(ADV7480)Mipi undershoot
Question asked by donadona999s on Sep 11, 2017
Latest reply on Sep 20, 2017 by donadona999s
Hi !
I have some questions about ADV7480.
I asked about MIPI line at this session.
(ADV7281-M) Some question about video network.
The device is not same but I think you can say same thing to ADV7480 Mipi-line.
At the thread, ADI's answer is this
Q2) and Q3)
All termination for the MIPI lines are controlled by the MIPI D-PHY physical layer in the ADV728x-M and the MIPI D-PHY physical layer in the reciever chip. I strongly advise not placing any other components on the MIPI lines as doing so could violate MIPI D-PHY specifications.
See layout recommendations in the link below for more information.  http://www.analog.com/media/en/technical-documentation/application-notes/AN-1337.pdf
And I said to my customer same thing.
But our customer have some undershoot problem
The mipi pin signal voltage range specification is -50~1350mV.
But the yellow line looks it is very close to -50mV.
Q1)
Do you think would this undershoot cause any problem?
Q2)
Can you give some advice why this happen?
Only the PCB layout is the reason?
Q3)
If I gave you our customers PCB layout, can you revue it?
Best regards
Kawa
