Cable driver
Question asked by xzsawq21 on Aug 24, 2017
Latest reply on Sep 8, 2017 by xzsawq21
Hello
(low noise and low distortion application)
I want to buffer a small signal with ADA4817 and then send the output signal through a 50 Ohm coax cable. I put a series 50 Ohm resistor at the output of ADA4817. the cable's length is 1 meter.
signal--->ADA4817---50 ohm----->----------------coax cable-------------------->filter>......
is there any problems? or it's better to translate it using a FDA and then sent it through 2 coax cables (I don't have a suitable STP cable)? can I have any common mode voltage (Vdc) on the cables?
Thanks
