 - 0x000007fef5731000 C:\Windows\system32\WINHTTP.dll
0x000007fef5650000 - 0x000007fef56b5000 C:\Windows\system32\webio.dll
0x000007fefc960000 - 0x000007fefc96a000 C:\Windows\system32\credssp.dll
0x000007fefd520000 - 0x000007fefd534000 C:\Windows\system32\RpcRtRemote.dll
0x000007fefb490000 - 0x000007fefb49f000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\librdi_repo_manager.dll
0x000007fef2d40000 - 0x000007fef2d6a000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libisl_sysinfo.dll
0x000007fef0b50000 - 0x000007fef0c24000 C:\Windows\system32\MSVCR110.dll
0x000007fef0aa0000 - 0x000007fef0b47000 C:\Windows\system32\MSVCP110.dll
0x000007febc780000 - 0x000007febd10d000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\librdi_common.dll
0x000007fee1720000 - 0x000007fee1a8e000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libCOIN-all.dll
0x000007fee1500000 - 0x000007fee171e000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libXil_lmgr11.dll
0x000007fefb860000 - 0x000007fefb876000 C:\Windows\system32\NETAPI32.dll
0x000007fefb850000 - 0x000007fefb85c000 C:\Windows\system32\netutils.dll
0x000007fefcfa0000 - 0x000007fefcfc3000 C:\Windows\system32\srvcli.dll
0x000007fefb830000 - 0x000007fefb845000 C:\Windows\system32\wkscli.dll
0x000007fefd6e0000 - 0x000007fefd71b000 C:\Windows\system32\WINTRUST.dll
0x000007fef51b0000 - 0x000007fef51c0000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_date_time.dll
0x000007fef29b0000 - 0x000007fef29d2000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_filesystem.dll
0x000007fef2dd0000 - 0x000007fef2dd9000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_system.dll
0x000007fef0c80000 - 0x000007fef0cf4000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_program_options.dll
0x000007febd9a0000 - 0x000007febda9a000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_regex.dll
0x000007fef2b90000 - 0x000007fef2ba3000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_signals.dll
0x000007fef2990000 - 0x000007fef29ad000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_thread.dll
0x000007fef2b80000 - 0x000007fef2b8b000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_chrono.dll
0x000007fef2980000 - 0x000007fef298b000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_xilinx.dll
0x000007fef10e0000 - 0x000007fef1160000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libhdlpsolve.dll
0x000007fee1460000 - 0x000007fee14fa000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libhdxml.dll
0x000007febd560000 - 0x000007febd994e00 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libisl_iostreams.dll
0x000007fef2960000 - 0x000007fef2976000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libboost_iostreams.dll
0x000007fef2700000 - 0x000007fef2723000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\librdizlib.dll
0x000007fef2080000 - 0x000007fef20a3000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\libisl_iosutils.dll
0x000007fef26e0000 - 0x000007fef26f5000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\pthreadVC2.dll
0x000007fef0500000 - 0x000007fef0554000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\librdi_commonxillic.dll
0x000007febd430000 - 0x000007febd560000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\librdi_curl.dll
0x000007fef2640000 - 0x000007fef2658000 D:\vivado2015.4\SDK\2015.4\lib\win64.o\librdiconfig.dll
VM Arguments:
jvm_args: -Dcom.xilinx.sdk.args.hwspec=C:/Users/710-6/Desktop/hdl-2016_r1/projects/fmcomms2/zc702/fmcomms2_zc702.sdk/system_top.hdf -Xms64m -Xmx512m &
java_command: <unknown>
java_class_path (initial): D:\vivado2015.4\SDK\2015.4\eclipse\win64.o\\plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
Launcher Type: generic
Environment Variables:
PATH=D:/vivado2015.4/SDK/2015.4/tps/win64/jre/bin/server;D:/vivado2015.4/SDK/2015.4/tps/win64/jre/bin;D:/vivado2015.4/SDK/2015.4/tps/win64/jre/lib/amd64;D:\vivado2015.4\SDK\2015.4\gnuwin\bin;D:\vivado2015.4\SDK\2015.4\gnu\microblaze\nt\bin;D:\vivado2015.4\SDK\2015.4\gnu\microblaze\linux_toolchain\nt64_le\bin;D:\vivado2015.4\SDK\2015.4\gnu\microblaze\linux_toolchain\nt64_be\bin;D:\vivado2015.4\SDK\2015.4\gnu\arm\nt\bin;D:\vivado2015.4\SDK\2015.4\gnu\aarch64\nt\aarch64-none\bin;D:\vivado2015.4\SDK\2015.4\gnu\aarch64\nt\aarch64-linux\bin;D:\vivado2015.4\SDK\2015.4\gnu\armr5\nt\gcc-arm-none-eabi\bin;D:\vivado2015.4\SDK\2015.4\gnu\aarch32\nt\gcc-arm-none-eabi\bin;D:\vivado2015.4\SDK\2015.4\gnu\aarch32\nt\gcc-arm-linux-gnueabi\bin;D:\vivado2015.4\SDK\2015.4\bin;D:\vivado2015.4\SDK\2015.4\lib\win64.o;D:\vivado2015.4\SDK\2015.4\tps\win64\jre\bin\server;D:\vivado2015.4\SDK\2015.4\tps\win64\jre\bin;D:\vivado2015.4\Vivado\2015.4\ids_lite\ISE\bin\nt64;D:\vivado2015.4\Vivado\2015.4\ids_lite\ISE\lib\nt64;D:\vivado2015.4\Vivado\2015.4\bin;D:\vivado2015.4\Vivado\2015.4\lib\win64.o;D:\vivado2015.4\Vivado\2015.4\tps\win64\jre\bin\server;D:\vivado2015.4\Vivado\2015.4\tps\win64\jre\bin;D:\vivado2015.4\Vivado_HLS\2015.4\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\adb;E:\aos\ndk\NDK\aos-ndk-r01;D:\Program Files (x86)\Altium Designer Winter 09\System;D:\MATLAB2013a\runtime\win64;D:\MATLAB2013a\bin;D:\Program Files (x86)\ssh;D:\Program Files (x86)\vscoder\Microsoft VS Code\bin;C:\Users\710-6\Desktop\hdl-2016_r1\projects\fmcomms2\zc702;
USERNAME=710-6
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 (6.1.7601.23807)
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 60 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, lzcnt, tsc, tscinvbit, bmi1, bmi2
Memory: 4k page, physical 8334212k(4998460k free), swap 16666564k(12846396k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.45-b02) for windows-amd64 JRE (1.8.0_45-b15), built on Apr 30 2015 12:40:44 by "java_re" with MS VC++ 10.0 (VS2010)
time: Wed Sep 20 09:36:53 2017
elapsed time: 515 seconds (0d 0h 8m 35s)
