ADF5355 Unstable output
Question asked by rubenz on Sep 1, 2017
Latest reply on Oct 11, 2017 by MRichardson
  • Operating frequency: 3 GHz
  • Ref frequency: 20 MHz
  • Charge Pump: High Current mode
  • Integer-N Mode
PLL locks at first, then gradually spectrum spreads out only in higher frequency direction and goes out of lock.
Checking:
  • Ref divider output is good
  • N divider output is quite low
  • Charge pump is railed low
  • VCO is sourcing current!
We have two boards exhibiting this behavior, each boards has 2x ADF5355 chips installed. Replaced the chips --- observed the same issue.
Attached are circuit diagram and programming code.
Thanks.
