ADV7511P output enable
Question asked by psusi on Sep 6, 2017
Latest reply on Sep 22, 2017 by MikeOC
I have the ADV7612-7511P eval board and running this script gets me some kind of output.  I took only the writes to address 72 and had my code write those same values to the 7511P on our own board, read them back to verify they took, and it does not generate any output.  We have not connected the I2C lines to the HDMI connector but it does not look like this script tries to communicate with the monitor anyhow.  We also do not have HPD connected, but I added a write of 80 to register D6 to force HPD.  Any idea why it isn't powering on?
## HDMI IN ADV7612 - HDMI OUT ADV7511 ##
:6-1d Port A, 480i,576i,240p,288p,480p 576p Any Color Space In (YCrCb 444 36bit from ADV761x) Through HDMI Out 36-bits 444 YCrCb (Fast Switching)VIC[1-3,6-14,17,18,21-29,30]:
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 F5 ; Auto CSC, YCrCb out, Set op_656 bit
98 03 42 ; 36 bit SDR 444 Mode 0
98 05 28 ; AV Codes Off
98 0B 44 ; Power up part
98 0C 42 ; Power up part
98 14 7F ; Max Drive Strength
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL enable
44 BA 01 ; Set HDMI FreeRun
64 40 81 ; Disable HDCP 1.1 features
68 9B 03 ; ADI recommended setting
68 00 08 ; Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
68 02 03 ; Enable Ports A & B in background mode
68 83 FC ; Enable clock terminators for port A & B
68 6F 0C ; ADI recommended setting
68 85 1F ; ADI recommended setting
68 87 70 ; ADI recommended setting
68 8D 04 ; LFG Port A
68 8E 1E ; HFG Port A
68 1A 8A ; unmute audio
68 57 DA ; ADI recommended setting
68 58 01 ; ADI recommended setting
68 75 10 ; DDC drive strength
68 90 04 ; LFG Port B
68 91 1E ; HFG Port B
72 01 00 ; Set N Value(6144)
72 02 18 ; Set N Value(6144)
72 03 00 ; Set N Value(6144)
72 15 00 ; Input 444 (RGB or YCrCb) with Separate Syncs, 44.1kHz fs
72 16 60 ; Output format 444, 36-bit input
72 18 46 ; CSC disabled
72 40 80 ; General Control packet enable
72 41 10 ; Power down control
72 48 08 ; Data right justified
72 49 00 ; No truncation
72 4C 00 ; 12 bit Output
72 55 40 ; Set YCrCb 444 in AVinfo Frame
72 56 08 ; Set active format Aspect
72 96 20 ; HPD Interrupt clear
72 98 03 ; ADI Recommended Write
72 99 02 ; ADI Recommended Write
72 9C 30 ; PLL Filter R1 Value
72 9D 61 ; Set clock divide
72 A2 A4 ; ADI Recommended Write
72 A3 A4 ; ADI Recommended Write
72 A5 04 ; ADI Recommended Write
72 AB 40 ; ADI Recommended Write
72 AF 16 ; Set HDMI Mode
72 BA 60 ; No clock delay
72 D1 FF ; ADI Recommended Write
72 DE D8 ; ADI Recommended Write
72 E4 60 ; VCO_Swing_Reference_Voltage
72 FA 7D ; Nbr of times to search for good phase
End
