AD9914 direct mode and sync_clock
Question asked by ChristopheMe on Aug 23, 2017
Latest reply on Aug 30, 2017 by mcee
I am using an AD9914 evaluation board linked to a Xilinx Virtex5 FPGA.
I can read and write registers in parallel mode (F=”0000”) and use the AD9914 in profile mode with success.
My goal is to use it in direct mode and I am encountering some problems.
When I switch in mode F=”0010” and I put a constant frequency on the data bus (D[31..0]) it works.
But as soon as I change the frequency, the AD9914 goes in a strange mode and only a reset can make it works again: the SYNC_CLK change from 100MHz to 1MHz and I cannot change the frequency anyway.
Could you please help me to solve this problem?
I suspect that the data change (D[31..0]) don’t respect the 2ns timing before SYNC_CLK. So I am changing the data only every 6 SYNC_CLK periods and rise the IO_UPDATE signal for 2 SYNC_CLK periods 2 SYNC_CLK period after the data change, so I am sure data are stable 1 period before the IO_UPDATE signal (see attached picture).
Christophe
My registers configuration is:
// CFR1
   // <Register Address="00" Data="00010008" />
   WriteDDSReg(    0x00,   0x08     );
   WriteDDSReg(    0x01,   0x00     );
   WriteDDSReg(    0x02,   0x01     );
   WriteDDSReg(    0x03,   0x00     );
   // CFR2
   // <Register Address="01" Data="00800900" />
   WriteDDSReg(    0x04,   0x00     );
   WriteDDSReg(    0x05,   0x09     );
   WriteDDSReg(    0x06,   0x80     );
   WriteDDSReg(    0x07,   0x00    );
   // CFR3
   // <Register Address="02" Data="0004781C" />
   WriteDDSReg(    0x08,   0x1C     );
   WriteDDSReg(    0x09,   0x78     );
   WriteDDSReg(    0x0A,   0x04     );
   WriteDDSReg(    0x0B,   0x00     );
   // CFR4
   // <Register Address="03" Data="00052120" />
   WriteDDSReg(    0x0C,   0x20     );
   WriteDDSReg(    0x0D,   0x21     );
   WriteDDSReg(    0x0E,   0x05     );
   WriteDDSReg(    0x0F,   0x00     );
   // Digital ramp lower limit
   WriteDDSReg(    0x10,   0x00     );
   WriteDDSReg(    0x11,   0x00     );
   WriteDDSReg(    0x12,   0x00     );
   WriteDDSReg(    0x13,   0x00     );
   // Digital ramp upper limit
   WriteDDSReg(    0x14,   0x00     );
   WriteDDSReg(    0x15,   0x00     );
   WriteDDSReg(    0x16,   0x00     );
   WriteDDSReg(    0x17,   0x00     );
   // Profile 0: frequency
   // <Register Address="0B" Data="0AAAAAAA" (99.99999962747 MHz)
   WriteDDSReg(    0x2C,   0xAA     );
   WriteDDSReg(    0x2D,   0xAA     );
   WriteDDSReg(    0x2E,   0xAA     );
   WriteDDSReg(    0x2F,   0x0A     );
   // Profile 0: phase / amplitude
   // <Register Address="0C" Data="00000000" />
   WriteDDSReg(    0x30,   0x00     );
   WriteDDSReg(    0x31,   0x00     );
   WriteDDSReg(    0x32,   0xff    );
   WriteDDSReg(    0x33,   0xff    );
And to switch in direct mode:
      WriteDDSReg(0x06, 0x40); // disable profile mode and enable parallel mode
